Made this quick video to show you a gadget a friend recommended to me
Refilling disposable gas canisters. Very sensible.
I've got a similar adaptor, works a treat. I can buy cheap 500ml canisters and use them to refill eye-wateringly expensive 100ml. Also I can ensure I start every trip with a full C100.
Fantastic tool - without it gas wouldn't be viable for me, I'd have to use meths.
Cool gadget, will have to get one of those. I don't understand the need to weigh the canisters though - surely both the big and the small ones are rated to the same pressure so you could just open the valve till they equalise?
why weigh it?
im looking to do this with helium. i cant see much difference tbh
It has been recommended to me to be safe not to over fill the canisters so I weigh them
Running dofe expeds I always weigh the canisters before and after each trip. It's a faff but means I can give near empty ones to bronze groups or use them in training whereas anything half full and above goes on exped.
Clever. That suggests you might already have a database of canister weights you might be willing to share (or do you assume all canisters are equal?)
FWIW I've recently started using meths in order to get around the partial canister/canister disposal problem but it doesn't really work well at low temps.
Perfectly safe. I have been using this for years. Beware overfilling. Liquid gas comes out of the burner. I don't weigh them, just shake it.
I don’t understand the need to weigh the canisters though – surely both the big and the small ones are rated to the same pressure so you could just open the valve till they equalise?
As TJ says the contents of a full canister are mainly liquid (you can hear it slosh around) which is why you can overfill.
C100 canisters (the small ones) vary a bit but they're all around 200g - Colemans are 190g full, the red MSR ones 210g.
And (because I'm lazy) are "winter" gas mixes available in the larger sizes?
Yeah, it's light but takes ages to boil a kettle 🙂
And (because I’m lazy) are “winter” gas mixes available in the larger sizes?
Yes but harder to find and a lot pricier, £8-£10 for MSR red isopro versus £3.50 for standard Coleman C500s if you buy them in bulk.
The trouble with winter gas mixes is the propane boils off first, the colder it is the more propane it uses relative to butane. So unless you run the cans until empty then refill from a full can you'll tend to end up with less propane with each partial fill.
Best bet is to just use butane (it's got a higher calorific value so works out lighter anyway) and save the expensive winter gas for those days when it's sub zero.
You can get propane only cylinders for proper cold weather but they're much tougher and heavier (more like a miniaturised version of the one you connect to a BBQ).
Keep meaming to do something similar for mrsmidlife's girl guide camp gear. They use a bunch of 907s (2.75kg) which are a rip off to refill, and a couple of 13 or 15kg for the burco and main stove. I'm sure I've seen adapters on sale before now, or they should be simple DIY.
Perfectly safe. I have been using this for years. Beware overfilling. Liquid gas comes out of the burner. I don’t weigh them, just shake it.
There is so much wrong with that sentence!
So this place, who wants to string up people for driving at 35 in a 30 or drinking 1 pint of beer before driving, think it's perfectly safe to decant flammable gas from a larger cylinder, at a higher pressure into an untested, disposable cylinder?
I work with compressed gases a lot and always treat them with respect.
There are good reason for the rules regarding hydro static testing and visual inspections of cylinders.
Keep meaming to do something similar for mrsmidlife’s girl guide camp gear.
Doing this for yourself is one thing, deciding it's a safe thing to do for a bunch of kids is quite another.
I use one, handy wee gadget, but I only refill a canister twice then dispose. Haven't died yet but wouldn't do it for anyone elses kids.
Gobuchal.
Sorry dude you have completely missed the point
The valves are not single use as you attach and detach them to the stove
You are refilling with the same mix from a big can to a small one. It's a similar process to the initial fill. Of course the cans are tested! And finally you show your lack of understanding as the pressures are the same.
I use the Coleman c500 (approx 440g of gas) and the performance c300 (approx 240g of gas). Sharpie the starting mass and then after each exped. It's a pain but otherwise I was ending up with dozens of partially used cans.
Silver and gold got a 300 each (cooking in 3s but under strict instructions to only open the next when the empty one was warm (in sleeping bag/up jumper) and empty.
