Garmin Forerunner 4...
Garmin Forerunner 45 problem
2 Users
1 Reactions
Post to follow
Posted : 24/05/2025 7:38 pm
Okay, as the New topic button doesn't appear on my Kindle Fire I had to start this on my phone, so I can now post.
I have a problem with my Forerunner 45, I have had for about 3 years and like it, it does everything I need. In the last couple of days the  watch face has started just popping off, hanging by the connecting cable. I can push it back and it seems to click into place but it can be easily dislodged.
I'd been thinking about replacing it with a Forerunner 55 and have started looking round.
Has anyone had a similar problem and can it be sorted easily?
Posted : 24/05/2025 7:47 pm
I wonder if an aftermarket case might hold it in place?
"https://www.amazon.co.uk/Compatible-Forerunner-Protective-Protector-Smar****ch-Black-White/dp/B088PH1R3R/?th=1"
Posted : 24/05/2025 7:49 pm
Could be worth a try, for £9 it might be worth it, but it would need to watertight, at least in rain.
Posted : 24/05/2025 7:53 pm
After-market case arrived and fitted. Clips over buttons on the sides, so, I think, should stay in place. Seems to hold the face on ok. Probably not completely water tight, so should avoid immersion. Not a permanent solution but will provide temporary cover.
I have emailed Garmin support for advice, should take a couple of days. Meantime, thanks @scotroutes
Posted : 25/05/2025 6:26 pm
scotroutes reacted
