Gymnastics rings
[Closed] Gymnastics rings
16 Users
Looking at reviews there seem to be a number of decent sets of gymnastics rings out there that have issues with their strap buckles; does anyone have a set they'd recommend/any to avoid?
It seems wooden rings are the way to go, unless anyone knows different.
Posted : 01/08/2017 11:55 am
Ive got these and they are fine
https://www.amazon.co.uk/Pellor-Gymnastic-Bodyweight-Excercising-Suspension/dp/B005EER2VC/ref=sr_1_4?s=sports&ie=UTF8&qid=1501588827&sr=1-4&keywords=pellor+rings
not mastered that iron cross yet though!
Posted : 01/08/2017 12:01 pm
Yep, I've got those rings, no problems with the straps at all - 80kg ish BW.
inverted Iron Cross is where it's at now...
Posted : 01/08/2017 12:06 pm
Cheers gents, purchased.
Let the frustration begin :mrgreen:
Posted : 01/08/2017 12:38 pm
A friend has had good progress with GMBs Rings One course...
https://gmb.io/r1/
The main pic at the top of that page is a local GMB trainer at a Crossfit box in Milton, Cambridge. She's demoing a 45 degree RTOH (rings turned out hold) which is quite challenging for something so simple.
Posted : 01/08/2017 12:45 pm
what do you use to mount the rings at home?
Posted : 01/08/2017 1:26 pm
mine are looped over an RSJ in the workshop
[url= https://farm5.staticflickr.com/4127/35579357051_ce1f1d71aa.jp g" target="_blank">https://farm5.staticflickr.com/4127/35579357051_ce1f1d71aa.jp g"/> [/img][/url][url= https://flic.kr/p/Wd2vhx ]Workshop[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Posted : 01/08/2017 1:39 pm
Get ready to feel very, very cumbersome.
Posted : 01/08/2017 2:44 pm
mine are looped over an RSJ in the [s]workshop[/s] sex dungeon
Posted : 01/08/2017 2:46 pm
I've had to stop using them after tearing my Pec doing Bulgarian Ring dips (Gymnastic Bodies Foundation Course, Hollow Back Press progressions). Waiting for it to heal...
Posted : 01/08/2017 2:55 pm
@footflaps = jealous...
Posted : 01/08/2017 3:02 pm
I'm moving in with footflaps
Posted : 01/08/2017 5:16 pm
I've been told I snore, is that a problem?
Posted : 01/08/2017 5:17 pm
I made my own with some plastic pipe, sand and a hot oven.
Posted : 01/08/2017 5:21 pm
Brave man, I wouldn't fancy going upside down on home made rings...
Posted : 01/08/2017 5:22 pm
I snore so that's a match.
Posted : 01/08/2017 5:45 pm
I think we should all head to Footflap's place for an STW powerlifting meet. I take it there's a bench tucked away somewhere...
Posted : 01/08/2017 6:35 pm
Had mine a couple of months and just nailed the muscle up, trying to get it more strict so no momentum from pulling up fast, slow and controlled is the goal.
Slowly and carefully training for the iron cross as well, a couple of years is what i'm thinking at the moment.
If anyone is interested my antics are on Instagram @fiftyplusfit
Posted : 01/08/2017 6:58 pm
It's in the photo, up on the cupboard at the back..
Posted : 01/08/2017 7:44 pm
I've the same rings over a beam in the garage. Not used them yet as the new place as too lazy to get the van out the way first! Main thing is too loop the strap through the buckle the right way, you'll quickly work it out!
Does anyone have any programme suggestions as I'm a bit out of practice and p20 is also planning giving it a go?
Posted : 01/08/2017 7:51 pm
Look up GMB Rings 1 course (linked above somewhere). Well worth the $95 or whatever it is.
Posted : 01/08/2017 7:56 pm
 Earl
twinw4ll - that's epic.
Posted : 01/08/2017 9:30 pm
footflaps, how bad a tear? Just a bit of bruising or serious tissue damage? Mine was torn back in 2002 bench pressing and it's never been the same since, I only use dumbells now.
Posted : 02/08/2017 6:24 am
Don't get plastic rings, I got a wooden set from China off ebay. I weight 92kg and have done me perfectly well and were only £15
Posted : 02/08/2017 7:23 am
ff, well they are hollow so the strap goes right through them and actually carries the load.
Posted : 02/08/2017 8:15 am
Grade 1 (lowest) level of tear according to Physio, will heal in a few weeks. It's at the attachment point where the Pec joins the humerus, which apparently is good (no idea why).
Posted : 02/08/2017 10:25 am
Lo STW scores another niche point, I had no idea home gym rings were even a thing, let alone several on here have them
Posted : 02/08/2017 10:48 am
Heh
Yeah, they're excellent when set up correctly, lethal when not. I have mine wrapped over a pull-up bar/cage thing I made out of box section steel and an old squat rack.
Posted : 02/08/2017 10:54 am
Footflaps do you deadhang? i've found it awesome for building strength, i do it for around 5 minutes total a day. Fixed my dodgy shoulder as well.
Posted : 02/08/2017 1:16 pm
Not specifically, however some of my core exercises (GB Foundation series) do involve a lot of hanging off Stall bars. This is my current Core workout, 5 rounds of
Doing this 2 or 3 times a week at the moment, building up to 5 sets of 5-10 reps of each exercise, ideally with 'perfect' form. First exercise (negative body levers) I need to pike less (have got better since this vid), 2nd one is pretty decent form. 3rd one is crap as my hamstring flexibility is terrible so can't hang with straight arms and then lift my legs to my hands, so I'm doing too much work with lats.
Posted : 02/08/2017 1:41 pm
Inspiring; I gotta add Eye Of The Tiger to my workout playlist...
Posted : 02/08/2017 2:16 pm
