Heat pump tumble dr...
[Closed] Heat pump tumble dryer anyone?
8 Users
 tang
Could be tumble dryer time here(there's a back story too boring to type). What say you to these heat pump A rated things?? Anyone got one?
Posted : 17/09/2013 7:47 pm
Yeah we do. Beko Dry&Save (DPU 8360 W) 8kg load, A rated.
http://www.beko.co.uk/Item/DPU8360?col=&route=/BekoRange/Category-Laundry/Type-Tumble%20Dryers/
I really rate it. Expensive up front but I did the sums and reckoned it would pay off the difference compared to a "normal" drier in two to three years.
Good things: big load, large door, fairly quiet, knows how long it has to go, easy access to filters, little light inside, easy controls, time delay and anti-crease, outflow can easily be plumbed in to save emptying the water tank all the time.
Bad things: dust/lint filters need emptying all the time.
Posted : 17/09/2013 9:25 pm
 tang
Thanks Graham, was looking at beko.
Posted : 17/09/2013 9:50 pm
Have had a Bosch one for a couple of years. Works fine. Takes a full machine's washing. Haven't had to clean any filters. Does weigh about 1 million kg though. Our builders carried it down to the cellar, and I'm not sure anyone will be able to get it out.
Posted : 17/09/2013 9:53 pm
In a couple of years?? How? Where does the lint go? 😕
The beko one has reminder lights to clean the filters but basically it is the pre-filter every couple of cycles and the main filter every six or so. Fortunately it is a very quick job as the pre-filter just lifts out and the main filter has a nice turn handle that makes you feel like you are installing a new CO2 scrubber on the space station 😀
Posted : 17/09/2013 10:19 pm
You always have to clear the filters all the time on tumble driers!
Posted : 18/09/2013 7:13 am
When I was re-installing mine I found the air leak all around the back panel that had been filling the kitchen with grey dust. It's now very much improved (gaffer tape)
Posted : 18/09/2013 7:23 am
Never heard of these - I'll be paying attention as MrsSB does like to use the drier quite a lot!
Posted : 18/09/2013 7:57 am
It wasn't so bad on our previous one which was an absolutely ancient tumble drier (e.g. controls were on or off). That one was vented and didn't really have a filter so it just blew all the lint out the vent hose 😕
But yeah I think [i]most[/i] modern condensing driers you'll have to empty the filter pretty regularly, so I'm intrigued by sl2000's Bosch.
Posted : 18/09/2013 8:34 am
Ahem - clearly it's just my wife that uses it 😳
So yes, it does have a lint filter in the door which you need to empty after every load. I'd forgotten about that in my excitement at it having a self-cleaning condensor.
Posted : 18/09/2013 3:08 pm
LOL - aaaahhh so the lint is taken care of by the same laundry fairies that convert the smouldering heaps of minging cycling gear into fresh neatly folded kit in a drawer?
Isn't technology wonderful these days 😀
Posted : 18/09/2013 3:55 pm
Condenser driers = great
Beko = make sure that you have a fire extinguisher and your insurance is up to date and you and your family are fire-proof.
Posted : 18/09/2013 4:52 pm
