Garmin Forerunner 3...
[Closed] Garmin Forerunner 305 issues
8 Users
Has anyone got any suggestions about what might be up with my Forerunner 305.
It just won't sync to my laptop. Was working fine when I last used it a few weeks ago and now nothing.
Sportstrack and Garmin Connect just don't see it.
I've tried the usual - cleaning the pins on the back of the unit, different USB cables etc but nothing.
Any ideas?
Thanks all
Danny B
Posted : 16/06/2013 6:36 pm
Have you powered the laptop off and back on again (seriously)? USB drivers can get a bit iffy if you're unplugging devices without un-mounting them first.
Posted : 16/06/2013 6:42 pm
 cp
as above.
have you installed any anti virus or firewall software? these cam sometimes get in the way of Garmin comms. could be worth switching off temporarily to check...
Posted : 16/06/2013 6:50 pm
Thanks for the ideas guys.
Yes, tried turning off / on and have disabled Kaspersky just in cases.
Was working fine and haven't changed anything I don't think.
I'll keep playing and if anyone else has any suggestions they would be appreciated.
Danny B
Posted : 16/06/2013 6:58 pm
Of course if it doesn't work I could use it as an excuse to get an Edge 500 (don't need the 510).
Danny B
Posted : 16/06/2013 7:00 pm
Try resetting your Garmin. You will lose data of the unit though.
http://support.garmin.com/support/searchSupport/case.faces?caseId=%7B4315c510-5161-11dc-4ec8-000000000000%7D
Posted : 16/06/2013 7:51 pm
what browser are you using ?
sometimes i really struggle to upload with Chrome or Firefox , but always work with Explorer .
and I need to upload everyday ( or for every single activity ) , otherwise I get a lot of errors .
have you tried to unistall garmin plug in and re install ?
Posted : 16/06/2013 7:55 pm
Nope - resetting didn't help.
I've reinstalled all the drivers and it sees the device when I plug it in, installs the USB drivers and then doesn't do anything else.
Annoying!
Anyone want Forerunner 305 that works in itself but is reluctant to talk to a computer!
Danny B
Posted : 16/06/2013 7:57 pm
Tried a different lead?
Posted : 16/06/2013 8:19 pm
Yep. Didn't help. Ready to slit wrists / drink bleach. Well - listed on ebay at any rate and will use proceeds towards Edge 500 (and yes I have detailed the issue!).
Danny B
Posted : 16/06/2013 8:33 pm
My FR210 is dodgy when the ram is nearly full, have you tried deleting all but the last (couple of) file(s) from the device?
(Incidentally: this is why I just bought a Suunto Ambit...)
Posted : 16/06/2013 8:56 pm
Problem solved. Was on ebay for about 5 mins and sold. Edge 500 will be ordered shortly.
Danny B
Posted : 16/06/2013 9:22 pm
Frying pan -> Fire.
http://singletrackmag.com/forum/topic/garmin-500-not-uploading-since-firmware-update
Posted : 17/06/2013 11:14 am
Don't think so mogrim - the 305's firmware hasn't been updated since 2009.
It was working fine now so there is either a) a wider issue with Garmin Connect at the moment or b) just coincidence.
Anyone else having issues with Garmin devices at the moment?
Danny B
Posted : 17/06/2013 12:34 pm
No, I meant that if you get the new Edge you might run into problems too - although my mate has a 500, and has managed to upload yesterday's ride data to Endomondo. As you say it could just be a temporary problem with the Garmin server.
Garmin's getting a pretty poor reputation for reliability, I was chatting to the shopgirl at my local running store on Saturday, she mentioned the number of problems they had had with Fenixes, enough that they'd stopped stocking them.
Posted : 17/06/2013 1:19 pm
Sometimes having other USB devices plugged in to the PC causes issues. Other times, having too many activities on the device can cause problems - usually lengthens the upload process though.
Re-pairing the device has worked for me in the past also.
Posted : 17/06/2013 1:29 pm
Garmin's customer support is great. Give them a call.
My Forerunner 205 lost its beep after a couple of years' use. After a phone call I posted it back to them, they charged me about £60 and sent me a shiny new one.
Posted : 17/06/2013 2:14 pm
