Gas or induction ho...
Gas or induction hob?
52 Users
66 Reactions
Need a new hob. Currently it’s gas but my other half has decided she wants an induction hob instead?
never used one, is this a good idea?
Posted : 31/08/2024 4:51 pm
I love gas, and if you use a wok, there is no alternative.
Posted : 31/08/2024 4:55 pm
Tricky question, I have a fairly bog standard, and old gas oven/hob... which works fine but could maybe do with replacing at some point.
I'm mostly concerned with efficiency, but also you might need new pans if going induction depending on what you already have... that said if your current collection of pans are a bit old/crappy then not such a big deal.
I do like gas hobs though, so much control and heat up really quick.
Posted : 31/08/2024 4:57 pm
RichPenny and RichPenny reacted
Induction - cleaner, and just as fast to heat. If not faster.
Posted : 31/08/2024 5:01 pm
dhague, robertajobb, ads678 and 7 people reacted
I feel suitably qualified to answer this.
Old house we had a 5 ring Bosch gas hob, with a massive middle ring for the wok.
New house we have a 4 ring Electrolux induction hob.
Overall for everything apart from stir frys I'm an induction convert. I was sceptical but the benefits are,....
* quicker boiling times, we no longer have an electric kettle as a traditional kettle on the induction is quicker
* Better fine control of temperature and no hot spots. Whack the temperature down to 3 and let the Bolognese slow cook for hours no worries.
* Quicker and easier to clean
One thing I would say, ours has a control for each hob or zone. My mum and dad's you have to select the zone then set the temperature, which I find really annoying.
As I say the only downside is the use of a wok or if you want to flambé. I dare say buying a newer and less wonky wok would solve the former problem.
Edit: When we re-do the kitchen I'm looking at getting a stand alone gas hob specifically for woks.
Posted : 31/08/2024 5:04 pm
Induction – cleaner, and just as fast to heat. If not faster.
That's a point.. my extractor isnt the best, but with induction you're only really worried about humidity and food smells rather than whatever fumes left over from burning gas.
Posted : 31/08/2024 5:06 pm
steveb and steveb reacted
I’ve just done this swap.  I wouldn’t go back to gas.
That said, I found that 50% of my pans just don’t work properly so they’ve gone to school for the mud kitchen. Cheap frying pans being the worst offenders - it’ll detect them and power them up, but nowhere near as well as a good pan.
I use a carbon steel wok and it works just fine. You can get induction wok holders if necessary.
Research the induction system carefully: cheap units just cycle the inductor on and off to keep the pan vaguely the right temp. More expensive ones actually vary the power delivered.  I spent an absolute fortune on mine and it’s mint (the rest of the kitchen being “free” thanks to a generous flood). I found out after delivery that it would actually take three phase which was annoying having just run a 32A single phase across from our three phase board. It’d be even more wickedly powerful on that. Get an induction kettle. Boiling a mug full of water takes less than 30s. It’s astonishing.
Edit: strangely Snowinn sell really good pans from tefal and others very cheaply.
Posted : 31/08/2024 5:07 pm
dc1988, RichPenny, RichPenny and 1 people reacted
One thing I would say, ours has a control for each hob or zone. My mum and dad’s you have to select the zone then set the temperature, which I find really annoying.
Mine has that, and I really can't say I've ever found it even vaguely annoying. One touch to select the area, then select the heat. No fuss.
One thing I would warn about: we redid the kitchen last year, and got a fancy white induction hob. I had my doubts, but it does look fantastic... at the moment.  But it's now got a couple of (admittedly small) scratches, and I do wonder about what it's going to look like in 5-10 years time. Heart (and wife) won out over head, but I probably should have got a normal black hob.
Posted : 31/08/2024 5:53 pm
zomg and zomg reacted
Induction is great. Buy a 32A one
Posted : 31/08/2024 5:58 pm
Love our induction hob, under 10 seconds to clean and can put stuff on timer and also has a child lock.
Posted : 31/08/2024 5:59 pm
My in-laws have it. If they were all like that I'd be using gas it's infuriating. When we did the kitchen we made sure we had 4 separate controllers
Posted : 31/08/2024 6:12 pm
jeffl and jeffl reacted
I absolutely love cooking on gas, loved the feel of it.
Then we went induction and I would never go back. Induction all the way.
