Ground Anchor-esk t...
[Closed] Ground Anchor-esk thing for bikes in a Van?
5 Users
I need some way of securing my bikes in my van to make it an arse for them to get robbed. whats the best port of call?
Posted : 02/05/2011 9:41 pm
on the ground anchor theme...
i put one in , then knocked the ball bearing into the socket of the bolt so that it could not be easily removed...How do i get it out again???
Posted : 02/05/2011 9:45 pm
I use a cable threaded round the framework, luckily I was too lazy to line it.
Posted : 02/05/2011 9:49 pm
alex - bolt up type ground anchor bolted to as strong / reinforced part of the floor? Weld up the bolts to prevent them beoing undone
Charlie - cut the heads off with a grinder?
Posted : 02/05/2011 9:52 pm
really? Grinder is the only way??
Posted : 02/05/2011 9:54 pm
 Ewan
I think that's the point isn't it!
Posted : 02/05/2011 9:56 pm
just done a search and found a torc ground anchor with a van kit for £60 ish- sounds like what I need however its surely down to the weakest link - whats the cheapest chain / cable I can get away using without making my ground anchor efforts pointless!?
Posted : 02/05/2011 10:06 pm
