Help me diagnose my...
[Closed] Help me diagnose my garage door not closing problem
10 Users
We have an electric garage door which is opening as normal however it won't close - when I press the button on the remote I can hear a 'clicking' noise which is, I believe, the sound of the safety sensors tripping (there are two sensors at approx knee-height which will stop the door from closing if they are triggered). However there is nothing in their path. I have checked them both by removing the covers and cleaning the optical lenses which were slightly covered in dust/cobwebs but it's still happening. The only other thing I can see that is a potential issue is that there was some water ingress after some heavy storms recently which dripped a little water onto one of the sensors but the insides seem 100% dry.
Any suggestions on where else I should be looking to trouble-shoot this?
Posted : 13/01/2020 11:00 am
Can you not 'bridge' the various switches/sensors in turn to work out which one is recording a false positive (or negative if a circuit that should be made isn't)?
Posted : 13/01/2020 11:09 am
Can you not ‘bridge’ the various switches/sensors in turn to work out which one is recording a false positive (or negative if a circuit that should be made isn’t)?
No, as I wouldn't have a clue where to start 🙁
Posted : 13/01/2020 11:13 am
I'd check the price on them and if they're cheap experiment by just swapping in new components.
Or get someone in who know what they're doing 😉
Posted : 13/01/2020 11:17 am
You certain it's those sensors, and not some kind of anti-crush thing that thinks there's something the door is shutting on? That could be a simple need for lubrication?
Posted : 13/01/2020 1:11 pm
Does it move at all? If not then like fadda says it sounds like something in the anticrush or similar. Is there a manual override that can be used to help kickstart it?
Posted : 13/01/2020 1:19 pm
Do you mean it tries to do something THEN clicks or clicks THEN does nothing?
Posted : 13/01/2020 1:21 pm
Is your car halfway in? That'd do it.
I'd be looking at lube / jamming also.
Posted : 13/01/2020 1:24 pm
I can make it go down by using the manual over-ride (which it does quite smoothly) so I don't think it is an anti-crush thing. However when I press the remote it makes no attempt to close at all, it just clicks straight away which sounds like the click I hear when I trip the sensors (every time I walk in or out of the garage they click as they beam is interrupted) so it *seems* it's the sensors that are being triggered but there is nothing in their path. Unless it's a poltergeist loitering in the doorway?
Posted : 13/01/2020 1:37 pm
Also, if I manually move it down at all (ie, so it is half closed) it still won't continue to close, it will just open up again.
Posted : 13/01/2020 1:38 pm
I've literally just been into a local garage door dealer to ask about the same problem.
Mine appears to work fine but won't go down on the button. He said it's a safety feature. There's a small box on the bottom edge of my door which is a proximity sensor to stop it from crushing stuff. He said there should be a small lithium battery in there and when it runs out, the sensor stops working and the door won't close.
He also said if I try holding the 'down' button for 15 seconds it'll work like a dead man switch i.e. it'll move as long as I'm holding the button. Can't wait to get home and try it.
Posted : 13/01/2020 1:44 pm
I tried the 'hold it down' thing and it doesn't work on mine. Also mine are hard-wired (old-school 1980s door) so no batteries in them.
Posted : 13/01/2020 2:20 pm
Have you emptied a can of WD40 all over it yet? The internet tells me that will fix anything. Didn't seem to fix to bowl I dropped on the floor last night though.
Posted : 13/01/2020 4:03 pm
Mine was the 3.6v lithium battery (you'll have to get it online) but now its detecting an impact when it touches the floor and keeps opening a few centimeters (or staying shut but sounding the alarm as it thinks someone is lifting the door). Bloody thing.
Posted : 13/01/2020 4:09 pm
As mentioned earlier, mine doesn't have batteries (or doesn't seem to have any) as it looks hard-wired in. I will check again when it isn't blowing a gale outside.
Posted : 13/01/2020 4:12 pm
If it doesn't have batteries for the sensor then there might be a problem or break with the wire or track that gets power to the sensor?
Posted : 13/01/2020 5:08 pm
