Except you might not get another such chance for a long time - see Rogers' "LBW" on 20 odd in the first innings.
I disagree. The very next ball is another opportunity for the bowler to create a chance. Whether they have the skill to create another chance is a different matter. If they don't - then maybe the next one, or the next one. But they certainly aren't told to go and sit in the shed for the next day or so, and only allowed to bowl again in the second innings.
In fact: If they bowl a slow half tracker and get hit into the road, someone else goes to get it for them so they can have another go (they should at least be made to go to the rope to get it back, so they can endure the silence a batsman gets when he walks off after having been sawn off for a duck)
(Can you tell I used to be an opening batsman 😉 )
That would certainly explain it! The fact the bowler has another opportunity straight away is irrelevant - on average they only manage a wicket taking ball every 9 or 10 overs in which time any decent batsman ought to be able to put together a good score, so it's not at all reasonable to make a wrong decision in favour of the batsman.
Which, as I understand it, is what currently happens. Third umpire tells him the facts, and he makes the final disposition, within the bounds of standing guidelines.
In theory. In practice the third umpire tells him what decision to make. The on field umpire doesn't get to take much part in the actual review process. What I'm suggesting is that the on field umpire takes a far more active part - this applies in particular to LBW calls where he could look at the Hawkeye and decide whether in light of the evidence his original decision was wrong (which ought at least get rid of the anomaly over the DRS decision depending on the original decision). I can see the argument for umpire's call from the point of view that the on field umpire shouldn't be over-ruled if it was close - if the on field umpire gets to make his own decision again that issue no longer applies.
Surely the point of DRS is to get the decision right so the extra info makes it a better decision and it is not doing this it is adding confusion- he did look out to be fair and I would have given it as well at full speed.
Indeed - and the DRS for the Watson and Haddin LBWs showed that the original decision was right.
BTW did anybody else see this edit of Watson's wiki page last night (sadly since reverted by boring spoilsports). Check out the nicknames
http://en.wikipedia.org/w/index.php?title=Shane_Watson&oldid=568251620
That wiki page is excellent. I'm liking particularly:
He announced his retirement due to injury after the 4th 2013 Ashes Test Match citing deep vein thrombosis, caused by being repeatedly hit in the same spot on his front leg.
Never seemed that way when I played. 'Phew, that was a good ball, lucky not to nick that one. On the plus side, that means there won't be another one for about 9 overs, so time to buckle my swash'
Every ball was a golden opportunity for me to end my participation for the day, and had to be treated as such, just as the bowlers get 100-150 odd chances to make their mark on proceedings.
The wider picture is that test cricket only works if there is an even contest between bat and ball. Umpiring has a huge role to play in that.
I agree
Problem is had he given them both not out and then been reviewed then that would have been right as well. That is the problem that needs resolving
yeah whatevers.
3-0 to the Engeerrland.
Maybe you should have been a bowler instead if you wanted more chances?
I reckon tests between two sides with world class bowlers and fragile batting line ups on a helpful pitch going to extra time on the 4th day suggests it's not too much in favour of the bowlers!
Ah well there I disagree - as I discussed above, clipping the stumps should be out, so giving them not out would have been the wrong decision (as Bresnan and Rogers' ones were). I agree that consistency is needed here. I'm particularly thinking about the Rogers first innings review here - the umpire had given him not out LBW because he though it had hit the bat, had he had all information available and known that it actually hit the leg would his decision have been different? I can imagine a more blatant situation where the fielding team appeals for LBW, the umpire thinks it pitches hits and is going on to hit in all the right places but that the batsman got an edge - the replays show the ball hit pad first but that slightly less than half the ball is hitting and the decision stays not out when it should really be overturned given the umpire didn't give not out on the basis of the ball missing the stumps. Yet the current rules don't allow that flexibility.
Actually, I think there's a dearth of truly exceptional talent at the moment. Just think back to the great bowlers and batsmen of 15-20 years ago...
And then look at England's test rankings for our current batsmen (Cook, KP, and Bell not too far behind) and bowlers (Jimmy and Swann).
