Garden Fencing... w...
[Closed] Garden Fencing... why so expensive?
34 Users
Just had a chap round to quote us for a run of fencing out the front. we need...
7 x arched 4ft panels
7x 1ft gravel boards
8 6 ft concrete posts.
This lot including fitting came to £1350 ???
Does that seem expensive or not?
Posted : 31/05/2015 7:59 pm
installed and treated?
Posted : 31/05/2015 8:00 pm
Yes sorry treated and installed.
Edit.... 1 x 6 foot panel and 6 x 3ft panels
Posted : 31/05/2015 8:02 pm
Yes it does.
 m0rk
Seems pricey... work it out from AVS Fencing and you'll be able to see how much his day rate is
Posted : 31/05/2015 8:03 pm
 cozz
round here id say
panels about £30 each (actually £26.50)
boards £10
posts £12-15
so i reckon £400 of materials
and I'd get my mate do do it, prob a days work for 2 blokes (mates rates) £200
so i'd be paying £600,, plus bit more for cement/ballast etc
2 blokes should get that done in a day - unless they have to remove old stuff first
My quick reckoning is between £500 and £600 on materials at Wickes prices.
Posted : 31/05/2015 8:05 pm
300mm concrete gravel boards ? Oh and before everyone starts going on about the price I expect most of the keyboard warriors couldn't even lift a concrete post. For what its worth cost would be approx 1K.
Posted : 31/05/2015 8:06 pm
Maybe the man has to pay tax, eat, feed and clothe his family and maybe make a small profit so he can buy some bike bits with the free cash. Or is that not allowed on here?
sounds expensive to me, yes. I had a chap build a 6ft high overlapped board fence that's the length of about 8 6ft wide panels + a gate for £800.
Posted : 31/05/2015 8:07 pm
you need to get some more quotes
We had pretty much the same as you want (but straight, not curved panels) and was about £500 a couple of years ago. Ans that's in the expensive SE badlands
We are getting more quotes.
Breakdown is 850 materials and 500 labour
Posted : 31/05/2015 8:09 pm
Find a local firm that makes everything themselves, way cheaper as they aren't buying in
Posted : 31/05/2015 8:10 pm
Ive worked it our roughly at Welch garden supplies at just under £350 for materials not including post crete
About 8 yrs ago it cost me around £120 per panel for a 50m run of 1.5m curved pressure treated panels like yours; concrete posts and gravel boards; fitted. Sounds a bit pricey to me, stuff like this hasn't gone up much since 2007. Pays to get it done well tho.
Posted : 31/05/2015 8:11 pm
[quote=renton ]Ive worked it our roughly at Welch garden supplies at just under £350 for materials not including post crete
well crack on and do it yourself, why get quotes if you are going shop online?
Posted : 31/05/2015 8:16 pm
The simple fact of being 9 hours and 500 miles away is the reason Im not !!
Posted : 31/05/2015 8:21 pm
We had ours done recently..
2 sides 9 x 6' panels + concrete posts and gravel boards
We had 3 quotes and they were all around £1800-2000
Posted : 31/05/2015 8:23 pm
I ordered a batch of these bad boys for our fence:
**** me, they we're heavy, a real struggle to lift to height to drop into the hole. The guy who (loaded &) delivered them wasn't too impressed.
All the timber i used (treated larch cant rails, overlap & boards) came direct from local forest & local saw mill.
Posted : 31/05/2015 8:26 pm
Sounds reasonable to me. I had a whole rear garden make over very recently which involved two guys working very hard for two weeks. I like a project - but I cannot lay circular patios or bricks or want to remove huge concrete laden posts. Sometimes other people have more expertise and tools than you.
You have to weigh up quality of outcome with cost.
Posted : 31/05/2015 8:33 pm
Is he getting rid of an old fence too, landfill costs are not insignificant for commercial operators, how easy is it to access the site?
Posted : 31/05/2015 8:34 pm
 joat
Bear hugging those^ caused me many a holed t-shirt (and bad backs). Quote doesn't seem too bad, just make sure you order the right size though Renton.
Posted : 31/05/2015 8:35 pm
There is nothing to get rid of as its just a little bit of land that people keep cutting across or dumping rubbish on!
Posted : 31/05/2015 8:38 pm
What's the ground like? Does anything have to be removed, replaced or disposed of? Is there easy access?
Your first two posts indicate you're not quite sure what's being fitted. The fencer may be covering the possibility of buggeration...
Posted : 31/05/2015 8:43 pm
There will be a slight addition to the cost to cover unforseen circumstances.
It's simple, pay someone to do a decent job, pay someone a budget price to do a budget job or do it yourself.
