garage, how much to...
[Closed] garage, how much to build?
7 Users
Single detached garage, apex roof, roughly how much inc drawings, building inspections/permissions etc?
Posted : 03/06/2012 7:27 am
I don't know about price but you need to spec materials, oak, concrete block, single / double skin walls, plasterboarded, slate, tiles, electric, water etc???
I am in the very slow process of building one, you can cut your faffage by building within permitted development, get online at .gov to see the rules.
Posted : 03/06/2012 7:43 am
Cheers will peruse
Posted : 03/06/2012 7:54 am
What size?
Materials are bloody expensive again at the moment!
Drawings easy enough to do yourself
Planning coupla hundred quid.
3cx for day to dig founds/level up £250
Concrete for founds/floor 75m3
Decent brick £250 a thou at 60/sqm
Blocks between 50/80p at 10/sqm
I'd also go for a truss roof as far quicker and easier, poa!!
Slates/tiles big variant depending on what you have!
If not doing it yourself then, Decent jobbing builder £120/day
Your labour/assistance to him free im afraid.
Posted : 03/06/2012 7:56 am
Garage door!! Doh!!!!!!! ££££ or £££ depending on spec, personally I'd also have a side door too.
Posted : 03/06/2012 7:58 am
Also if you want to up your sq footage go for an attic truss as you'll be able to get up there and deck it out! More cost tho.
Posted : 03/06/2012 8:01 am
 dyls
Why not buy an off the shelf concrete panel garage? Probably cost £1500/2000 fitted. Youd need to do the base yourself, something like 100/150mm of concrete with mesh would be ok, say 3m3. Planning would be a few hundred, if you know someone who does CAD they could do the drawings pretty quickly.
Posted : 03/06/2012 8:21 am
Good idea, just requested a quote, security is the key for me after having had shed break in, how secure are prefab garages?
Posted : 03/06/2012 8:45 am
Doors and windows are the weak points, so somewhere between 0 and 10 will see the best trade between security and access. 🙂
Budget for extra locks on an up and over door and 5 lever deadlock on the access door.
Posted : 03/06/2012 8:48 am
on average if your were to work on £600 per meter squared that would give you a good idea
Posted : 03/06/2012 8:55 am
I had the same problem, my old garage was attacked twice,first time no success, second time cleaned out of all tools, bikes, and fishing gear.
A prefab garage was around £3000
To have one built from drawings, in brick was another £1000.
In the end i ordered a 10 x 8 ft shipping container in green, had a side window cut out, and a rear door installed,covered it in trellis,and grew clematis up the sides, total cost delivered £980 + £200 for the door and window.
Best bike shed ive ever owned.
And for the car I built a car port.
Posted : 03/06/2012 9:31 am