As the rules stand had he given them not out then they would have remained not out as it was umpires call for both decision. So he was "right" whatever he said
In your example imagine it was caught so out for a ctahc but they missed and it was LBW but mariginal
Either way you need to decide that someones decision trumps someone elses
I agree th ebest scenario is to let th eumps trump their own decision though via replay.
That said , if STW is anything to go by, ,many will not back down, however compelling the evidence is , and admit that they are wrong 😉
Under the current DRS rules, which are clearly flawed. I'm suggesting that given all the information available it is clear that the ball would have clipped the stumps, so those should have been out. "umpires call" appears to be to appease those who reckon there is significant margin of error in the system, when the error margin is actually far smaller than the "umpires call" margin.
It does sound like we are generally in agreement on this though - I'm pleased my suggestion to hand more power back to the on field umpires has met with such approval.
<imagines umpire TJ> 🙂
Yes, it means that they're better than their contemporaries.
Or, in your example suppose the umpire thought it had pitched in line but was going on to miss, but in review it pitched 'umpire's call' but went on to hit. On field would be not out, on review would also be not out even though the actual umpire's call on where it pitched wasn't originally in doubt on the field.
No, far better that they go with the technology decision full stop, but with a margin of error built in.
(PS, I could bowl occasional off spin but mainly had the gloves on. So I do see both sides really, bloody frustrating to wait ages for a chance only to pouch it cleanly, or take a good stumping, and then for the umpire to say he wasn't sure so benefit of the doubt to the batter)
And Cowdrey, and Hammond for the batters.
And Trueman, and Underwood for Jimmy.
And Cowdrey, and Hammond for the batters.And Trueman, and Underwood for Jimmy.
None of the current mob get close to the batting and bowling averages of the players you list. Statistics fail.
I was referring to players of 15-20 years ago, none of the players you list were playing then. Comprehension fail.
Sachin Tendulkar?
14 matches, 9 dismissals, average 30.22
Ricky Ponting?
12 matches, 4 dismissals, average 6.00
Jaques Kallis?
15 matches, 7 dismissals, average 33.00
clearly the bowler involved in those stats isn't a great though
As of 12th August, KP had scored 7,775 test runs and 23 test hundreds, and Cook had scored 7,742 test runs and 25 test hundreds. Both have scored more test centuries than [i]any[/i] other English batsman and are five and six respectively in the all time list for English test batsmen.
Bowling wise, Jimmy is third in the all time list for England with 324 test wickets, and only Underwood is above Swann in terms of spinners. Jimmy is only one wicket behind Willis, which leaves only Beefy to catch, whist both batsmen have got to where they are having completed considerably fewer innings so far in their careers than the retired greats they stand equal or better than.
But as you said, statistics fail. 😉
Not sure what your point is?
All I'm suggesting is the best players of that era were better than the best players of today. Just look at the bowling - Walsh, Ambrose, Wasim, Waqar, Donald, Pollock, McGrath, Warne and Muralitharan. Then there's Lara, Border, Waugh...
Are you thinking of some Cowdrey other than Colin, batting average 44.06?
Or some Underwood other than Derek, bowling average 25.83 (I'd suggest an average 2.5 runs higher is quite close given conditions nowadays are doubtless generally less favourable for spinners - Underwood was renowned for his returns in condition modern bowlers don't experience)?
That's more runs than Bradman. Does that make KP a better player? Or is it just possible that the total number of runs scored isn't the only indicator of a player's quality?
At an average of over 30. Trueman averaged under 22, as did Glenn McGrath.
Back to class, Zokes.
Are you thinking of some Cowdrey other than Colin, batting average 44.06?Or some Underwood other than Derek, bowling average 25.83 (I'd suggest an average 2.5 runs higher is quite close given conditions nowadays are doubtless generally less favourable for spinners - Underwood was renowned for his returns in condition modern bowlers don't experience)?
Sorry, was thinking of Barrington.
I'm not convinced conditions for spinners are worse these days - Warne and Muralitharan didn't do too badly...
Bugger me, was he playing 10-15 years ago?
In the same way as batting average isn't, you mean? And seeing as they've played fewer innings than the other English batsmen ahead of them, I'd assume they have a higher average. They do.
