Forum Update
[Closed] Forum Update
425 Users
15.7 K Views
Is that a site-wide (mobile) issue?  Are iDevice users seeing the same thing?
I'm sure that will be discovered when the team test it on the Idevices and Android devices they are using for testing
If that isn't happening that it could explain what is going wrong, what platforms or devices are the team short of/not got one of?
Posted : 29/04/2018 6:28 pm
 gray
Regarding logging in on Android  I'm magically logged in on my Android phone now. I didn't try to log in... but somehow I am! Maybe they fixed something...?
Posted : 29/04/2018 6:30 pm
the next page forum is below the new thread box
I'm not sure what you're referring to here, I can't see that anywhere.  Is this the mobile site again?
It'd be really useful if folk specify desktop / mobile where relevant.  I'll edit my post.
A guide for some of the less intuitive features
I'll make a note of it.  I expect part of the challenge here is that writing such things whilst the forum is under heavy development means it's one more thing to keep up to date as stuff is changed.
Assume Improve Member History is heading back to what was there before?
Your assumption is as good as mine.  I understand that's what you guys are asking for though.
Does ‘favourites’ work for anyone?
Oooh that's a very good shout, thanks.
I’m not sure if this is what you mean by member history
It is, yes.
Posted : 29/04/2018 6:33 pm
I’m not sure what you’re referring to here, I can’t see that anywhere.  Is this the mobile site again?
Front Forum Summary page you get new post box and then the page numbers Chrome/Windows & Chrome/Android for it to be there it's been put there by design.
As for instructions posting pics, vids and emoji's hasn't changed - As I suggested before pin it in a sticky thread and you guys will spend less time posting the same answers over and over again.
Forum/Post History if somebody has a bright idea that would be better then perhaps they need to post some previews for comment - again if lots of people are asking for one thing then it makes sense that it works. No need to reinvent the wheel here.
Thanks for feeding these back, it takes effort to do all of this but it feels a bit neglected if there isn't a reply to it to say if any of it is happening. The engagement from Mark etc. has helped recently,
Posted : 29/04/2018 6:36 pm
That's actually a really good question.
Posted : 29/04/2018 6:37 pm
Ah!  I see what you mean.  It's the other way around on the individual forum indices, so is at best inconsistent.
Posted : 29/04/2018 6:41 pm
I previously suggested that STW provide access to a testbed system to a small group of users with a range of device/OS/browsers so that the testing is wider.
Posted : 29/04/2018 6:44 pm
I've just had an idea here.
The big challenge is to create comprehensive documentation and keep it current as the site evolves.  No-one's going to do that any time soon, the dev team don't have the time and the mod team don't have the inclination.
How about instead, if I create a "Forum Tricks and Tips" thread?  People can submit ideas (eg "alt-shift-D gives you Strikeout"), and I'll periodically collate the discussion back up into the OP.  Maybe it can also be a place for "how do I...?" questions, even?
Thoughts?
Posted : 29/04/2018 6:49 pm
It would need to be heavily moderated and curated. ...
Posted : 29/04/2018 6:51 pm
Screw that, then. (-:
Posted : 29/04/2018 6:52 pm
The big challenge is to create comprehensive documentation and keep it current as the site evolves.  No-one’s going to do that any time soon, the dev team don’t have the time and the mod team don’t have the inclination.
Just been thinking this over...
It's an out the box, off the shelf forum editor - right?
The documentation should be as simple as cut and paste with some tweaks from the documentation supplied by the people who wrote it.
If it doesn't work like it's designed to then it's a bug.
If not we appear to be rapidly heading down the patch on patch route which got us here in the first place.
If the Editor is crap then don't use it as the base.
How about instead, if I create a “Forum Tricks and Tips” thread?  People can submit ideas (eg “alt-shift-D gives you Strikeout”), and I’ll periodically collate the discussion back up into the OP.  Maybe it can also be a place for “how do I…?” questions, even?
Thoughts?
Just add the ones you know works, perhaps a line to report if something doesn't work any more.
