GPS folk
[Closed] GPS folk
12 Users
Looking for a bit of clarity - I am comparing chalk and cheese with the various map inclusions of different GPS manufacturers.
This is a schools project. I have need of 45 units initially, with associated mapping at 1:25000 of certain areas local to each school. Ideally it is a buy it once, not a yearly payment. Ideally OS maps at 1:25,000.
It seems (but I may be wrong!)
Memory Map do educational stuff, funnily enough the thing we need is the yearly payment really...at £350 for 25 yearly licences at 1:25,000.
Garmin don't do an educational deal, instead you buy a unit with 1:50k on and pay £20 per unit for a small local tile of map at 1:25000.
Satmap - noooo idea, and they haven't got a phone number or respond to emails.
So a Garmin Dakota 10 would be the cheapest way to do this, by a long way...?
Suggestions or thoughts please!
Posted : 25/09/2013 3:57 pm
compass and OS map so they learn a proper life skill!
Posted : 25/09/2013 4:01 pm
We already do that - this is life skilz II
Posted : 25/09/2013 5:04 pm
No map or GPS, dropped off in the middle of nowhere to navigate home - much betterer
Posted : 25/09/2013 5:06 pm
Have you looked at Viewranger? I have no idea what, if any, educational packages they offer, but worth a look.
Posted : 25/09/2013 5:08 pm
I'd have thought that learning to use modern technology is a much more useful life skill than being lost and then walking home via the chippy.
OP - Viewranger could be cheap. Smartphone rather than dedicated GPS but OS maps 1:25000 can be purchased oughtright by the tile so you only need the area you are after.
Posted : 25/09/2013 5:09 pm
Open source mapping? Got an Etrex 30, with OSM running on it but not sure if it meets your needs. I assume educational is fine under an open source licence?
Posted : 25/09/2013 5:24 pm
Do you really need OS maps?
I'd go with OSM on the most basic etrex which will take them.
Can you put MM mapping on Garmins? Not sure you can.
Edit: What Tom said
Posted : 25/09/2013 6:30 pm
OS is what 'paper' maps they are seeing and using. It seems to make sense to keep that going, and then lead into DofE etc later.
I am not sure smartphone stuff would work - I can see prank calls and such happening...
We also need this to be as geek-less as possible. This is because staff are not experts, and frankly my phone now v navigates me simply and easily, so should a gps...
Posted : 25/09/2013 6:35 pm
I'd also question 25k mapping over 50k tbh.
The OS do the MM 2800 with 50k mapping for £180 which seems reasonable.
BUT IME the MM hardware and software ( based on windows CE) always feels a bit unfinished.
Posted : 25/09/2013 6:43 pm
No SIM and lock down the phone into 'kiosk' mode with a suitable app, that only allows access to the permitted app(s). Shouldn't be too geeky to use once set up and locked down. Although I can see smart phones more likely to 'go missing' than a dedicated GPS device.
Posted : 25/09/2013 7:15 pm
They are not in the wilds, and only using relatively small areas (e.g. Holyrood park).
Posted : 25/09/2013 7:24 pm
1:50k is good enough for the guys at Glenmore Lodge and I've never seem any reason to doubt them. Dakotas are "end-of-life" now so beware of a big commitment.
Posted : 25/09/2013 11:03 pm
Satmap have a new model coming out soon, and recently they were doing good prices on A10s. They also have a facebook page you could try contacting them through - they do seem to be missing a phone number on their site.
But I would favor a simple GPS showing coordinates that they have to use in conjunction with a real map so they learn a bit more about map reading - this is a school after all, and having a full blown mapping GPS is not really teaching them much, apart from maybe spatial awareness. Phone apps would be good enough to give a display of coordinates.
Posted : 26/09/2013 4:49 am
So - any decisions?
Posted : 26/09/2013 8:36 pm
I had the Dakota 10 model you've been looking at a few years ago. They're a good little unit, and the ideal size to stick on your handlebars, but for walking/orienteering, etc the screen is too small. You can't see a large enough area of map on the screen.
I upgraded to one of the Oregon models, which has much the same features, but the screen is a much more useful size.
Posted : 26/09/2013 8:54 pm
scotroutes - Member
Depends where you are. In Scotland I use 1:50k, but in the South of the UK 1:25K makes life a lot easier.
Posted : 26/09/2013 8:58 pm