My only caveat is get one with proper turny knobs. None of that touch panel nonsense, although mine has both I never used the panel
Posted : 31/08/2024 6:32 pm
 mrmo
Something to think about, the move to heat pumps and the phasing out of gas heating. I have no idea of your overall situation how long you intend to keep the kitchen etc. but you might find you're paying for gas jstanding charges etc ust for cooking
Posted : 31/08/2024 6:45 pm
hightensionline, RichPenny, ChrisL and 5 people reacted
Thanks everyone, the gas pipe actually runs down the outside wall so that would be one benefit if we could remove it.
just don’t want to make a costly mistake!
can you use le creuset style pans on them?
I can't confirm le creuset but we have a tesco copy that works fine We didn't have to buy any new pans for induction
Posted : 31/08/2024 6:51 pm
Another induction vote, but get a good powerful model that needs the 32A feed.
For stirfrys, just about everything else I cook, a flat bottomed saute pan is the go to.
Also something else I mention on induction threads, is frying pans etc that have the perforated stainless steel plate forged on to the aluminium do not absorb as much energy as pans with continuous SS bases. Probably about 60-70% of the energy. The input power to the hob reflects this with perf base pans.
Posted : 31/08/2024 6:53 pm
All my cast iron pans and the Dutch oven all work on mine.
I'm all for the touch though they just have to be individual touchs. Makes for easy cleaning.
Posted : 31/08/2024 6:54 pm
Few thing that I will look for in the next induction hob
All Flexizones not rings, so you can just dump a pan/pot anywhere
Takes any size pan/pot (my samsung is a bit fussy where you place a little moka pot). You def need to check min pan size, a milk pan might be too small for some hobs.
Individual controls for individual zones (I thought I’d get used to one control to switch between zones but still haven’t)
Decent fine control, mine has 15 settings + P, so 16, which is adequate. Not essential but would be nice to have the removable magnetic knob option but TBH I don’t have a problem with digital touch controls.
Posted : 31/08/2024 6:55 pm
dhague and dhague reacted
Yes. Just don't slide them across the surface
Posted : 31/08/2024 6:56 pm
Stove top coffee maker ie espresso can be problematic. We have a stainless one, it works but has to be positioned correctly as it is quite small in diameter
Posted : 31/08/2024 7:02 pm
Induction: fast, responsive, easy clean, safe and doesn't fill your kitchen with toxic fumes.
Posted : 31/08/2024 7:10 pm
We have both -  the gas is more powerful but it is still less used than induction side.
 ji
induction wok plates exist - slightly curved inwards to match the shape of the wok
Posted : 31/08/2024 7:14 pm
They vary quite a lot - we had one that was a complete pain to use, now we have another that's fine. Of course both were sold as "induction ready", you won't know if yours is good or not until you buy it...
Posted : 31/08/2024 7:20 pm
We moved into a new house with an induction hob - I’d 100% go back to gas.
damn induction thing turns off if you get anything near the controls.
Do they do induction hobs with physical knobs!!?
And cost in new pans if your current ones aren’t compatible. Our really nice copper bottom ones are now struck in the attic.
Posted : 31/08/2024 7:23 pm
My only concern with our induction hob is the tendency of SWMBO to leave the knobs switched on. Which has resulted in the burning of various items subsequently left on the cooker top by the same person. The cooking of an iPad was a highlight.
Posted : 31/08/2024 7:32 pm
 gray
That's maybe one benefit to the no-knob variants then. With ours if you remove the pan, then 30s or so later, that 'ring' turns itself off automatically.
Ideally I'd like knobs, but ours is on an islandy bit (actually a peninsular but that sounds even more daft for a kitchen) with a breakfast bar, so the flat surface is nice. I find the touch controls fine once used to them, and it really very easy to clean.
Good ones really aren't cheap, but I'd definitely rather not go back to gas.
Posted : 31/08/2024 7:43 pm
Gas.  My current flat has electric stove but I missed gas cooking.
Gas stove is easy to use and not have to think about the pot or pan compliance.
I have a round bottom wok (proper wok) that I never got to use it, so invested in several flat bottom woks which is not as efficient.
Posted : 31/08/2024 7:49 pm
Every time I clean our 6 burner gas hob (not that often TBF) I wish we had induction
The ignition on half the rings doesn't work either
Induction next time for sure
Posted : 31/08/2024 7:57 pm
Depends how clumsy your household is. Our induction hob shattered when a glass spice jar fell out of the cupboard above the hob.
