Garmin Fenix - repl...
[Closed] Garmin Fenix - replacement straps
12 Users
The strap on my Fenix 5 has snapped and choices seem to range from about a fiver to £45 for the genuine Garmin one. £45 seems a bit steep so any recommendations for mid-ranges versions that last well?
Posted : 28/06/2019 10:27 am
If you find the 935 Garmin straps they fit but are not quick release and usually lot cheaper think mine was about 15 for the Garmin one.
Posted : 28/06/2019 11:38 am
I've got a few from AliExpress, about £3 each, with Quickfit connectors. They have lasted fine for the last few months anyway.
Posted : 28/06/2019 12:10 pm
I used some MoKo ones from Amazon for Fenix 3 which were pretty cheap, but lasted longer than the one it replaced.
Posted : 28/06/2019 12:34 pm
Ah, ok so cheap and cheerful may be the way to go here - worth a punt for a few quid 🙂
Posted : 28/06/2019 1:51 pm
When the strap on my 35 snapped Garmin replaced it free of charge. I'd be asking them first. (...and then a few weeks later asking for a second one in case you need it in the future.)
Posted : 28/06/2019 1:58 pm
After struggling with replacements and contact dermatitis with both Garmin and aftermarket straps I now use hope elasticated/velcro straps. Just needed the tools to undo the one side where the straps connect.
Easily replaceable and better still cheap, secure and comfortable 🙂
Posted : 28/06/2019 2:08 pm
I've had a £15 Amazon special copy of the Garmin metal strap for about 3 years. It's been mountain biking, swimming, running and working in some fairly extreme environments and the only thing wrong with it after all this time is the finish is looking a bit jaded. Not a chance I'd pay full price for Garmin branded stuff.
Posted : 28/06/2019 4:29 pm
I’m interested in this too as I can see my 5S strap is splitting. However, all the Amazon after market ones say they are longer than the originals. As I’m only 4 holes off the minimum on the official one, this isn’t going to work for me. Anyone any direct experience of any which aren’t longer?
Posted : 28/06/2019 7:13 pm
I bought some of these for my Fenix5, seem reasonable quality and have worked fine swimming/biking/running these past few months:
https://www.amazon.es/gp/product/B07DCQNP7X/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
(Amazon Spain link, presumably the same are available in the UK)
Posted : 28/06/2019 9:20 pm
#ThreadResurrection!
Looking at buying a Fenix 5x Plus and going for a leather strap version. I sweat, lots, and spend a lot of time in the water. Am I going to regret this? Will the strap die and/or look rubbish after a week. Will I spend all my time swapping with the supplied silicon band? \\
Thanks
Neil
Posted : 20/07/2019 2:36 pm
With regards to dermatitis remember to clean the watch regularly as it's full of bacteria in the skin contact areas of the watch.
Posted : 20/07/2019 3:59 pm
With regards to dermatitis remember to clean the watch regularly as it’s full of bacteria in the skin contact areas of the watch.
I get a bit of dermatitis from mine, but go swimming 3 times a week (minimum) - surely that should be enough to clean out the back of the watch?
Posted : 20/07/2019 5:40 pm
Unless you take the watch off and wash it, the nasties build up between the watch and the skin to cause irritation. I usually wash my instinct in the shower?
Posted : 20/07/2019 6:02 pm