Posted : 31/05/2015 8:46 pm
This the famous bit of land that your deeds say you cant put a fence up on ?
Posted : 31/05/2015 8:49 pm
In that case you probably don't need the Rolls Royce fence you've specced. Metal fence post concreted in at each end and any corner. One roll of 4ft chainlink and a few intermediate posts driven in. Three tension wires per run.
Posted : 31/05/2015 8:50 pm
There are a couple of tree stumps on the ground where a couple of fir's were cut down but he has said they are not where the fence will be going.
Nothing else apart from mud.
He obviously thinks he can charge good money for his erection...
Posted : 31/05/2015 8:51 pm
Trail rat do try and keep up.... that bit of land was the front garden at my old house.
This is the front garden at my new house, down the left side is/was fir trees that have been cut down as they were blocking the light into the front of the house.
The patch of land is now open onto an alleyway down the side and people are now cutting across it and dumping rubbish etc.
We want the arched fence panels as there are already some down the side of the house and this run will continue on from that to the edge of our land.
Posted : 31/05/2015 8:56 pm
A rented property? so its an allowable expense if it is.
So it wont cost you anything in reality.
Posted : 31/05/2015 9:00 pm
Get some more quotes. I've seen plenty of fences that have been done quickly only to blow over during the first winter. It can take a while to dig a decent hole for a fence post if there's roots and big stones every few inches.
Posted : 31/05/2015 9:05 pm
So there may be roots involved?
This is land in question......
[URL= http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0002_zps95jfh9ka.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0002_zps95jfh9ka.jp g"/> [/IMG][/URL]
[URL= http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0003_zpsriypsy36.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0003_zpsriypsy36.jp g"/> [/IMG][/URL]
Fence will continue off this one.....
[URL= http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0001_zps8doiyui2.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMG-20150531-WA0001_zps8doiyui2.jp g"/> [/IMG][/URL]
Posted : 31/05/2015 9:06 pm
After seeing those pics I reckon youre getting a fair price.
Posted : 31/05/2015 9:11 pm
Should be able to knock that up in a day.
Seems a little excessive pricewise however there's a "premium" charge as most home owners won't do fencing/hedging as it's too much hassle.
Tim
Posted : 31/05/2015 9:15 pm
I did the fence at my previous house on 3 sides with a couple of mate and it went up ok.
To far away to do this one unfortunately
Posted : 31/05/2015 9:19 pm
That border does look like a world of pain, roots and hassle. If you could get it cleared back to bare earth you might get a kinder quote.
Posted : 31/05/2015 9:21 pm
[quote=midlifecrashes ]That border does look like a world of pain, roots and hassle. If you could get it cleared back to bare earth you might get a kinder quote.
This ^
Posted : 31/05/2015 9:23 pm
The chap did say the stumps and roots wouldn't be a problem though.
Do you think his Labour charge is fair at 500.
Would it likely go up if we supplied our own materials.
Posted : 31/05/2015 9:25 pm
Worth a try, but I think the hassle and pain of the roots has been priced into the job.
Posted : 31/05/2015 9:44 pm
Yup. I'd probably price it similar unless I was desperate for the work. Don't know about the materials but for two of us I'd err on the side of caution and price for two days work. Probably wouldn't take two but could easily be more than one. There are easier ways of making a living.
Posted : 31/05/2015 9:49 pm
4ft panels, 1ft gravel board and 6ft posts...I see a problem already..where is the fence-line..where the stumps are? What panels ate you using? there's many different sorts, scoreboard, woven etc..
Where's the job?
Posted : 01/06/2015 12:18 am
Tymbian... Job is in Droitwich Worcestershire.
The bloke said that the stumps aren't in the way so not a problem.
The border is actually quite clean between the path and mud. It just needs sweeping up so you can see it.
We are after arched panels, 1 @ 6ft and 6 @ 3ft.
Posted : 01/06/2015 8:55 am
 Del
not a problem, just what you are paying him to deal with.
you seem to think he's too expensive. just go and get some more quotes.
personally I'm not afraid to pay someone to do a job to a reasonable standard and earn a living. YMMV.
500 quid:
1) turn up to quote for a job you may not get.
2) spec, arrange and supply materials on account.
3) run van and pay for tools, be an employer, or pay a loaded rate to a colleague.
4) accept liability and correct any problems later.
5) feed and cloth the kids.
6) chase non-payers and fail to get any money at all out of some people.
Posted : 01/06/2015 9:04 am
Del we are getting g more quotes so will be able to compare.
To be honest his Labour quote at £500 seems fair enough. It's just the materials @850. I've priced it up at 350 online.