Posted : 29/04/2018 6:56 pm
Is that a mobile issue? The Submit button “clicks” when you press it on the full-fat site.
Not much use if you run silent
I* also have an issue when attempting to navigate around using an andriod phone - some links / buttons take several goes to make them work and there is no indication that it has worked
that could well be me tho
Posted : 29/04/2018 7:02 pm
I meant it clicks graphically, not audibly.
Seems there's a general issue around button feedback on the Mobile site then.  I'll add it to the list.
Posted : 29/04/2018 7:08 pm
 Del
maybe this doesn't fit the remit but chrome/android/mobile, if you hit the link button it goes in to some crazy cycle of popping up the link window, the keyboard, then closing both. repeat.
Posted : 29/04/2018 7:12 pm
Hold that thought for now.  I'm going to at least try and collate a separate platform-specific list later.
I really should use the mobile site more, it'd be a lot of help in these discussions.
Posted : 29/04/2018 7:26 pm
@Cougar - Just to check as it might be lost in the page number refresh weirdness - did my last post on page 105 makes sense in terms of where it's heading?
Oh and page numbers/count not really working
Posted : 29/04/2018 7:30 pm
Ah - I certainly don't get any feedback when clicking a link, button or anything else when using my mobile - no graphic click
Posted : 29/04/2018 7:37 pm
maybe this doesn’t fit the remit but chrome/android/mobile, if you hit the link button it goes in to some crazy cycle of popping up the link window, the keyboard, then closing both. repeat....
Yup, mine too.
Posted : 29/04/2018 8:09 pm
And mine
Posted : 29/04/2018 8:34 pm
Ok, noted.  What keyboard, are you all using the same?
Posted : 29/04/2018 8:55 pm
I have had that sometimes as well.  sony experia phone, chrome and whatever keyboard it comes with
Posted : 29/04/2018 9:01 pm
I'm using the standard Samsung keyboard - the one provided with the phone.
Posted : 29/04/2018 9:02 pm
Motorola G3 running the last available update.
Standard Chrome keyboard.
Posted : 29/04/2018 9:32 pm
Oooh, i just tried hitting the link button (Samsung tablet on SwiftKey), does the same thing with the keyboard flashing on and off.
It's looking like it's a lot better than it was, though, things are looking up. 😊
Also  no feedback on the submit button here, either.
Posted : 29/04/2018 9:36 pm
 Del
wrt the link/android/keyboard issue - moto g5, android 7.0, google keyboard. about as stock as it gets without being a google phone.
Posted : 30/04/2018 8:35 am
Noted.  Cheers all.
Posted : 30/04/2018 9:22 am
Well I just clicked on page 108 and landed on page 104.....
Posted : 30/04/2018 9:31 am
108?
Post time traveler?
Posted : 30/04/2018 10:26 am
I'm liking the new page header:
Posted : 30/04/2018 3:59 pm
I'm getting about 10 screens of random characters at the top of each page. Lots of black diamonds with question marks. Looks pretty, but I'm sure it's not what was intended..
Posted : 30/04/2018 4:00 pm
Blackhawk down...?
Posted : 30/04/2018 6:04 pm
I'm logged back in! Yay!
Thanks chaps. Have a drink on me.
Posted : 30/04/2018 6:22 pm
Hitting the link to clear cookies, closing Chrome down and restarting the phone finally did it for me.
Dodgy Chinese Doogee ruftytufty phone
Android 7
stock keyboard
Chrome.
funnily enough I had no issues with my iPad, which didn’t help as ive been in France all weekend without it.
Posted : 30/04/2018 6:38 pm
Loving the new smaller font on the main forum page, then opening up a thread the font is much bigger.
Not a moan, it’s a compliment.. 👍
Posted : 01/05/2018 4:16 pm
Found a glitch - on iPad, when you post a pic, then select it, so you can edit/resize it, you can’t type in any of the boxes except the url one. I wanted to put a number in the size box and couldn’t.