When do you test them?
Not in that video, the bloke freezes the cans to reduce their pressure before refilling.
Also, you talk about over filling, how is that possible if they work at the same pressure? I don't how LNG behaves but that would seem very strange to me. When you connect the 2 cylinders, the pressure would equalise across both of them.
Doing this for yourself is one thing, deciding it’s a safe thing to do for a bunch of kids is quite another.
You're right, they should incorporate it into some badge work and do it for themselves.
Because the contents are mostly liquid not gas. What you're actually doing is draining the liquid from the larger can into the smaller one and it'll quite happily carry on past the nominal fill level.
The freezing thing isn't essential but it does speed it up especially when the larger can is getting low.
^Real lack of understanding right there!
What you’re actually doing is draining the liquid from the larger can into the smaller one and it’ll quite happily carry on past the nominal fill level.
^This, and to continue:
If you over fill the container, there isn't enough expansion room for the liquid part of the fill when the container get warm. This means that the container gets over pressurised AND WILL BURST if/when it gets hot. (If the container isn't fitted to a stove, etc. it *may* vent through the take-off instead when it gets hot - e.g. in a parked car...)
If you're going to do this, make sure that you actually understand what you're doing.
think it’s perfectly safe to decant flammable gas from a larger cylinder, at a higher pressure into an untested, disposable cylinder?
What circumstances should trigger the testing you're suggesting? If you need to test every time you screw something onto the cannister then you need to test every time you connect a burner. If you need to test every time the pressure changes you need to test all your cannisters every time the temperature changes.
This means that the container gets over pressurised AND WILL BURST if/when it gets hot. [snip] If you over fill the container
Nobody is advocating overfilling the container. The reason people weigh/shake the cannister is to ensure about 20pc space is left for expansion. If you filled a rigid Meths bottle brim full thermal expansion could rupture the container. If you filled a rigid bottle of milk brim full thermal expansion could rupture the container. We don't all stink of rotten milk from ruptured containers so most of us have managed to master the art of leaving a gap for thermal expansion.
If you’re going to do this, make sure that you actually understand what you’re doing.
Agree, but it's pretty basic stuff. My Chemistry/Physics stopped at GCSE and I understand. to be honest, on this topic I think the people who don't understand are the ones who are needlessly fearful. They just hear gas and get scared without thinking it through.
Having said all that I have never considered your point that the valve won't safely vent if a stove is attached. Not an issue for me because I don't leave the stove attached but it's worth remembering so thanks.
The lack of knowledge being shown here (with the exception of tillydog and elliptic) is a bit scary if I'm honest.
TINAS
Aren't the mixtures Azeotropes?
Aren’t the mixtures Azeotropes?
I dunno, but I *have* noticed that emptier cannisters have lower pressure and since pressure is relative only to temperature I can't explain that unless the remains at the end of the can have a higher butane ratio and lower propane.
Maybe a forum chemist/physicist can explain what's actually happening.
butane (it’s got a higher calorific value so works out lighter anyway)
Only it doesn't.
Butane has a higher cal:mol than propane
Butane also has a higher g:mol than propane.
The ratio is actually very very simlar to the point at which the cal:g rate is almost the same, (iirc propane is marginally lighter per cal, but not so as you'd notice).
A lighter can of butane produces less heat than a can of propane of even marginally more weight.
Edit values here https://www.google.com/amp/s/www.engineeringtoolbox.com/amp/gross-net-heating-values-d_420.html
oob it's entirely possible that you are right and that there isn't an azeotrope of propane and butane, I just assumed that there would be.
If you filled a rigid Meths bottle brim full thermal expansion could rupture the container. If you filled a rigid bottle of milk brim full thermal expansion could rupture the container. We don’t all stink of rotten milk from ruptured containers so most of us have managed to master the art of leaving a gap for thermal expansion.
For many reasons your analogy is significantly flawed not least because all the liquids you have mentioned are subcooled and have an atmosphere above them that is full on non condensables; an LPG mixture of C3 & C4 as contained in these cans is saturated so is a very different situation.