Posted : 01/06/2015 9:19 am
I'd get a few quotes then pick the cheapest I think would do a good enough job, I'd be looking for recommendations from friends. No point worrying about how much anyone needs to feed their kids, that's their job to get right.
Posted : 01/06/2015 9:22 am
including all the consumables / fixings / postcrete and all the other incidentals that the layman forgets that tradesmen need to supply on top of the big ticket items.
and of course your ensuring that they are absolute like for like products made from the same quality materials ?
stuff from tradesman will be more expensive due to his markup ok 500 Over and above is excessive however i dont believe thats the full picture .
Posted : 01/06/2015 9:23 am
I think any tradesman that marks up materials is taking the piss. If you get a discount when buying and choose not to pass it on then fair enough, as said above you have to cover time spent finding materials etc. If the customer is good to deal with and doesn't ask for discount for cash etc then I'll usually pass on any savings to them. I don't do many landscaping jobs as they are often a pain in the backside because people don't want to pay a decent rate for a hard days work.
Posted : 01/06/2015 9:32 am
Some clients, you just know, you know...
Same with bike shops. They should charge £5 to fit a headset bought off them at wholesale pric... 🙄
Posted : 01/06/2015 9:44 am
Trail rat I'm not sure I get what you mean when you say it's not the full picture. ??
Posted : 01/06/2015 9:46 am
I N R A T S but I just replaced a panel with separate slats (it blew out and the replacement matches the rest of the fence).
Only a 6' length, but 7' high, timber £30.
Posted : 01/06/2015 9:47 am
If the Trader supplies goods, he has to guarantee them.
So, of course he is going to add something to the cost.
He also has to go and collect the stuff, pay for it (probably on the day, as most fence suppliers do not do accounts, whereas Builder Merchants do do account payments).
It soon adds up in both time and money.
So, to the OP, you supply the goods, get him to fit it. You'll then have the benefit of paying slightly less for the materials, and have the added benefit of arranging the deliveries and getting rid of the waste too.
But be aware that some fences are not as good as others - they look the same, but once you have put one up, you soon tell the difference.
It's a litlle strange that you think he shouldnt be adding anything to his cost price of the materials - he is in business to make a profit, when you buy your groceries, do you complain that they are charging more than the shop bought the goods for?
Posted : 01/06/2015 9:50 am
He's unlikely to be in the business of retail so doesn't have storage costs and any markup is for hassle of ordering and collection - could just build into his labour costs really. If he was a retailer he'd be buying from a distributor so be paying less than the retailer who's already making a profit.
Posted : 01/06/2015 9:59 am
Yep but 500 more ?
This is the quote ..........
[URL= http://i2.photobucket.com/albums/y33/renton1/IMAG0214_zpsw6vz5bjt.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/IMAG0214_zpsw6vz5bjt.jp g"/> [/IMG][/URL]
Posted : 01/06/2015 11:09 am
im saying - welches garden world or who ever - for 350 quid are probably supplying a fence of a lesser quality - as they full well know they wont have to warrenty it when they can blame fred bloggs for putting it up badly.
mr fence man has to use good stuff as he will be the one back to fix it when it blows to bits.
Posted : 01/06/2015 11:41 am
This is where I am looking online....
http://www.garden-fence-panels.co.uk/fencing-panels/garden-fencing-close-board-arched-or-scalloped-panel.html
Those panels don't look to bad at all do they ?
Posted : 01/06/2015 11:50 am
not passing comment on that - its a 2 dimensional picture of a fence panel at some point
Its very assuming to assume that what your see is what you get when it comes to the internet- yet we all do it from time to time.
Posted : 01/06/2015 11:55 am
eh? it's the same thing by two different routes.
Posted : 01/06/2015 12:28 pm
Did you intend to just publish your address on the internet? Checks posting history to work out what bikes he has 😉
Posted : 01/06/2015 12:50 pm
They don't exactly look great. All those knots are going to fall out and provide a peepers' paradise.
I note from the quotation that fitting new gravel boards for the existing fence are also included- something you forgot to mention.
To be honest, I don't think the fencer is too bothered whether he gets this job or not. Some jobs, and clients, are just more hassle than they're worth.
Posted : 01/06/2015 12:51 pm
" I don't think the fencer is too bothered whether he gets this job or not. Some jobs, and clients, are just more hassle than they're worth."
the fencers an STW regular then 😉
Posted : 01/06/2015 1:32 pm
Come on trolls you must try harder than that.
My father in law has been dealing with him for me and he (fil) is a thoroughly nice chap.
So nowt to do with me being hard work.
Posted : 01/06/2015 1:52 pm
If he is a nice chap, who does good work, then pay him his price.
You can always ask if he could do it a little cheaper beforehand.