So he was more economical, but won fewer games? (On the assumption that a team needs to take 20 wickets to win a game, and therefore taking more of them would help somewhat - c/f Broad about 24 hours ago)
Were Cowdrey, Underwood, Hammond or Trueman?
I didn't say it was. Do try and keep up.
Sutcliffe, Barrington, Hobbs, Hutton and Hammond must all be worse because they scored fewer runs in total? Hmmm...strokes chin.
Or, just possibly, the answer is he played fewer matches. (307 wickets in 67 matches at 21.57.)
In which case, you'd be correct about Trueman, but still wrong re: the batters. Only Hammond has a higher average for England.
1. You are the one who keeps talking about England and referring to players of 50+ years ago. I referred to the greatest players from any team of 15-20 years ago.
2. Trott, Pietersen and Cook are 14, 15 & 16th on the all time list. There are 7 players ahead of them who have played 20 or more matches.
http://cricketarchive.com/Archive/Records/England/Test/Batting/Highest_Career_Batting_Average.html
You do realise how Deadly Derek got his nickname? Doubtless some spinners nowadays get to play in better conditions than others, but I doubt anybody who knows anything would suggest Swann gets the help Underwood sometimes did.
I'd have thought it obvious, and notably the stats of some of your greats against the same players are rather worse.
Yes I do, but I've heard it suggested that the number of occasions that actually happened are rather overstated. It's before my time so I really don't know.
On the other hand, Underwood didn't have DRS, which has been of huge benefit to Swann. We'll never know...
As I say, the test records of Warne and Muralitharan show conditions for spinners haven't been too bad over the last 20 years.
Not really, unless you think a player with a top-ranking test average getting out quite often towards the end of their career to a particular player is a great indicator of something?
"In the same way as batting average isn't, you mean?"
...which was the first mention of averages, in reply to a post suggesting some current players were better than some older ones?
It would appear your answer is actually a variation of the Edinburgh defence when you start off trying to prove your point using stats...
So what exactly was your point when you wrote:None of the current mob get close to the batting and bowling averages of the players you list.
Zokes suggested that some current players are better because they have scored more runs and taken more wickets. I pointed out that the reverse is true is we look at batting and bowling averages. Whilst I think averages are a more useful statistic, nowhere did I claim that it should be the sole measure of a player's quality.
I had thought this was going to be an interesting discussion about great cricketers past and present, but apparently not.
I think them getting out quite often to a particular bowler when clearly still at their peak (Sachin got out quite a lot to Jimmy before 2008) has a certain amount of significance, yes. It's at least as good a piece of evidence of the relative quality of players as anything you've presented. Exactly what other means do you suggest to meaningfully compare players of different generations?
In absolute terms I suspect that batsmen of 15-20 years ago would find Jimmy as hard to face as any of those you mention and vice versa for Cook/Pieterson. Ultimately it's a fairly pointless discussion, but it's one you started, so really you need to come up with something to try and prove your point.
The bowling averages (and total number of wickets) of the players I listed were considerably better than Jimmy's. He's a very good player, no doubt, but yet to stand comparison with the very best in my book.
Cook and Pietersen would've filled their boots against a mid 1990s England side, but I'm not so sure about some of the others.
It tells us that he has trouble against Jimmy. It'd be interesting to see if he has trouble against other swing bowlers - any ideas?
No, your condescending tone saw to that quite early on in the proceedings, unfortunately.
Can we get back to slating the Aussies please? 😀
When yossarian and I agree, you just [b]KNOW [/b]it's right!
No need, they're quite capable of self-flagellation without our help 😀
http://www.smh.com.au/sport/cricket/oval-the-last-stand-for-some-coach-20130813-2rugr.html
I offered the following opinion:
You then went on to tangle yourself up with stats about England players from 50 years ago. Why you persist with not responding to what is written, I've no idea, but it precludes sensible discussion. A pity.
Of course! The pleasing thing for me, is whilst England have been below par, we're still far too good for the Aussies. Heaven help them if the top six start firing!