Also, are we getting the last poster in thread thing back anytime soon, now that the migration to cloud is done? The replies created substitute is quite shit, you must admit.
Posted : 01/05/2018 10:23 pm
I'm amazed that they still can't spell favourite correctly.
Posted : 02/05/2018 5:43 am
Well I see that this forums returning back to its 2006 build of childish Next pop ups on every page you scroll through, then you have to click the X to get rid of it.
So, having hit the X four times to find this thread I’d like to know how many page impressions your advertising trackers are passing back to ad agency please.
Its looking more like Lings PCP website every day, and clearly the Devs are 11 yrs old an think pop ups are “cool”
Posted : 05/05/2018 6:21 am
Has the favorite function to bookmark a thread ever worked since the update? Because it doesn't, and its annoying.
Posted : 09/05/2018 8:00 pm
No, and it's on the list.
Posted : 09/05/2018 8:48 pm
 Euro
Not logged in in a while but tried yesterday and again today. Obviously i succeeded but it takes several stabs each time. My user name and password are the same but that Recaptcha 'feature' is a ballache and despite giving me the green tick of acceptance, it then informs me i'm unable to join in the frollicks. I was about to purchase 10,000 P's and 1,000 magazines but wont bother now. I'll be giving my monies to Lance and Specialized instead 😛
Posted : 10/05/2018 7:56 am
Being a P and just wanting the simple functionality of the forum itself, apart from a few minor quirks, it's not bad.
Ability to hover and see 'last posted by' over the end of a thread, would be nice
on mobile view, ability to go easily to last actual post, not just last page, that would be nice too
search that works.
Ability to find your own posts, not just your own threads.
None of the above for me are deal breakers though, just things i'd like to see that we used to have.
Posted : 10/05/2018 8:00 am
has mark popped in to update since I last asked the question somewhere about page 90 or something?
Posted : 10/05/2018 8:27 am
not fixing the insert link jumping around on mobile site?
Posted : 10/05/2018 8:35 am
Ability to hover and see ‘last posted by’ over the end of a thread, would be nice
Agreed!
Keep asking for them people!
Posted : 10/05/2018 8:38 am
search that works.
Doesn't it?
Posted : 10/05/2018 9:30 am
Search works for me (Chrome on Ubuntu 16.04 desktop), searched for "JennRide" as an older thread and "Cruise control" for a new one and both searches returned the relevant thread as the first hit.
Posted : 10/05/2018 9:36 am
Getting different search results Mobile (android/Chrome) and windows Chrome
Search term "Infinity War" mobile searches articles and STW publications, Desktop searches forum with google ads in there
Any other updates on the list you took to STW?
Posted : 10/05/2018 9:39 am
So, the "Replies created" page has been fiddled with? What a mess! What's the point of the [size=22][b]Reply to:[/b][/size] ??
Posted : 10/05/2018 9:49 am
It's just to prove that nobody is reading the feedback and insisting on reinventing stuff, same as the search thing above its almost like somebody wants to prove they are not testing across platforms
Posted : 10/05/2018 9:52 am
Hmm, just come across the log-in/cookies problem. My two weeks was up, logged back in, made the post four above this one, did a bit of looking around, came back and I was logged out and had to clear cookies again.
Posted : 10/05/2018 9:56 am
Same here - just logged me out, wouldn't let me log back in at all until I had gone into Chrome settings, deleted all the 15 STW cookies, quit from Chrome, restarted Chrome. There may be a few more users doing that over the next few days (or not bothering) as everyone who thought they'd sorted your log-in issue first time around is thrown out again.
Unless that was the user experience you were pitching for every few weeks or so...
Posted : 10/05/2018 10:26 am
Oh, mine has just gone pear shaped.
Logged out and on Chrome when i get the Captcha it doesn't open the window to tick the boxes with cars in... I assume Chrome is stopping the pop-up or my work laptop is... one or the other.
I've logged in with Firefox OK, but can't with my usual Chrome browser.
