Fresh poured concre...
[Closed] Fresh poured concrete pad...
18 Users
I had a 40sqm concrete pad poured yesterday... Anyone know how long before I can walk on it? and more specifically.. how long before I can let a BIG horse walk on it??
Additionally.. When I do let the horse on it.. Would it be sensible to throw some woodshavings or sand etc on the concrete to temporarily protect it from the great oafs feet?
Posted : 04/11/2017 9:31 am
That is a question for whoever supplied the pour, normal stuff takes several days but in our work we get stuff that hardens pretty much overnight. (I am not a civil engineer)
Posted : 04/11/2017 9:49 am
Wait until it's stable. 😉
Posted : 04/11/2017 9:53 am
a couple of days but get him to take his shoes off first
Posted : 04/11/2017 9:56 am
24hrs for 80% strength then 28 days fully set. Depends on type/mix assuming its compacted and reinforced.
Posted : 04/11/2017 9:57 am
I'd only tentatively tiptoe across it next day. The horse I'd leave for a few days, have you seen the mess they can make of a bridleway?
How did you resist writing your name in it?
Posted : 04/11/2017 9:58 am
Bet a cat walked across it before it set too
Posted : 04/11/2017 9:59 am
Depends on the strength and additives. Concrete has certainly come on in the 40 years since I was last involved in seeing it poured on site. It used to be covered in hessian and regularly sprayed with water for a day or two to prevent cracking. Watching a site over the road from our office this week they did a big pile cap pour and the next morning were walking around on it setting up formwork for the next lift.
Posted : 04/11/2017 4:07 pm
Wouldn’t you normally put a shed load of straw down anyway to make it more comfy?
Do horses only ever stand?
Genuine question.
I am not an equine expert!
Posted : 04/11/2017 9:52 pm
The weight of the horse is unlikely to break a slab poured on the ground even the day after, but I'd expect horseshoes to mark the surface in the first week at least.
Posted : 04/11/2017 11:19 pm
If you draw a cock and balls in it with a stick it's too soft, if the horse and draw a cock and balls in it with a stick it's still too soft but you'd have a moderately amazing horse
Posted : 04/11/2017 11:39 pm
We were told 3 days before walking on it (I think more to save potential blemishes) and then a month before building on it.
I wouldn’t let a horse on for a while
Posted : 05/11/2017 8:33 am
If it does, hoof it in the slats
Posted : 05/11/2017 9:12 am
You can case harden it by soaking it in a urea bath. Just cover the surface in stale urine and let it soak all afternoon. The nitrogen atoms from the urine will be absorbed into the crystal matrix and form a hard surface. If you can't source enough urine, guano is a perfectly acceptable substitute.
Posted : 05/11/2017 10:17 am
That makes it sound like you should let the horses on ASAP.
Posted : 05/11/2017 12:24 pm
You can buy urea easily - AdBlue, £300 for 1000 litres
Posted : 05/11/2017 2:48 pm
Give it till Monday, what straight was the concrete? Should be on the batch note / delivery ticket
Posted : 05/11/2017 2:51 pm
I think you have the sequence wrong here. Horses head in bed. Then new patio.
The horse should never encounter the patio.
Posted : 05/11/2017 2:59 pm
Urea can actually cause the surface of the concrete to scale off, not a good idea to soak a slab in it.
Posted : 05/11/2017 5:06 pm
This is complete nonsense, there is no such thing as case hardening concrete. You can cure it by covering it in damp hessian (as mentioned by slowoldman) or using a spray applied curing membrane. You can treat dusting concrete with Lithurin (spelling similar to urine, but completely different chemical).
Adding urine or guano will have no benefit, somebody is having a laugh 😆
If you don't believe me ask The Concrete Society http://www.concrete.org.uk/contact-us.asp
Posted : 06/11/2017 9:09 am
