OK - this has me flummoxed:
A woman has a clock that strikes the number of hours every hour (e.g. it strikes four times at four o'clock). It also strikes once every half hour.
She goes into her house and as she opens the front door she hears the clock strike once.
Half an hour later it strikes again.
Half an hour later, just as she is going out of the door, she hears it strike once again.
What time was it as she entered the house and what time was it as she left again? (the clock is working correctly)
last stroke of 12
12.30
1
1.30
1st stroke of 2 (as door is shutting) ?
Given that that is probably the answer, what branch of maths is that?
12:30 am and 1:30am.... The day the clocks go back
More importantly, where is she going at 1:30am?
A clock? How quaint.
Answers above all assume a loaded question.
As a straight question it's unanswerable.
^ I'm glad you've said that as I don't think there is an answer. Will report back when we get the teacher's input
Maths?
2 hours have passed as measured by 5 events over 4 intervals, but given that you know only that the clock has struck, and not the number of times during the mid-intervals. It could be any period which starts on the half-hour and ends two hours later on the half hour.
It's time to get a chuffing clock that doesn't chuffing chime every chuffing half an hour!
logic.
So this woman has a clock in her house, which she has heard chime five times in the past two hours, but she still needs us to tell her what time it is??
She must work in management.
It's not logic. It's a smart-arsed question. It's likely to be muddy arsed guy's solution but that depends on you thinking of that particular situation and knowing about when the clocks go back (which 10 year olds might not). So it's not logic because you have to guess this and you aren't given it.
Other possibility:
She lives on a house boat/in a motor home which is near a time zone boundary, and the clock is a smart one that updates its time zone via GPS. The mobile house crosses the time zone boundary westwards between 1 o'clock and 2 o'clock.
Its not muddys answer, I'd bet its this as posted above -
last stroke of 12
12.30
1
1.30
Read the question, it says 'She goes into her house and as she opens the front door she [b]hears[/b] the clock strike once'
Not "the clock strikes once", but she [I]hears[/I] it strike once. Same for when she's leaving.
Logic.
Wouldn't she have to put the clock back? I think Scaredypants has it.
If it's a 24h clock; she enters at 12am, leaves at 2am
Not if it does it automatically. Could be electronic.
Often the people who set these questions have a particular answer in mind but aren't aware there are other valid answers, btw.
Not seen an electronic striking clock. Curious turn of phrase for one too, chime would be more typical
(I have no idea btw, just fun drawing this out :-D)
It says 'the clock strikes'.
But since we are on this path.. another possibility:
The clock itself has a very quiet bell that cannot be heard from the front door. However it's mounted on a rotating arm that takes half an hour to complete a revolution. At one point on the clock's circuit is a bell which the clock bumps or strikes each revolution. This bell is much louder and is the one she hears.
Anyway, ask the "maths" teacher for their working.
I also have a question...
If a train from Somerset leaves at 1200 travelling South, and a train from Reading leaves at 12:15 travelling Northwest, then at what time will my father who left for a packet of cigarettes 25 years ago come back?
So it could be any time on the hour or half hour if the open/closing the door while chimes are starting/ending premise applies.
Is the clock on a treadmill ?
It's a sort of trick question - I don't think these do anything for giving children confidence in their maths ability.
OK, the rather annoying answer is:
She arrived on the last stroke of 12 o'clock and left on the first stroke of 2 o'clock.
Scaredypants has it
But I entirely agree with Prezet
Is it a train driver's clock?
Nope, the only way it can chime once three times in a row is around 1 'o' clock (12:30, 1:00 and 13:30). Once you've established that then it's clear she must have missed the other chimes for 12:00 and 02:00.
Where does it say it strikes *once* three times in a row 🙂
I think you should have told your kid about Schrodinger and his cat.
If nobody heard the clock strike then did the clock strike or not?