Posted : 31/08/2024 8:02 pm
The ignition on half the rings doesn’t work either
Cleaning?  Shouldn't you be wiping off whatever after cooking?  We clean the stove every few days or as often as needed.
Yes, the UK gas stove ignition is rather troublesome if you don't clean them often. We never had that problem in the far east because use a separate igniter.   Our gas stove is simple or basic and nothing fancy, hence nothing will go wrong and will last for a very long time.
Posted : 31/08/2024 8:17 pm
Where is your extractor ? Bora  Downdraft -those are silly money.
Posted : 31/08/2024 8:42 pm
Grew up with gas, have an induction now as no mains gas here
I prefer gas, just much nicer to use.
Only advantages of an induction for me are easy to clean, and I have a very small kitchen so an extra bit of flat surface is nice, but for actually cooking I prefer the gas
Also, if you do go for induction avoid those stupid touch controls, I absolutely hate mine, get proper knobs. They adjust themselves if you just brush against them with anything, and the worst one I had was a pan boiled over, the water got onto and turned everything up maximum! A solution to a problem which didn't exist, get knobs!
Posted : 31/08/2024 9:37 pm
100% induction. Worth it just for the ease of cleanup. Boils water faster. Touch controls suck but at the same time I'd take them over physical ones for the ease of cleaning. It needs to be the proper 32A like others have said so you get the turbo boil.
Posted : 31/08/2024 9:43 pm
Could people name and shame the induction hobs that manage to fry phones, turn everything up to max when wet, have unreliable touch controls or whatever other failing.
I've got a cheap FAR. It's never done anything it's not programmed to do. The touch controls have been faultless. I couldn't fry my phone without placing it on the hob then going through a sequence of three touch commands  - on, select zone, select power level. I've got a few old pans that aren't induction specific but if they're iron or steel they work fine.
Posted : 31/08/2024 9:48 pm
thebunk, hot_fiat, thebunk and 1 people reacted
How does it work with an combined oven/hob unit though... gas oven is nice as it preheats really quick.. electric ovens take days to warm up?
Posted : 31/08/2024 9:50 pm
I had a built in Miele which was slow to warm up, consumed lots of leccy and did a better job of heating the kitchen than the food. It clearly lacked insulation. Replaced with a Rowenta which does a pizza in 17min from switch on for me and 24min for Madame who insists on a longer 14min preheat whereas I use 8/9min preheat.
Posted : 31/08/2024 9:57 pm
Knobs suck if your hobs doing anything other than defaulting to off (which our aeg does) when you boil over....it's wrong.
Posted : 31/08/2024 10:04 pm
doesn’t fill your kitchen with toxic fumes.
We got rid of gas for this reason.
Posted : 31/08/2024 10:05 pm
If the pans are magnetic on the bottom they will work on an induction hob. Mine turns itself off when you remove the pans after a few seconds and is only hot for a minute or two after.
Posted : 31/08/2024 10:06 pm
gas oven is nice
Are you living in some 70s time warp? I've not seen a gas oven for...30+ years!
Posted : 31/08/2024 10:19 pm
We have both. I'd say induction is better in every way apart from cooking. Does make for a tricky comparison but as cooking is the important bit then gas wins.
Posted : 31/08/2024 10:21 pm
 rsl1
I love how fast a response you get from induction. Pan boils in no time, but then turn it down and it instantly goes to a simmer without boiling over. The only downside I've found is that my carbon steel wok doesn't seem to heat through nicely and instead burns the stuff on the bottom, contrary to an earlier poster.
Posted : 31/08/2024 11:16 pm
b33k34 and b33k34 reacted
I would never go back to gas. Induction all the way, for the cleaning alone. And you can still use a wok.
Posted : 01/09/2024 12:12 am
I hate to say but the way things are going with gas pricing, it might be a better investment to get a quality induction hob.
Posted : 01/09/2024 12:50 am
We changed from gas to induction, 15, maybe 20 years ago, as part of re-doing rhe kitchen.
Absolutely no question we're on an induction again when it finally needs renewal (ours is a Di Dietrich).  Just faster, more controllable, and cleaner to use and keep clean.  + no Carbon monoxide risk either, and less condensation (only steam from whats cooking, no steam / condensation from the act of burning the gas itself).
We've got a cast iron Wok thst works well enough on it (I do take the point that a thinner carbon steel wok may  get hotter on gas).