It's not really. If you have a fluid in a container with no gap to expand into it can split the container. The consequences might be different but even so, we don't typically worry too much about thermal expansion when we fill bottles and very few of us have had a bottle of anything split due to thermal expansion.
I'd also imagine that those metal cannisters have a fair bit of give in them so if you did overfill one with a stove attached it will bend a bit before a seam split. In fact if I had be asked to design one I'd have made the tolerances enough to survive being filled brim full in frozen Alaska and moved to direct sunlight in Death Valley without rupturing.
I feel an experiment coming on... 😀
Anyway, two specific questions above. Can one/all of the experts answer:
I *have* noticed that emptier cannisters have lower pressure and since pressure is relative only to temperature I can’t explain that unless the remains at the end of the can have a higher butane ratio and lower propane.
Maybe a forum chemist/physicist can explain what’s actually happening.
What circumstances should trigger the testing you’re suggesting? If you need to test every time you screw something onto the cannister then you need to test every time you connect a burner. If you need to test every time the pressure changes you need to test all your cannisters every time the temperature changes.
I feel an experiment coming on… 😀
I was joking, but seriously, can someone suggest an inert fluid with the same coefficient of expansion as Propane/Butane mix? I wanna try this and I'd rather not do it with gas. (Although at the bottom of my garden I reckon it could be done with gas.)
It’s not really. If you have a fluid in a container with no gap to expand into it can split the container
The limits that are in place for a saturated liquid are there not just because of thermal expansion they also have to consider the rise in pressure caused by the increased mass of gas in the head spaced. The fact that this liquid is saturated is the fundamental flaw in your analogy. I am the “chemist/physicist” that you are asking for. (Well strictly I’m a chemical engineer with about 25 years working with hydrocarbons but let’s not split hairs here).
My earlier post should have read "same pressures as in normal use" sorry for that
Its clear those of you who are saying this is unsafe have really not thought it through at all
1) the cans valve is designed to be fitted and removed multiple times. There is no limit to the amount of refitting possible marked on them
2) the design of the cans makes it impossible not to leave an expansion gap as the filled protrudes into the can below the top. there will always be a expansion space even if overfilled. Its actually very difficult to overfill to the point you get liquid gas out of the burner
3) I guess none of you have ever refilled a refillable lighter. Much more dangerous mashing two ill fitting valves together with no safety valve between them and no screw threads. do you pressure test a lighter before every fill? Do you refuse to refill refillable lighters? Please tell me how this is differnt
4) I do understand how gases work, how these gas cans work, how this gadget works and thus am able to say with certainty its perfectly safe assuming some level; of mechanical sympathy. The only possible issue is that if you overfill it you get a small amount of liquid gas thru the burner. simple to deal with - don't light it until this small amount of liquid gas has evaporated away.
Jeepers guys. This has been done by many many people over many many years and I have never heard of a single adverse incident.
Scotroutes - if you want to weigh cans for an extra safety check simply weih the empty one. When I do refills I make sure the receiving can is totally empty before refilling so you could weigh that then refil then weigh to see if its the empty weight plus the weight of gas the can is supposed to take
Less stuff = less pressure?
I am not a chemist and this is a wild guess but,
If you put a gas in a container and compress it, it will start to condense, to turn into a liquid. The greater the pressure, the more liquid is formed.
Ergo, the butane / propane mix is only liquid because it's under pressure, if you were to open the can it'd turn to gas (after all, the stoves don't burn liquid). As you use the stove, more liquid turns to gas inside the canister, less liquid trying to turn to gas => lower pressure?
Tj I have no doubt that refilling cans can be fine safely, provided appropriate equipment is used. “Some gadget off the internet” would not qualify to in my mind. But yeah you’re right, it’s not as if the behaviour of hydrocarbons is part of my day to day job…
I’m afraid not in this situation. If you considered a butane tank the pressure is the same no matter what the liquid level is as it is only a function of temperature as the liquid is always at its boiling point (it’s a saturated liquid)
gonefishin - so go on. Explain what is unsafe about this please. always willing to be educated
The valve I uses is a wee bit differnt to the one in the vid but the same principle
What about refilling refillable lighters?
