Getting rid of old ...
[Closed] Getting rid of old IT gear - how/who?
5 Users
Time's moved on and I've got some old IT kit that is just getting in the way*
What the best/easiest way of disposing of it?
* 3 Dell Poweredge rackmount servers, a few CRT monitors, tape drives, etc?
Posted : 02/12/2015 4:46 pm
Drill through the hard drives, drop off at local council recycling depot (also known as the tip).
Posted : 02/12/2015 4:53 pm
Freecycle will likely take most of the stuff away if that's an option, but destroying the drives is sensible.
Posted : 02/12/2015 4:58 pm
Drill through the top of the HDD and squirt in expanding foam or mastic. Or, if you have access to it, use an oxy/acetylene torch on them. Or shred them.
Posted : 02/12/2015 5:16 pm
Or, rather than getting paranoid about a load of shit that is probably ancient history anyway, run DBAN through it for a few passes and let someone else get the use of the drives.
As said, Freecycle or Gumtree will likely get the, shifted, tip will take it or a computer charity if you have no luck.
Posted : 02/12/2015 5:56 pm