The pans thst won't work are those made fully of aluminium, or with a 100% copper base.  Many newer pans have a steel plate let in them to work on induction if they are alu or similar  (the pans need to be magnetic.  18/8 Austenitic stainless steel is also fine (some other grades of SS are not so magnetic)
Posted : 01/09/2024 1:01 am
Having come from an excellent gas hob to a mid range induction hob the only downside is the slightly annoying touch controls.  We still sometimes turn the whole lot off accidentally. And turning a "ring" off means counting down to zero.  An annoying waste of 2 seconds.
Most of our old pans either worked fine or didn't work at all. But one, our lovely le creuset griddle pan, works at about 80% efficiency so doesn't get hot enough to do its job.
If we had to replace it we would go induction with twiddly knobs.
Posted : 01/09/2024 4:56 am
5 pan flexinspace  induction and a single mega gas burner ring alongside. Induction great for about 90% of cooking but despite what people say it’s not flexible/responsive or as hot as gas for when you really need some oommmph (e.g stir fry, or steak searing etc.) costs a fortune to do it this way and takes up space, but if you’re into your cooking this is a good set up.
I if you only have space/budget for one, then gas it is… induction only always left me feeling a bit short changed.
Posted : 01/09/2024 6:19 am
We had gas, now have induction. It's easier to clean, faster to boil and simmers lower. Just better all round. Downsides were cost and new wiring.
Posted : 01/09/2024 7:07 am
Steak searing on the hob. Heathen.
Whole other debate but that's what the gas BBQ outback is for. #flames
Posted : 01/09/2024 7:22 am
Gas BBQ? I’LL GIVE YOU HEATHEN!
Posted : 01/09/2024 7:49 am
andy4d and andy4d reacted
 edd
Anyone got any recommendations for some 60cm wide induction hobs? (Or even recommendations for induction hob brands?) Currently have a terrible set of ceramic hobs. The good news is that they already have a 32A supply so converting to induction should be easy. Ideally around £600 or less
Posted : 01/09/2024 8:06 am
jimw and jimw reacted
This is the one we have, came with the house and I'm pleasantly surprised by it.
https://www.appliancehouse.co.uk/electrolux-lit604-induction-hob
Posted : 01/09/2024 8:15 am
I don't know this for certain but I understand, according to my local appliance repair man, that several of the brands are the same manufacturer but different logo/price point.
We have a zanussi induction cooker, it's identical to AEG I think but was cheaper.
The hob has proper knobs, across the makes. Or at least they did, it's about 4 years old now
Posted : 01/09/2024 8:22 am
 jimw
We changed from gas to induction and wouldn’t go back for the reasons well explained above. The only advantage that our old gas hob had was that we could still cook  or boil water if there was a power cut, of which we seem to be quite prone for some reason although lately they have been short duration ones.I bought a cheap gas 2 burner stove for those occasions a couple of years ago.
Posted : 01/09/2024 8:47 am
Induction every time.... Gas can get [back] in the sea!
You don't need a wok, it's amazingly it's easy to stir fry in a saute pan.
We changed 5 years ago and I'd never go back to gas.
(Don't buy a cheap induction hob though)
Posted : 01/09/2024 8:51 am
When we moved here we had an induction cooker. I wouldn’t go back to anything else. We’ve now got a 85cm wide Neff thing (wife’s choice), it is better than the previous. Flex zones, timer that turns hob off and can be programmed for more than one zone - great for dippy eggs. It’s the safety element too, no fumes, no CO, no leaving the house filling with gas (looking at you Mum), no leaving a gas ring burning all night (also looking at you Mum). Easy to clean, quick boil, adjustability as good as gas. You can also use it as an excuse to get new pots and pans and Le Creuset work too…
Posted : 01/09/2024 9:01 am
Ah the English BBQ. Standing round for hours waiting for it's 30 seconds of glory at the right temperature - by which point it's usually raining.
Ain't no one got time for that shit regularly.
Posted : 01/09/2024 9:07 am
Ah the English BBQ
Indeed. Brother lives in Oz. Has gas BBQ
He could be the only one though, I don't know.
Posted : 01/09/2024 9:15 am
Anyone in the house use an insulin pump or pacemaker? If so, warn to stay away from the induction hob when it is in use. The magnetic force can upset these devices.
Posted : 01/09/2024 9:43 am
anorak and anorak reacted
Ah the English BBQ. Standing round for hours waiting for it’s 30 seconds of glory at the right temperature
Sounds like amateur hour here. Learn the craft and be amazed how much better properly cooked bbq food (and that’s a wide genre) tastes over gas cooked.