I've not watched the video so forgive me if this is covered there in but...
The valve in a gas canister is designed to let gas out. In a lighter, the valve in the base is designed to let gas in.
They're not intend to be bidirectional valves are they?
Unless I'm misunderstanding stuff from ancient Science lessons if any of the contents are in gas form at all the cannister will be within it's design constraints because the gas pressure is related only to temperature, it doesn't matter how full it is *until* it's full of fluid. At the point it's fluid it's no different to milk/meths.
The headspace is purely to allow for potential changes in temperature.
It's fairly easy to liquify butane at RTP/STP. It's why they work in fridges as a coolant. The pressure keeps it liquid but as you increase temp more will become gaseous and increase pressure. There will be an equilibrium/vapour pressure/temp that can be worked out. But I'd say you need that volume for expansion. There will be a maximum storage temp for full cans so they don't go pop.
As a reminder to those who did high school chemistry. 1 mole of water in a liquid state has a volume of 18ml and mass of 18g if we could have that mole (18g) as a gas at RTP (room temp pressure) it would occupy a volume of 24,000ml (molar gas volume, this volume increases with temp). So yes expanding gases very dangerous.
They’re not intend to be bidirectional valves are they?
How do you think they get the gas in? 😀
We're talking about a gas. 😀
OOB - add to that what about refilling refillable lighters
Leave it in a room full of pressurised butane for a few 000 years until it permeates through obviously.
But seriously, just because it's good for 1 fill doesn't mean it's refillable. Try putting the juice back in a carton then carrying it round for instance.
Are you sure about that? Does that give the 20% capacity needed for LPG? Basically, it can't.
Again, not the point - the risk in overfilling is in overpressurising the container to the point that it bursts. Disposable cannisters don't have a separate pressure relief valve. They're designed to survive exposure to whatever temperature range with the factory fill. You go over that and they will not survive.
A valve is a valve. ON there cans when you screw in either the burner of the adapter there is a hollow tube that pushes into the valve and opens it by pushing the moving part of the valve inwards. I cannot see how the direction of the gas alters how it works at all.
Disposable canisters don't get tested (other than during manufacture) - they're meant to be filled, used, and thrown away.
Refillable cylinders are inspected and/or tested on an age basis when returned to the filling depot.
Pressure isn't relative only to temperature, in the scenario where you use the gas you are removing the gas, so less gas, this gas the effect of vapourising some of the liquid, as it vaporises this reduces temperature.
So you are doing two things that will have the effect of reducing pressure. Removing mass and cooling.
tilly dog -
The design of the cans means even if overfilled there is always expansion room. Yes I am certain of that.
How on earth can an overfilled can increase pressure if there is always expansion room. Pressure is a function of temperature not fill level. Basic physics!
Please - just have a look at a can and a wee think about it
But seriously, just because it’s good for 1 fill doesn’t mean it’s refillable.
I think it *is* refillable because the valve is good for a large number of connections and nobody has yet been able to offer a reason why these cans are not refillable. Maybe someone will in which case I'll change my opinion.
Because over filling reduces the expansion room (it's got liquid in it, not gas). Pressure is also a function of volume and the quantity of stuff in that volume - same basic physics.
Anyway, I think you're trolling now, so I'm oot! 🙂
so tilly dog - how about refillable lighters?
In use, pressure drops/the cannister cools. At low ambient temperatures I've had to warm the cannister with my hands to get any decent flame out of it. Winter mixes suffer less but partially filled containers can be next to useless.
Pressure isn’t relative only to temperature,
Pressure *is* relative only to temperature.
No tillydog - the expansion room contains gas! The design of the can is such that you cannot fill it completely with liquid. You are not using the pressure from the top can to pressurize gas into liquid. You are using a tiny differential in gas pressure to push liquid gas from one to the other
Its clear you really do not understand this at all. go and look at a can, take it apart to see the design. I have!
the valve part sticks down into the main chamber. any space above that cannot fill with liquid gas. It can only remain full of gaseous gas
How about refillable lighters?
