Free bets from the ...
[Closed] Free bets from the bookies
7 Users
It being the Rugby World Cup next month, the only thing I ever consider putting a bet on just for a bit of fun, I was having a look at the odds online from various bookies. They all seem to have these free bet offers if you place a £10 bet with them. I've sat down with a bit of paper, and worked out that if I spend £10 each with four bookies, I can lay a total of £120 worth of bets, and if any of New Zealand, Australia, South Africa, France or England win the RWC, I would at a minimum just more than double my £40, and potentially (Allez les Blues) win nearly £400.
It's either a no brainier or I've missed something critical?
Posted : 23/08/2015 4:38 pm
 m0rk
Often you can't draw your winnings.... You have to bet it on other matches/games/whatever diluting their 'loss'
Posted : 23/08/2015 4:39 pm
Yes with free bets you have to 'bet through' a certain amount more before you can withdraw your winnings
Posted : 23/08/2015 4:42 pm
Ah I see
Posted : 23/08/2015 4:46 pm
Not always, and usually not with the smaller free bet offers. Have a read around 'matched betting' and see if there's something you've missed, but generally, yes, it is that simple. If you need to re-wager the initial bet it becomes more work, but I've made a few hundred quid in the past through using the free sign up offers and matching them with betfair.
Posted : 23/08/2015 4:52 pm
Not seeing anything in the T&Cs for any of the four I was looking at to that effect.
Posted : 23/08/2015 4:55 pm
Think you may need to exclude the free bet as you may only get back the winnings.
Posted : 23/08/2015 5:09 pm
I've deducted the stakes for the free bets in my sums, I assume that's what you mean.
Posted : 23/08/2015 5:26 pm
There does appear to be a time limit for 'using' the free bets. I wonder if that means you have to place the bet within that time, or if the event has to occur within that time?
Posted : 23/08/2015 5:30 pm
as mentioned above, look into 'matched betting'. there are a few sites that talk you through it, with online calculators etc.
its guaranteed profit so long as you follow the instructions. ive had a few hundred before it got too complicated, others have had thousands. i stopped as it became too time-consuming and i didnt understand the t&c's of some of the more complicated bets.
Posted : 23/08/2015 5:41 pm
Done now, £40 spent, anywhere between £85-£390 to be won as long as one of those five win. Think I'll leave it there though, not a hobby to get too stuck into I think 🙂
Posted : 23/08/2015 5:51 pm
£80 worth of free bets should be netting you a around of £60
What you have done is specifically called dutching, although obviously not quite covering all eventualities.
Posted : 23/08/2015 8:00 pm
Not quite all, no, but hopefully enough!
Posted : 23/08/2015 8:53 pm