Posted : 01/09/2024 9:51 am
trail_rat and trail_rat reacted
I spent a stupid amount on a Miele (7575 I think), and I’d be happier on a £300 gas unit instead. Mostly good, but when it turns off because water has splashed on it, or turns off because it’s confused itself with pans in close proximity or turned off for any other reason just as your finishing pulling everything together I want to hurt it.
The levels are really accurate, but I prefer seeing a flame to know how much heat there is. 3 years in and I suppose I’m used to it that - finally.
If you do get one, Barkeepers Friend is awesome for getting marks off them.
Posted : 01/09/2024 6:17 pm
PeteT and PeteT reacted
@edd
Bosch have 60cm induction hobs for 32A supplies for £500-600, fitted one when I did son's new kitchen early this year. Look at the boost ratings for the rings, 3.7kw is common on such. And thats COOKING!
Posted : 01/09/2024 6:40 pm
edd and edd reacted
Thanks for the input everyone.
I'm not a statistician but i'd say thats a pretty convincing lean towards induction (unless gas aficionados are a just quiet bunch)
Think i'm going to get an induction but leave my gas supply in place is till i've given it a couple of months.
Now just which one..........
Posted : 03/09/2024 1:23 pm
 Sui
When i did my Kitchen i got a fancy Neff one Neff N70 T58FD20X0, Yes it's great for cleaning, but no matter what people sya they still scratch and get chipped.  We had to discard (bung in the shed) all of our old pans, so we now only have about 5 that work as i cant be bothered to get any new ones.  Yes it heats quickly with the boost function, but i don't like the controls especially when you realise things are about to boil over.  We still have a gas hob in our second kitchen/utility room (Italian family), so when we do messy/smelly stuff use a wok we go there!   If i was to do it again i'd get the induction/Gas mix hobs - i bitterly regret not getting that this time round.  Also - im convinced our elecy bills went through the roof becuase of it..
Posted : 03/09/2024 1:52 pm
 mert
I have no mains gas (there's pretty much zero mains gas in the entire country).
I still cook on gas, bought a hob that would run on bottled.
Saying that, the latest generations of induction are a shit load better than those i was looking at 15 years ago.
Posted : 03/09/2024 2:21 pm
I love my gas hob. I wouldn't change it - love the heat control and general "feel" of it when cooking. Plus, can toast/puff things like tortillas or char peppers over the open flame if you're getting creative.
Never had an issue with leaving the gas on by accident or whatever because it is incredibly obvious to those with basic observation skills if a gas hob is left on.
Please bear in mind I am pretentious and have ideas way above my station.
Posted : 03/09/2024 3:09 pm
Before all the Brexit taxes kicked in, we invested/splurged on a Rangemaster Nexus SE 110 Induction, and we love it.
Not all inductions are the same so I think the advice to get a 32A one is good.
Also, physical control knobs, not touch controls that make annoying noises, or protest if you get them wet/greasy etc.
Posted : 03/09/2024 3:15 pm
Think i’m going to get an induction but leave my gas supply in place is till i’ve given it a couple of months.
Now just which one……….
Can your electricity supply handle one?  When I redid my kitchen 12 years ago, I had a new cooker circuit put in because we were fitting a 100cm electric ovens/gas hob range. Shiny new dedicated 32a circuit.
Range cooker needed to be replaced this year (long story) and I really wanted to out a fully electric one in with an induction hob. Problem; all of the range cookers in that size needed a 48a supply on a 10mm cable, when I have 32a on a 6mm 🙁
Might not be a problem if you’re just doing a hob, but if that’s replacing a gas one, the wiring to it might only be enough to drive the ignitions.
I’ll just have to wait another 10 years till we need to redo the kitchen again, because there’s no way of running a new cable without destroying stuff.
Posted : 03/09/2024 3:18 pm
No competition. Good quality induction all the way.
Easy to clean.
Lightning fast.
No local emissions.
After being a gas hob user for decades I switched to induction several years ago. I do not want to go back.
And you can get flat bottomed woks that work fine.
Posted : 03/09/2024 10:25 pm
 J-R
We changed from gas to induction with a kitchen upgrade and induction is outstandingly better, except for one thing: if you want to cook with a wok you need gas. I’ve used a flat bottom wok on induction and it was a bit meh.
For us the answer was a 4 spot induction hob, and next to it a dedicated wok gas burner.