Posted : 10/05/2018 10:27 am
Can't log in from my phone. The Craptcha thing isn't working.
Posted : 10/05/2018 10:39 am
Out of interest, why do you need the Captcha thing for existing users trying to log in? I can understand it to stop bots trying to set up new accounts, but I don't get it for the rest of us punters.
Posted : 10/05/2018 10:49 am
I'd put money on there being no answer to that question.
Posted : 10/05/2018 10:54 am
Android paranoia innit.
Mark is terrified of robots. He believes there's a global conspiracy to take over STW with artificial people.
Little does he realise that Chipps is actually named after his primary component
Posted : 10/05/2018 10:57 am
Chipmunks?
Posted : 10/05/2018 10:58 am
He believes theres a global conspiracy to take over STW with artificial people.
West Yorkshire World.
Posted : 10/05/2018 11:00 am
🙂  Well played.
Posted : 10/05/2018 11:01 am
The Captcha addition is an annoyance as was the message about cookies on my stock Fire HD tablet yesterday and not allowing me to follow a link to Amazon.
Posted : 10/05/2018 11:16 am
Chipmunks?
Fried potatoes?
Posted : 10/05/2018 11:18 am
I've not yet seen the Captcha, or the cookie message, but it sounds like STW trying to protect our accounts, and inform us about tracking and data capture… which is exactly what they should be doing.
Posted : 10/05/2018 11:21 am
Once it's been properly tested and checked to make sure it works on at least the majority platforms...
Posted : 10/05/2018 11:24 am
 Rio
It really doesn't, it makes it appear that they don't know about these things so are throwing random things at it just in case it does any good. Anyway, seems the captcha has gone now which is just as well as I'd given up trying to use the forum on my phone - it's hard enough to work out what Google reckons is a road sign/store front/car on a big screen when you can see the picture; on a phone screen it was hopeless. Surprised this didn't come up when it was tested on small screens...
Posted : 10/05/2018 11:29 am
still can't log in though.... Please don't tell me i need to mess about and log out all my accounts from various forums again !
Posted : 10/05/2018 11:31 am
Phone still not having it.
Posted : 10/05/2018 11:40 am
Fine on iPhone and Mac..
Posted : 10/05/2018 11:43 am
I did the cookie clearing and restart of device as per the 'our forum' topic.... Still no good for me... Still can't log in on Chrome.
Posted : 10/05/2018 11:46 am
<div class="bbp-reply-author">bikebouy
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">
I think we have established the STW test environment then...
</div>
Posted : 10/05/2018 11:50 am
I'm getting used to Captcha. Its no big deal, which is just as well seeing as I still have to log in every single time I visit the site.
Posted : 10/05/2018 11:52 am
Black squares when scrolling, showing up for a number of users.
Posted : 10/05/2018 1:18 pm
Just had to delete all my cookies to be able to log in again....
Posted : 10/05/2018 1:20 pm
The most brilliantly sublime pun for some time 😀
Edit: And I’ve not been able to log in on my laptop (chrome) for weeks, despite trying everything, but I honestly don’t care anymore. (Not a flounce!)
Posted : 10/05/2018 5:55 pm
Ooh, that blue bit at the top is a step forward 😀
Shame you have to go into the thread to see it... but it's a positive sign most definitely!
Posted : 11/05/2018 2:09 pm
<p>Still having formatting issues. WYSINWYG</p>
Posted : 11/05/2018 3:16 pm
 sbob
Three times in a row I've clicked on the wrong thread as links slowly open up the page, when are we migrating to the new fast server?
Posted : 12/05/2018 4:01 am
Erm, I'm afraid we are already there and for most people it appears to be much faster.  Your problems might be related to ads rather than the site itself 🙁
Posted : 12/05/2018 7:16 am
Loving the blue box 👍🏼
Posted : 12/05/2018 10:19 am
Still have the html issues, keyboard still not working properly and there's still a 'u' in favourite....
Pretty fast though.
Posted : 12/05/2018 11:05 am
Page 53 / 56