Rubbish! As has been pointed out, the question doesn't even specify how many times the clock struck the 2nd, 3rd and 4th time. It's a dreadful question and I'd be pointing that out to the teacher. It's like one of those awful riddles that has an improbable and convoluted answer (or several!); it teaches you how to think laterally but I'm not sure it has a place in maths teaching which is about rules and patterns.
The only "logic" I can see here is in recognising absolutes.
The only time it strikes once three times in succession is at 1am and the two adjacent half hours. That's a pretty straight-forward logic puzzle for a 10-year old I'd have said. The rest of it isn't logic, it's lateral thinking.
In fact, you know what it needs? Splitting in half.
Question 1.
The clock strikes once.
Half an hour later it strikes once.
What time is it?
Question 2.
The OP's question as presented (only with 'once' explicitly stated each time).
[i]Then [/i]it's a logic puzzle, rather than what it is currently which is something dreamt up by a smartarse purely to make themselves feel superior to prepubescents.
They've used the word "again" to describe the 2nd -4th strike. So you look at how many strikes were described for the first strike to know how many strikes in 2nd-4th strike.
I'm certain that's the intention, but it's badly worded and open to misinterpretation.
It's the sort of thing that crops up as an image on Facebook - "80% OF PEOPPLE WILL GET THIS WRONG!!1!" sort of affair - and sparks a row running to tens of thousands of posts precisely because it's vague (probably deliberately to attract clickbait followers).
Definitely could be worded better but we don't know how much of that is down to the teacher, where the teacher copied it from or the OPs paraphrasing.
No paraphrasing - straight off the question paper
Risking making a fool of myself while trying to sound clever...
Won't the 12th chime of 12:00 be at 12:00:12? [u]One hour[/u] later means hearing the 2nd chime of 14:00 at 14:00:02 (with another 10 seconds until an hour has passed at 14:00:12)
She could have entered the house at 1am after a heavy night and, being blind drunk, fell straight asleep for 12 hours and then woke up at 12am just before the next set of chimes?
Or she could have entered her extremely large house at 1am and then went upstairs to go to sleep in a back bedroom that was a long way from the chiming clock, and only came downstairs again at 12am just before the next set of chimes.
Not many 'striking' clocks adjust themselves for daylight savings. Chiming maybe, but not striking.
If a daylight saving time adjusting striker appears in the answer I would want to know the model before accepting that was the answer.
Not many clocks strike once on each half hour either (usually quarter) but that doesn't actually prevent that being a *possible* answer.
The question is stupid, as Cougar says the middle bit is fine, but all the guff about coming in at the end of 12 and leaving halfway through 2 is bullsh*t. She must have the fastest shutting door, that is also amazingly soundproofed to not hear the 2nd chime at 2 o'clock.
It's the type of question that will put kids off maths and does no one any favours. We should be giving them confidence, while challenging their abilities, not trying to knock them down.
I hadn't realised that, thanks.
It's not a maths question. No mathematical calculations are required to get the answer, e.g. no addition, no subtraction, no division or no multiplication.
It could have some merit in computer programming. You could solve it with logic (AND/OR/IF etc) either. E.g if clock sounding when entering the house, ignore it and wait for ~30 mins. Note the number of chimes, wait ~30 mins again. If number of chimes noted the 1st and 2nd times are 1 then.....etc
I remember doing some AND/OR logic at school, probably in maths. However the beginning and end hamper this and there are probably much better questions for pure logic
With absolute logic:
If the scenario is that she heard a chime when she walked in the door she [b]couldn't[/b] have heard another chime half an hour later (note: not 'about' half an hour later) - for the clock to chime 12 times it must have taken a while and thus the time difference could only have been something like 29 minutes and 30 seconds, not the definitive 30 minutes stated in the question.
So its unsolvable.
I claim my chocolate digestive.
If we're going with pure logic....
I see the steps implied as
She's goes into her house. She is now within the house.
She opens the front door.