6 wickets is "considerably"? Unless he breaks down sometime soon Jimmy will certainly finish with more wickets than Donald and most likely Waqar at least. Meanwhile I thought it was generally acknowledged that he has greatly improved from his early years and that his overall average suffers compared to those who started off playing at their best. I also thought we'd agreed that wickets and average didn't tell the whole story.
No tangling involved. We were talking about the English test team, so by logical extension, I took your comment to mean English players. Cook, KP, Anderson and swanny are amongst, if not in some cases, the best players England has ever fielded, including those who played 15-20 years ago.
Then, for whatever reason, you resorted to condescension instead of merely clarifying what it is now apparent you actually meant. Wind your neck in a little and you might get more civil responses from others. See also the Concorde thread.
He may well do. As I said, I think he's a very good player, but hasn't in my book quite done enough yet to be one of the greats.
Given there were few if any great players playing for England 15-20 years ago, it was pretty obvious I was talking about world cricket. If you thought I was talking about English players from that period, why did you refer to players from a much earlier time?
You tried to assert something with the selective use of statistics. I pulled you up on it, and you chose to get huffy. Rather like the Concorde thread.
The greats would have been great in any era. Times and conditions have changed which make comparison hard, but a batsman that scored runs in the past on uncovered pitches would also have got them today. Bowlers that benefited from those conditions would have changed their games to suit - eg: I'm not old enough to have seen Underwood but my dad and uncle both did and are convinced with his accuracy and control, if he bowled in today's game he'd bowl a different line and get more drs'ed lbw's than he did back in the day. Tendulkar may have benefitted from 3lb bats and fast outfields but watch the way his feet and hands moved - with that talent he might have played differently in the 50's, but he'd still have been world class. Warne is simply the best of all time and would have been in any era.
Here's the controversial one. I'm not sure about the Don. Body line was designed to play on his weakness against the short ball, which wasn't (really) a valid tactic back then. He might well have adapted had he been forced to, and yes he'd have benefited from helmets and armguards and..... But for all that, he never really had to face an attack as fierce as the windies of the 80's, Lillee and Thommo, even Wasim, Waqar, Flintoff, Harmison, Curtley and Courtney, etc. And given the improvements in athleticism / fitness in all sports over the years, i dont doubt that while the quicks, Lindwall, Trueman, etc., would always have been quick, they were the exception, and sustained 90mph bowling from both ends for long periods was not common.
I'd pay well to see it though......
The thing is, you could reduce his average by 1/3 and he'd still be top of the list! He was still well over 50 in the bodyline series...
They do say Larwood was ferociously quick but I'm not sure who else there was in that era.
Edited to add: a really good article on this very issue: http://m.cricketcountry.com/cricket-articles/full-article/Busting-myths-about-the-Bradman-Era:-The-Don%27s-average-on-sticky-wickets-was-20-29/19492
I don't know if it's been mentioned already but the 'Hawkeye' prediction is actually a cone (or triangle) of predicted path of which only the central path is shown. So on each predicted line they show you on the TV you can/should allow a little more either side as it's all only theoretical.
Which is, as aracer pointed out, exactly what you are doing. Fact: KP, cook, Anderson and swann stand amongst the English greats. Any interpretation of the statistics shows that, unless you take a very blinkered, skewed view.
Oh, and you should revisit the Concorde thread after your mini-flounce, you might learn something.
My kid told me this .........
What do you call an Aussie who can handle a bat?
A Vet!
Pmsl.
Comparing between generations is impossible given all the changes in the game.
This is unfortunate - Brezza's out for the remainder of the season with a stress fracture in is back.
http://www.bbc.co.uk/sport/0/cricket/23720676
Bresnan's injury is a shame. I think he's done really well! wickets, economical and runs when batting.
I'd like to see Tremlett come in for him at the Oval if only to see what he's got after his injuries.
Agree. We'll miss his runs too (hopes to be proved wrong as cook and trott get the tons that ability suggests they should by the law of averages). Give Tremlett a go.
I haven't argued otherwise. Unfortunately this doesn't address your mistakes:
1. I was talking about the great players in world cricket of 15-20 years ago. You responded by talking about English players of 50+ years ago.
