General sparky Q - ...
[Closed] General sparky Q - specifically washing machine...
5 Users
The mother-in-law has roped me into fitting her replacement washing machine. Basic question is: is it for any reason inherently a bad idea to remove the plug that comes attached to the washing machine and replace it with a new third-party one assuming I put the same rated fuse in?
It's basically for a boring (fairly unavoidable unless I attempt kitchen cabinet surgery which she's not keen on) reason in order to be able to just replace old-for-new machines directly.
TIA for any help.
Posted : 30/05/2012 6:39 pm
A plug is just a way of connecting it, I can't see any issues.
Posted : 30/05/2012 6:43 pm
Only issue I can see is if you're a ham-fisted doof who can't wire a plug safely.
Posted : 30/05/2012 7:25 pm
Thanks for the vote of confidence mate 😉
Reckon I can handle wiring a plug - you just sellotape the wires to the outside of the case right??
(Thanks both)
Posted : 30/05/2012 7:27 pm
It might be easier (and free) to detach the other end of the lead where it secures to the terminals in the washing machine, feed cable through hole, and reconnect.
Posted : 30/05/2012 7:28 pm
Ah, I wasn't suggesting you were, just that that's the only issue I can see.
Posted : 30/05/2012 7:29 pm
You never know - I *am* asking for electrical help on a cycling forum after all 😯
Thanks again, and Tucker - that sounds like an interesting option, will see if that fills me with any confidence when I see the new machine.
Posted : 30/05/2012 7:34 pm
I remember as a kid several (rarely used) appliances in our house that were missing plugs, old man used to line the wires up and shove a plug in over the top of them!! 😯
Posted : 30/05/2012 7:56 pm