Posted : 03/09/2024 10:29 pm
 myti
So how bad is the pollution from gas? I have gas hob and no extractor and never realised it was an issue. Tempted to switch to induction as some of the tech described on here sound brilliant such as being able to set a timer, zone heating rather than rings and really low simmer. I do a lot of cooking including some wok but happy to buy flat wok or special wok plate if required.
How much are we talking for the good kit and those singing induction praises what make and model are you using?
Posted : 04/09/2024 8:31 am
We have a range with an induction hob.
It's great, nearly as controllable as gas but much easier to clean.
It has proper knobs, not the touch controls.
I've stayed in a couple of holiday places that had the touch controls, they were terrible.
Posted : 04/09/2024 9:23 am
love the heat control and general “feel” of it when cooking.
If you think gas gives you 'heat control' then you've obviously never used an induction hob - they can* be miles better than gas IMO.
We had a big range cooker with gas hobs and the hobs never went low enough for a gentle simmer so I ended up having to start turning the the knob back towards off until the flame was almost low enough to get the right simmer..... and then the flame would go out. So annoying!
And that before I start on keeping the pan stands clean (ans: you can't).
Now I can set [whatever] to simmer as slowly as I want, put the timer on it and leave it to it's thing.
Bloody hateful thing and I'm sooo happy we changed 5 years ago.
I don't know but their kicking up a fuss about it in the US.  Think of it this way, if you have a gas burner in your living room or a gas boiler the law says it needs to have all the exhaust gasses expelled outside through the flu - your gas hob is burning exactly the same stuff and you're standing over it sucking in it's emissions.
Makes you think!
Difficult question to answer but I put a big Neff in at home.  It has a magnetic [removable] 'twistpad' for selecting and controlling the zones which I think works really rather well - it gets away from touch controls but keeps the surface knob/clutter free (the hob can be used in touch mode if required).
In our beach place I originally put in a cheap (used off ebay) hob that just did touch control which is OK but it only had power settings from 1-9 and i found that 2 was too high for the simmer I wanted but 1 was too low (may have been 3 and 2... can't remember!).
So earlier this year I bought a used Neff from ebay which has an earlier version of the twistpad, called the tip pad or something - it's not as slick as the twistpad but it's pretty good.
* The big main thing for me though is that Neff do "half" settings on each power indicated by a dot, so you have 1, 1 + dot, 2, 2 +dot, etc to give much more control which I find perfect.  I'm sure other manufacturers to something similar - just make sure you have way more than 9 or 10 power settings.
Also look for the ability to combine zones for large pans**.
** I've now learned that you tend to get what you pay for when it comes to pans.  Expensive ones conduct the heat throughout the pan much better than cheap pans so you can get a way with a larger pan on a smaller induction ring (also applies to gas).  A cheap pan is also more likely to be thinner so you need to be careful when applying full power on an induction hob as it can actually warp the pan - especially when 'empty'
I now buy very expensive pans but only used off, you guessed it, eBay!  I never knew that expensive pans (I'm talking £300 for a new saute pan) were such a joy to use!!
Posted : 04/09/2024 9:52 am
myti, J-R, myti and 1 people reacted
 J-R
 J-R
I’ve stayed in a couple of holiday places that had the touch controls, they were terrible.
I agree knob controls would probably be a little better, but I’ve found after a week or two you get completely used to touch controls. It’s just a different method from the one you have used for 40+years.
If you think gas gives you ‘heat control’ then you’ve obviously never used an induction hob
Absolutely this.
Posted : 04/09/2024 10:11 am
That AEG looks like a good deal. Seems to be the poached branded version of the Electrolux I have and linked to earlier. If you're happy with touch controls I'd go for it.
Posted : 04/09/2024 10:35 am
@smiffy If you love gas and think there is no alternative if you use a wok, then you've never tried a charcoal bucket.
Posted : 04/09/2024 10:37 am
Only 10 power settings plus Boost - not enough for me
Slide control thing - I'd prefer simple touch buttons if there's no knob
Can't combine zones.... but it does have one larger zone.
I'd look at alternatives.
Posted : 04/09/2024 10:56 am
Only 10 power settings plus Boost – not enough for me
Slide control thing – I’d prefer simple touch buttons if there’s no knob
Looking at the photo it has 14 power settings, plus boost. Also you can slide or touch the individual power setting.
But yeah you can't combine zones, that costs way more £££
Posted : 04/09/2024 11:35 am
