Help fix my hole (r...
Help fix my hole (roofing content)
11 Users
2 Reactions
Have some scaffold on the house for another job.  Whilst up there, examining the eaves and found this:
[url= https://i.ibb.co/kmcfXPD/IMG-20240604-133044562.jp g" target="_blank">https://i.ibb.co/kmcfXPD/IMG-20240604-133044562.jp g"/> [/img][/url]
Looks like the bottom piece of mortar has just fallen out.  Any thoughts on a good fix?  Guessing maybe fill with repair mortar?  But presumably would need something to keep it in place whilst it dries?
Any ideas?  Have got a big tub of this: www.platinumchemicals.co.uk/products/soudal-cement-repair-express kicking around
Posted : 04/06/2024 1:44 pm
The mortar should be resting on cement board, that's the sheet underneath the mortar that's still in place. You'll need to replace that and then put the mortar in.
Posted : 04/06/2024 2:32 pm
Might want to repaint the soffit boards whilst the scaffolding is up
Posted : 04/06/2024 2:39 pm
Remove all the cement board and mortar and spend 30mins fitting dry verge and you won't have to keep patching it up as bit after bit fails.
Posted : 04/06/2024 2:42 pm
The cracked cement sheet holding the pointing up is called under cloaking, you can buy this from builders merchants. That then supports the mortar pointing, make sure you don't use a very wet mix or it'll shrink when it dries and fall out!
Re: dry ridges they are lower maintenance but still have habit of blowing off in high winds and they don't look as nice in my opinion.
Posted : 04/06/2024 2:43 pm
Posted : 04/06/2024 3:52 pm
Flexim Roof Putty is ideal for this sort of problem...
https://flexim.eu/en/what-is-flexim/
Posted : 04/06/2024 3:57 pm
Likely to be asbestos cement under-cloaking by the look of it.
Posted : 04/06/2024 4:20 pm
Wow - under cloaking. Who knew that's what it was called. Every day is a school day
Posted : 04/06/2024 4:31 pm
Next question then - how do I cut under cloaking board?!
Posted : 04/06/2024 4:45 pm
Depends if it's asbestos or not....
Posted : 04/06/2024 5:14 pm
Depends if it’s asbestos or not…
I'm thinking the repair piece I buy from the shop hopefully won't be 😉
Posted : 04/06/2024 7:22 pm
Score and snap with a Stanley knife I would have thought.
Posted : 04/06/2024 8:19 pm
What is Flexim
Exceedingly expensive is what it is.
Posted : 04/06/2024 8:32 pm
A multi tools ace for jobs like that.
Posted : 04/06/2024 8:35 pm