So 1mole of a gas in a fixed volume has the same pressure as two moles in same volume at same temp?
No
I'm not saying it *does* but it might, it depends on how the valves are constructed as to the risks of damage - the nozzle is designed to engage and open the valve to a specific depth to allow outward flow, then close off under internal gas (or mechanical) pressure. The depth of compression is dictated solely by the mechanical interface and the nozzle on your stove will be produced to a specific design and tolerance.
Applying pressure beyond the mechanical engagement by filling could, theoretically, over depress and damage the valve.
Anyone who has ever refilled a cheap lighter will know the valves occasionally stick, and they definitely are designed to allow inward flow (note those same lighters have a different fill point to exit point)
~Scotroutes - have you tried the primus winter mix? It has a "wick" to help evaporate the gas at low temperatures especially when part empty and the mix is even more volatile - it comes in a brown can and not the 100g ones. It really does work.
Nope dangerous brain - the valve is opened mechanically in exactly the same way when attached to a burner and when attached to the refill gadget. Some stoves use these cans inverted so liquid gas flows past the valve and then its evaporated in the burner.
In use, pressure drops/the cannister cools. At low ambient temperatures I’ve had to warm the cannister with my hands to get any decent flame out of it. Winter mixes suffer less but partially filled containers can be next to useless.
So you reckon the emptier cans just cool faster as the gas leaves? That sounds quite likely thanks.
No
Gas pressure is relative to temperature and nothing else. More volume = more fluid, not more pressure. The gas (and therefore the can) remains at exactly the same pressure.
Google is your friend here.
Fair do.
Gas is removed which is the replaced by the liquid evaporating. The liquid evaporating needs energy from somewhere so the temperature of the liquid drops.
If the differential temperature between the atmosphere and the can isn't high enough then the energy flow into the can won't be high enough to evaporate the liquid quickly enough to maintain the pressure. Your hands are much warmer so heat transfer has a higher driving force and will be more efficient as the air is a rubbish at heat transfer. The mix of fuel is also a potential issue here.
Likely a higher propane content.
I may be able to shed a little light on the gas pressure / volume thing. more gas in less volume does equal more pressure when it is all in its gaseous state. However once you have reached a pressure high enough that some of the gas is liquid then the pressure will stabilize at whatever pressure is needed to liquefy that gas. thus a container that is part liquid gas and part gaseous gas the volume factor no longer matters - temperature is the only variable that alters pressure of a container that is part full of liquid gas and aprt ful of gasueous gas.
anyway - anyone interested in this its simple, perfectly safe and easy to do. I have been doing it for years and so have many other folk I know - including one chap who works for an organisation were they do hundreds of cans a year refilling them
the only possible is is if you overfil you get liquid gas out of the burner 0- sam as if you knocjk it on its side while lit.
It is impossible to fil these cans to the point that the whole can would be full of liquid with no expansion room. \just as well as that would be dangerous but it cannot happen
I may be able to shed a little light on the gas pressure / volume thing. more gas in less volume does equal more pressure when it is all in its gaseous state. However once you have reached a pressure high enough that some of the gas is liquid then the pressure will stabilize at whatever pressure is needed to liquefy that gas. thus a container that is part liquid gas and part gaseous gas the volume factor no longer matters – temperature is the only variable that alters pressure of a container that is part full of liquid gas and aprt ful of gasueous gas.
TJ I for one don't need an explanation from you on how the behaviour of saturated hydrocarbon mixtures.
anyway – anyone interested in this its simple, perfectly safe and easy to do. I have been doing it for years and so have many other folk I know – including one chap who works for an organisation were they do hundreds of cans a year refilling them
Messing about with hydrocarbons is never "perfectly safe" and you don't think that maybe, just maybe, a commercial enterprise might be able to achieve the task with far better control on the suitability of tools, location to manage the hazard associated with the transfer of hydrocarbons? And that this is very different to someone "doing it in their kitchen/garage/shed" (if you do want to do this, please do it outside)
I've heard that statement too many times for it to not ring alarm bells in my head.