EDIT: There is a possible explanation. She entered the house by the back door then for some reason walked through the house and opened the front door. But then that messes with the door opening/closing cutting off the clock chimes..
EDIT2 Unless the back door cuts off the chimes...
Not a bad exercise in deductive reasoning, which is useful for debugging things. The usual conversation goes:
Them: We've got this error message
Me: That's caused by X
Them: But we've checked X and it's fine. This is impossible.
Me: Well it must not be, because you had the error message.
Them: But we've checked it
Me: Well, under what circumstances could X appear to be fine, but not actually be? Something else is indirectly causing X to not be fine.
Them: <go away to think about it>
Them: Yeah you were right, we thought about it and it was something that made X look ok but it wasn't.
There was no clock. Woman has tinnitus.
I would have went with scaredypants answer but...
The woman is a horologist and when she enters the house it's 'time to start work'. She then fixes the clock and when she leaves it's 'time to get paid'. It's only mentions the clock is working correctly after she left.
The correct answer is Google it, top hit (this topic being second) is for a document on a maths site with that very question in it, last page in the document has the answer.
She's studying Hora?
STW is great. I post a (badly constructed) maths question aimed at 10 year olds and get 48 responses and yet posts on Strava discrepancies and a new bike (albeit challenging the Brompton crown) received nothing whatsoever.
Oh well...
I'd definitely give the feedback to the teacher that it's not a maths question. It is, as some have mentioned, just the sort of question to put people off "maths".
The great and fundamental thing about maths is that you can use simple concepts to solve complex problems. No abstract thinking is required. This question goes against that.
She is deaf in one ear and only hears the chimes when her good ear is facing the clock.
By coincidence she manages to be facing the wrong way at the top of the next few hours, and so misses the full sets of chimes...
The correct answer is Google it, top hit (this topic being second) is for a document on a maths site with that very question in it, last page in the document has the answer...
... to the [b]puzzle[/b].
Parent of 3 boys, so threads like this genuinely capture my attention. Bromptons and Strava discrepancies don't. Sorry 🙂
Why not throw this maths question back at the maths teacher and report back on their answer (with workings if needed)?
Q1. As I was going to St. Ives,
I met a man with seven wives,
Each wife had seven sacks,
Each sack had seven cats,
Each cat had seven kits:
Kits, cats, sacks, and wives,
How many were there going to St. Ives?
I'd be asking the teacher to set some maths homework instead of brainteasers.
With absolute logic:If the scenario is that she heard a chime when she walked in the door she couldn't have heard another chime half an hour later (note: not 'about' half an hour later) - for the clock to chime 12 times it must have taken a while and thus the time difference could only have been something like 29 minutes and 30 seconds, not the definitive 30 minutes stated in the question.
So its unsolvable.
Ha...yes, this.
So you think you're clever eh Miss Maths teacher.
5 - Me and Ladypanther and the 3 panthercubs, but not for another 8 weeks.
Do I win five pounds?
Such a stupid question.
Are we to assume she can't hear the clock from outside the house if the door is shut?
Are we to assume that it is only striking once?
Are we to assume she has shut the door and that she can no longer hear the chimes once the door has shut?
And then there's stuff like daylight saving and the inaccurate "half an hour" later. Guess we're also to assume that the clock keeps accurate time.
The question is very poorly constructed. There is the obvious answer but there's probably a load of other answers given a different set of assumptions.
Unknown.
The usual answer is of course 1 one the basis that if you met him he must've been coming the other way i.e. away from St Ives. But you might've both met at a stop, or you might've overtaken him. Also, it's not clear if the man was actually with any of his wives - he might've been on his own simply being married to those wives, or he might've been with a few of them. Or anyone else. In fact, anyone could've been going to St Ives at the same speed as you but behind or in front of you. The only possible way to answer it is to contact the St Ives tourist information office and ask for typical visitor statistics to St Ives on that particular day. Plus, there's more than one place called St Ives. Then there are all the people who set off for St Ives but don't actually get there. For part of their journey they ARE going to St Ives, then they aren't. But they might still WANT to go, even if they end up on an AA truck to the nearest garage which might be in, say, Truro. So were they going to St Ives or Truro?