2. Only a very selective use of statistics would make them better players than some of those you cited, for example Trueman and Hammond.
Oh, and I think the Concorde and other thread bear adequate witness to the fact that I am much better informed than you on a very wide range of subjects. 😉
You can add delusional, boring and childish to your list of things you're better than me at too.
Anything relevant you'd like to add to this discussion? A few of us had started talking about the fact that one of the key players from the last test is unfortunately out injured. Or would you just like to carry on losing in a tedious point scoring game that I'm sure just about everyone is fed up of reading.
Back under your bridge, please.
http://www.bbc.co.uk/sport/0/cricket/23778598
More sour grapes? Is he for real or is this a wind up? Frankly; I've played in a few semi-decent sports teams in my time and the one thing i know is that you stand shoulder to shoulder with your team mates when times are hard. Broad doesn't strike me as someone who is likely to crumple if some nasty australian calls him a bad name anyway, but this is playing into England's hands isn't it.
I would think Broad would use it to fire himself up to make them pay for it where it'll really hurt, and likewise the rest of the team - you need a bit of siege mentality for a long tour away and this is perfect for creating it.
Broad to take another hatful this test. 4-0
Looks like Woakes in for Bairstow
Kerrigan for Bresnan? Does that mean no Tremlett? Shame if its the case.
Very silly comments from Lehmann, Broad is going to be furiously fire up now. Is he trying to make Malfoy bowl even faster? Thanks pal 😀
aussies to bat
I reckon Broad may well open the bowling!!
And I hope he cries and goes home. I don't advocate walking, but when you hit it to first slip it's pretty hard
so there you go he did what he would have done and what he would have expected an Ozzie.
I think we should send Monty as his guard for nights out 😉
I cannot see Broad crumbling tbh and when they target you like this you know you have got under their skin and they have taken the eye off the ball.
I also agree with the cat that it is better for the coach that they discuss the cheat Broad than the dismissal team they put out. It was not crickets finest moment though.
Woakes and kerrigan in for england and surprisingly the Aussies have shuffled the pack again
I'm sure it will be water off a ducks back when Broad cops some flak in Australia from fans. I'm guessing that it certainly won't be as bad as the stick given to England players at times in the last 40 years!
I wish people would stop saying he edged it to slip when he blatantly didn't.
Also, the argument seems to be that cheating is ok when you think you're more likely to get away with it. 😕
Wow, just wow.
That Lehmann whinge is the best whinge yet
"What's that Skip? You're crying in a ball of self pity? Why's that, Skip?"
"Blowers, my dear old thing"
Having read the full Lehman piece now.
'I don't advocate walking'
'Broad is a blatant cheat'
Cheating in respect of walking or not walking is like being pregnant; you can't be 'a bit pregnant'. If you know you hit it it doesn't matter if it went to the keeper or third man; if you don't walk you're a cheat* So by his very assertion that he doesn't advocate walking he's a cheat too?
* I disagree with this too actually, it's up to the umpire to decide and you accept that, rough or smooth. But read back in the thread for my view on that.
Tuffers suggests that to make Broad go home from Oz crying, they'll have to trap his finger in the door 😆
warner gone 🙂
Anderson's rogered him 😀
Go home and sell some socks, punchy bogan
he's looked hopeless this morning
what odds on Watson lbw, it's swinging enough 🙂
The bookies have stopped taking bets!
Anderson now equal with Willis in the England rankings
aussies look nervous, none of the usual belligerence.
well a nice slow start, anyone with tickets for day 5?
Clarke seemed keen to distance himself from lehmann's remarks as well. 'Relationships between the sides are fine' and 'you'll have to ask the coach about that' suggest that they might not be particularly united behind the door marked Visitors
Anderson is making the ball talk here 🙂
verbals between watson and anderson.
Probably giving him tips on how to bat
Anyone else grow up watching Terry Alderman, Merv 'the tache' Hughes, Allan Border, Steve and Mark Waugh... and wonder what the hell happened?
No, thankfully 😀
Terry Alderman vs. Gooch was a terrifying experience, sonny. 😉