Messing about with hydrocarbons is never “perfectly safe” and you don’t think that maybe, just maybe, a commercial enterprise might be able to achieve the task with far better control on the suitability of tools, location to manage the hazard associated with the transfer of hydrocarbons? And that this is very different to someone “doing it in their kitchen/garage/shed” (if you do want to do this, please do it outside)
In terms of the balance of risks. If I'm refilling a gas canister at home I can think of very few ways it could possibly go wrong. Compare that to meths. If someone kicks over my Meths stove there's gonna be burning meths all over me.
I think gas (including the refilling process) is safer than meths. Indeed I wouldn't run a meths stove with my 3yo running about, I happily use gas.
I'd be interested in the safety margins and where this 20pc figure comes from. I'm guessing they bottle at a set temperature but lets assume they don't. 20pc must be enough margin that they can safely bottle somewhere very cold and ship to somewhere very hot. Maybe that's more margin than required for a weekend camping where the bottle is filled at roughly the same temperature it will be used at.
I always leave the same gap the canister came with but I suspect that's OTT.
Or gravity. That's generally how I do it with both cans at the same temperature, and therefore pressure.
In a pinch you can do it with a 'straw' from a plastic shafted cotton bud and a slightly shorter piece of washer hose. Now that will get the chemical engineers frothing.
In a pinch you can do it with a ‘straw’ from a plastic shafted cotton bud and a slightly shorter piece of washer hose. Now that will get the chemical engineers frothing.
You can also fill a Coleman Canister with lighter fluid from a standard lighter fluid can. I've done it once and it works.
Unfortunately I did it in September which meant I had a cannister full of butane for most of the winter and in the cold after a few minutes it literally wouldn't push butane out at all. 🙁
Or gravity.
That's how I thought it worked. Liquid denser than gas, innit. Pressure differential will be minimal (as others have explained) and presumably will equalise between the two cans when you open the valve anyway?
TJ I for one don’t need an explanation from you on how the behaviour of saturated hydrocarbon mixtures.
I do. I thought that was useful.
…then you should probably be aware that there are errors albeit ones that won’t generally apply here.
Justy trying to shed a little light - tillydog was obviously confused over this.
I don't think you are not understanding gonefishin - just condemning something you have not seen.
No it is not pushing thru from gravity - it is the pressure differential. Yes the pressure does equalise between the cvans - its that equalising of pressure that pushes the liquid thru
gonefishing - I do actually understand that if you work in this field then it would appear dangerous as it would set all your alarm bells ringing. But in practice it is not.
I note no one has answered the point about refillable lighters. Similar gas, much more dodgy process
Much much smaller volumes (therefore the hazard is reduced) and a sight glass so the level can be seen, oh and as was actually said earlier a system that is designed to work that way.
gonfishin. Not all lighters can y see the gas level - look at clippers. The donor can is not significantly smaller. the valves are much cruder.
You aren't refilling the donor can.
Why I have no doubt that this can easily be done, I still think it's bizarre that the people on here that claim to be so safety conscious and careful in some areas of their lives, think this is a sensible approach.
I think doing it 2 or 3 times to a canister that is good condition is probably fine, anymore than that is pretty stupid.
You are using a potentially hazardous piece of equipment, way out of it's original parameters and specification, with no way of knowing it's in the same condition it was when you first bought it. Basically "it'll be reet". All to save a couple of quid. Fair enough, crack on, but if you use these on campsites near other people, then I don't see the difference from the people who drink 2 pints then drive their car.
I wonder how much the rest of your camping kit cost?
gobuchal - and its clear from your posts yo simply do noit understand the process 🙂
I do understand yor concerns - its the same as I get to fringe medicine. Its a result of your training
None of the folk who think this unsafe have actually been able to give any concrete reasons why
Once again - as you attach and detach the can from burners many many times there clearly is no limit to how often the valve can be opened and closed mechanically. Some systems use the can upside down so the valve passes liquid gas - so that is clearly no issue. It is impossible to overfil the cans to the piont there is no expansion room. You cannot get pressures in the cans higher than in normal use.
so what is the issue? Where is the danger? What can go wrong?
educate us please.
