Ford 1.8tdci warnin...
[Closed] Ford 1.8tdci warning light help
3 Users
 hora
https://www.google.co.uk/search?q=ford+mondeo+warning+lights&client=ms-android-google&espv=1&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAWoVChMIkJmm2q6jyAIVi4ksCh0SGga3#imgrc=nZyWkkcR4qGvvM%3A
Plumber/tiler has this showing. Anyone experienced this so I could help him as a Friday good deed on my day off? 🙂
Posted : 02/10/2015 8:30 am
From that same link,
[i]Powertrain Malfunction - this light will illuminate when the engine management system detects a fault that requires the engine to be shut down and requires immediate attention by a qualified technician.[/i]
Discussed here,
http://www.fordownersclub.com/forums/topic/30731-what-does-this-warning-light-mean/
[i]could be any sensor related to the power train if im honest. its one of those errors where you may need it hooking up to a scanner for a full diagnosis. [/i]
Posted : 02/10/2015 9:30 am
Had this on our Cmax along with reduced power, turned out the missus or daughter had caught one of the multiplug connectors below the glovebox and dislodged it slightly.
When reconnected light went out and full power restored.
It's worth checking to see if the Mondeo has a similar layout (hinged multilingual connectors to fusebox below glovebox)
Posted : 03/10/2015 7:34 am