On a general point, why is someone doing manual labour questioned about their costs and the amount they charge?
When you are employing a Solicitor, does anyone ask him why a letter costs £35+, when it will take 2 minutes to write?
The same goes for a financial advisor - I paid £300 for what, for him, was probably 2 hours work. If pushed, I could probably do it myself, but it would take me many hours to research. He's got the knowledge, so I paid his fee. I didnt question his fee, yet it is common to query manual labour costs, and then conclude that you are being ripped off as he is charging more for the parts than you can get online.
Posted : 01/06/2015 2:04 pm
 Del
OK, to summarise, pay the man or don't. If that's trolling I'm out.
Posted : 01/06/2015 2:10 pm
I've not said I am being ripped off at all ? All I have said is that I thought his material costs are quite high compared to what I can source the stuff online.
Even if you add an extra 20 quid per panel to my figure it's still quite a bit more.
Anyway. Got another chap coming to give a quote later in the week.
Posted : 01/06/2015 2:13 pm
 iolo
No disrespect to yourself but if I was coming to price a job and the potential customer spoke in the way you are in this thread then I would include a "buggereation factor " into my price too.
The panels you linked to are the first ones that come up if you type "arched fence panels" into Google. Maybe have a look at a few others to compare. Tell you what, go down to a local fence supplier, have a look at their cheapest fence then the fence you would like to have and compare. Then come back to this thread.
Posted : 01/06/2015 2:25 pm
Renton - it's easy, order the parts online, and ask him for a labour only cost.
I'm always happy doing that, if something goes wrong with the parts, I can charge for replacing them, but when I supply myself, I have to guarantee and repair free of charge.
Probably not useful for fencing, as there is little to go wrong, but I really would check the panels are the same quality - 2 mm thickness in the wood really does add to the robustness of the panel, but you can never tell that by looking at them.
Posted : 01/06/2015 2:29 pm
LOL - and make sure you pay him for his down time when you don't order everything required inc fixings :O)
(not a dig at the OP, just a comment to that comment. I've been asked for a labour rate before and refused. Then again I won't put up panel fences either :O)
Posted : 01/06/2015 2:34 pm
Iolo.... How exactly have I spoken ???
I've asked if a quote was expensive and that I've been able to source the parts online cheaper.
It's like shopping at your lbs when the same thing can be had online cheaper is it not ?
Posted : 01/06/2015 2:41 pm
Alanl thanks for that.
Just out of interest would your Labour charge differ between supplying and not supplying materials ?
Posted : 01/06/2015 2:43 pm
maths fail
Posted : 01/06/2015 2:44 pm
I had 120m of fencing done for about £7k 15years ago. This was 4" posts, cant rails and feather edge boarding.
[url= https://c1.staticflickr.com/9/8383/8683414218_1cbee8477f.jp g" target="_blank">https://c1.staticflickr.com/9/8383/8683414218_1cbee8477f.jp g"/> [/img][/url][url= https://flic.kr/p/eejLwf ]Daffodils[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Posted : 01/06/2015 2:48 pm
My labour charge is the same whether I supply or not, but I'd rather the customer supplied the parts.
As outlined above - not supplying the materials has a number of plus points - no time going to wholesalers, no payment upfront for parts, no guarantee from me for the parts, if parts are late it isnt my problem, no waiting for the customer to pay the my Invoice for the parts, no arranging of delivery etc.
I had one last week, wanted outside lighting, I gave him a brochure, said go here, when you've got them, ring me and I'll fit them. It isnt worth my time getting them, then the customer may not like them, as they look different to the pics in the brochure.
Posted : 01/06/2015 3:29 pm
Thanks for that.
To be fair if he does a good job of fitting the concrete posts then we could possibly get away with cheaper panels for now and then replace all of them including the ones that are already there in a few years.
I will see how much this other quote comes back at!
Posted : 01/06/2015 3:35 pm
the original states fitting concrete gravel boards to an existing fence as well as building a fence from scratch...am I correct?
Posted : 01/06/2015 5:15 pm
Yep. Three extra gravel boards.
Posted : 01/06/2015 6:06 pm
Posted : 01/06/2015 6:07 pm
Last year when I went to my local timber merchant they were actually discussing this very issue. Boards were in short supply due to the repairs to flood damaged property's hoovering up all the boards. They were only getting limited stock and it was being shuffled around branches 🙄
Posted : 01/06/2015 8:01 pm
Except the bloke in question is possibly charging more than retail price for the materials, not trade price and charging for labour. It'd be more like a shop charging you £30 for a £20rrp headset plus whatever they charge to fit it.
Posted : 01/06/2015 8:39 pm
