So when does a headache become a cause for concern? When you're woken at 4:30am with a sharp pain in the right hand side of your head that doesnt go away with cocodamol and gets worse when you lie down, makes you feel sick for a short period of time and means all you can do is walk the streets for an hour watching the world wake up, and is still there mildly at lunch?
If it's going I wouldn't be panicking.
Early lunch?
History of migraines? Change in personal circumstances (ie new glasses prescription recently?)
A few hours then and your mobile, no cause concern just yet any other symptoms?
Had 2 migraines in my life, none recently. Rarely get a headache unless I leave it too long for food, then I get a headache and a stiff neck. When I was younger (5 years+ ago) I used to get really REALLY sharp stabbing pains in my skull, in the same location each time, but not in this location and they only lasted 2 mins.
No recent changes in circumstance, no recent injuries/head impact. Feels like it's eminating from above my right hand side of my upper jaw, behind the temple. Feel like my right eye is a tad "slow" focusing but I get that when it's tired anyway so probably unrelated!
Any recent toothache? Any visits to NZ to relax in nice natural hot springs?
If it is going and then it's gone, I would suspend worrying about it.
If it happens again, I'd go see the ducknoise. 😉
I had a sudden unexpected headache like that. Went to the doctors and the next day they put me in one of those massive CT scanning machine thingummies.
After which they told me to go home and not worry.
EDIT: Talk to a doctor. Could be serious.
Yeah sounds like it could be teeth related - still have wisdom teeth? Are you grinding them in your sleep?
caffeine withdrawal?
No toothaches, do sometimes grind teeth but usually my front ones (oddly!). Unfortunately no NZ visits! I'll suspend worry for now. If I'm found dead in a hedge with a massive brain hemorrhage I'll wave my finger about in here!
LOL - I thought that too 😆
Might be a cluster headache.
See if it comes again, same place.
I think brain tumours come with other symptoms - phantom smells, odd behaviour, visual effects etc. Watch out for those. Except be careful with the phantom smells one because every time you smell something unusual you'll get worried, then walk around the corner and find a perfectly reasonable explanation for it 🙂
😀 Shouldn't be caffeine withdrawal, I've loads handy!
No phantom smells, I do keep thinking I see things moving in my peripheral vision but I'm not sure if that's related.
FFS go see your GP or drop in centre?
Could be, CK.
When i am suffering with headache.i drink one cup of hard Coffee it give me relax and remove my headache.
[baleeted - mod]
@remodiyaz - that looks like an advert you've dropped in there.
You're probably in violation of the forum rules with that unless it's somehow relevant to headaches.
Alternatively, you could just shave and get the cool, revitalising cut that you only get from a Braun 790.
Wouldn't have thought cluster headache with sick feeling although being on one side and lying down making it worse fits in
Would expect it to affect one eye too,watering/getting droopy and possibly get a runny nose as well
Wouldn't think it would last that long either and the pain is very very severe, like being stabbed through the eye with a hot blade.
Having suffered for a few years with Acute Cluster Headaches you get to know a bit about it
Could try a go at Imigran from the chemist especially if painkillers don't work
Sounds like migraine of some description, but worth mentioning to the doctor I would have thought
Mrs North suffers from cluster ehadaches, though without the watery/droopy eye bit.
She too has had her head scanned, and was found to have a brain. Which was not waht I had expected.. 😉
Wisdom teeth shifting/coming through? Got mine age 30 odd and had horrendous headaches.
If you see things moving in your peripheral vision it's just fairies and nothing to worry about. When you start seeing Unicorns and Gryphons that's when you need to worry.
Sounds like migraines I get sometimes. Make sure you drink lots of fluids too and if/when you get one again you might try cold or warm compresses on the temple. If they reoccur often definitely a doctor because if nothing else they can get you the better drugs (the legal way).
Daresay she already knows this, but just in case
Sumitriptan is very effective for relieving migraines and fortunately cluster headache too
If you suffer frequently the nasal spray works quicker than tablets
I also have it to self-inject from an epi-pen type device which is the fastest way to get it in the system
If you get a bad bout a short high dose course of steroids works too, 60mg prednisolone a day for five days
Loads of possible preventative cures, these are usually very powerful drugs with side effects such as Lithium
One I had some success with was Gabapentin, worth a try because it seems to have less unpleasant side effects than most
Hope she doesn't suffer too much with them and give her some sympathy, very nasty condition and you wouldn't believe how much they hurt
