Looking to get some extra black rubber bands, the "heavy duty" ones, that come with cheaper bike computers, cadence sensors etc.
Had a look on ebay but they don't seem to have them.
Any suggestions?
do you mean o-rings?
They are generally measured by inner diameter & thickness, so you might need to do some measuring up of what you need.
ebay:
or it might be easier to search a 'proper' shop:
Like [url= https://www.amazon.co.uk/Pieces-Stretch-Headlight-Headlamp-Bicycle/dp/B071D671Z1/ref=sr_1_8?dchild=1&keywords=Amostik&qid=1601980301&sr=8-8 ]THIS [/url]
or
[url= https://buy.garmin.com/en-GB/GB/p/65216 ]This[/url] ?
Many thanks!
O rings might be the best solution.
I cut a slice through an old inner tube, whatever width you need. You can alter the diameter a bit by cutting diagonally.
@gobuchul If its the O-rings as used for the Garmin mount you're after, I may have some I can pop in the post.
Post up on here if they are and I'll have a look tonight
Carlos
@carlos - thanks for the kind offer. But it's for something a little bigger.
Might try that inner tube idea, I have a job lot of 26" tubes that are sitting in a box still.
You want to search for silicone o-rings, not rubber o-rings to find the right thing.