See, it's all bollocks.
GCSE maths exams include questions where no mathematical calculations are needed.
How many of what were going to St Ives? You know the person posing the question is going, but that's about it.
from looking at the answer then yes, she cannot hear the chime through the door or otherwise she would have to leg it down the path to avoid hearing the next chime after she had closed the door.
Not inconceivable with a grandfather clock, we have a damper on ours to keep it quieter than normal.
That would be [i]arithmetic[/i]. There is a little more to maths than that. 😀
I'm probably alone in
a) Liking the question
b) Enjoying working through it in my head
c) Feeling clever when reading that the first reply concurred with my thought
d) Not caring whether it's maths or not 🙂
with that many bongs, I'd have thought the clock struck 4:20
That would be arithmetic. There is a little more to maths than that
Well, first I put mathematical operations but that didn't seem the right terminology. You can add to that list that there is no algebraic substitution, no trigonometry, no calculus... but I thought these might be beyond the average 10 year old
Do you have an example?
EDIT: I've thought of one, algebraic substitution or rearranging. Perhaps my terminology wasn't the best.....
Overall, I'm trying to state that there is no maths in that question as I see it
Off the top of my head:
* Write 5674 in words
* Measure the length of this line: ________________
* Draw a 45 degree angle
* Construct an equilateral triangle with sides of 6cm
* Draw a rectangle which is 90mm by 35mm
* Name a 2D shape with 7 sides
* How many edges on a traingular pyramid?
Maths is a subject of absolutes and problems that can be solved with a set method. Now correct me if I'm wrong but you can't solve a formula with more than one variable. In the given scenario, who knows how many variables there are?
As I said, unsolvable and as others have said not appropriate for building confidence.
We'd need to know the context in which the question was set, and something about the teacher and the class. Perhaps the teacher sets a 'tricky' lateral thinking question each week?
Presumably you mean 'equation' not formula.. and you solve whatever problem the question asks, number of variables not an issue 🙂
GCSE maths exams include questions where no mathematical calculations are needed.Do you have an example?
Here no abstract thinking is required and answers are absolute. Also, apart from the first and last two, you can test your answer to confirm it's right.
Which wasn't your original definition? No calculations are required in those examples...
It's also why we need the context in which the OP's question was set. If it was "here's a maths question:", then it's a stupid question to be setting. If it's "here's a tricky/fun problem to solve:" then there's no issue.
Are those genuinely GCSE level questions? If so, exams certainly have been made easier over the years!!Off the top of my head:
Yes.
GCSEs assesses every student, from a G grade upwards. These are very early questions in the Foundation (G to C) paper, designed to tell whether a student is a U, a G, or an F grade.
The questions on the Higher paper to distinguish between an A grade and an A* are slightly trickier.
There are n sweets in a bag.
6 of the sweets are orange.
The rest of the sweets are yellow.
Hannah takes at random a sweet from the bag.
She eats the sweet.
Hannah then takes at random another sweet from the bag.
She eats the sweet.
The probability that Hannah eats two orange sweets is 1/3.(a) Show that n^2 – n – 90 = 0
(b) Solve n^2 – n – 90 = 0 to find the value of n
Fair enough, that makes sense. Maths was never my strong point at school (20+ years ago) and I was thinking I probably would have been ok with that level of questions!GCSEs assesses every student, from a G grade upwards. These are very early questions in the Foundation (G to C) paper, designed to tell whether a student is a U, a G, or an F grade.
Yes....we seem in agreement. It's not a maths question. I expanded on my 'definition' too if you follow through the posts 😀
molgrips
How does that work?
v = u+at
u=1 a=5
Find v
Or should I have specified unknown variables? And yes, equation.
