There’s only one team deserve to win this and it’s certainly not us
Edit: right on cue 🙄
Well played Coventry 👏👏 deserved that goal. Shame.
Fabulous end to end goal. Class!
EDIT: BOOO!
I predict Antony to miss a pen
Ah dammit, think I cheered that goal more than I've cheered any of my own teams goals this season 🤣
I really feel for Coventry. Such a great effort. Deserved more from the game.
And now we get to get battered by City in the final again
How can you say there is a God?
Crazy. Football robbed of a legendary fairytale - and justice - by VAR.
Coventry were robbed there.
Now we get the the chance to get absolutely taken apart by Citeh again
Ugh. My anyone but City policy is going to be sorely tested.
Really hate the way they show the VAR offside decisions now, from an angle with the lines barely differentiated, it just makes it look dodgy even though it isn't. I hope the way the semi automated system is implemented next year gives a much clearer graphic of the decision.
At least it gives ten hag more time to get it right 😁
Sodding hell - drove up into the Peak to pick up LittleMissMC listening to the first half on the radio, Man U 2-0 up and sounded like they were all over Coventry, so when she got in the car I let her put her playlist on......
Got home just as VAR disallowed Coventry's fourth. WTF!
As a Coventry fan I feel robbed 🙁
I suppose VAR ensured we got the right decision and that's all of us want isn't it?
Is it ****!
If they are going to use VAR this way for offside decisions then I think there needs to a +/- not they were 1mm offside, that if they were less 100mm offside then VAR doesn't flag it & it's in the margin for error.
I agree with that ^ but then of course you'll still have the argument of whether they were 102mm offside.
To which the answer is that it's beyond margin for error then - the margin for error is (say) 50mm and we already allow twice that so they should have been flagged anyway, the 2mm makes no odds really
Needs to be a 'clear and obvious' error to overturn a goal, otherwise the decision on the pitch stands.
Getting the micrometer out and squinting at lines drawn on a still image taken at an angle from a 24 fps broadcast where even the precise moment the ball is played may not be captured is just nonsense. There's enough of a margin of error to render the entire exercise a waste of time.
If the VAR can see the error clearly on the first replay of the action, fine, let them intervene. If he needs to take a couple of minutes running through it frame by frame, he's about as likely to come up with the correct decision as the on-field ref.
Even using this as an example - the defender is already running back, the attacker is turning to begin his run. In the space of one frame of footage, that equates to potentially several centimetres difference in position in favour of the attacker, and yet we are expected to accept millimetres of difference on the image.
Needs to be a ‘clear and obvious’ error to overturn a goal, otherwise the decision on the pitch stands.
Fine in principle and certainly sensible for matters of opinion like fouls but linesmen have pretty much stopped making on field decisions for offside
To be fair, the only part of VAR that works pretty well is offside, yes being a toenail offside is infuriating for the team and fans, but it's against the release of the pass and the position on the players, of course it's not 100%, but it's a lot more defined than the VAR assistants re-refereeing games by showing refs a static picture of a specific angle, it always seems to be the worst possible appearance, as someone once said about VAR, with the freeze frame and angle, the VAR assistant can make a peck on the cheek look like a porno 🤣
To be fair, the only part of VAR that works pretty well is offside, yes being a toenail offside is infuriating for the team and fans, but it’s against the release of the pass and the position on the players, of course it’s not 100%,
That's the whole point though, if the judgement has been made on millimetres in a still photo, it's as worthless as the on-field instant decision because of the potential margins of error.
Linesmen not making on-field decisions is the unintended consequence of having someone in a back-room in Bedfordshire available to look at game-changing moments.
They are, it's just that the guidance says not to flag, allow play to develop and then flag (or not) at a point where you won't influence the outcome.
So as per yesterday's type of scenario, if the lino thought that was offside, they wouldn't flag. Allow play to go on and see what happens.... goal scored, then flag for offside because that's what they thought. VAR (with all its imperfections) then decides. It's important the lino still makes a decision though because there has to be evidence to overturn, otherwise stay with on field.
If they flag at point of the apparent offence, and the player stops, or hesitates, and play is influenced and THEN on review it was wrong - well, chance could be gone by then.
If it's absolutely clearcut, then they can flag anyway.
The process is actually sound despite the arguments. It breaks down when toenail-sized measurements are needed, hence there should be more benefit of doubt to attackers, etc. And also there's the possibility that in the ensuing play, that shouldn't be happening because it was offside, a player is injured or whatever. But that's a real edge case.
So with what is said above applying it to a scenario like yesterday - Lino doesn't flag, but flags after the goal is scored VAR gets involved.
Lino doesn't flag at all - VAR stays schtum, unless they've missed someone who is clearly offside.
There is definitely part of me that wonders if Utd scored that last minute winner then VAR might not've got involved,
VAR stays schtum, unless they’ve missed someone who is clearly offside.
Define "clearly offside", that's the only issue. What you described is what happens except with 'clearly' removed. If it's close VAR reviews and then tries to judge with mm precision something that can't be adequately judged at that precision.
I mean - define 'when the ball is played'
The ball is squishy, a foot flexes, do you measure from when it first makes contact? Or contact is broken again? Halfway between? ISTR contact between a golf ball and club is about 1/200 of a second and that's a hard ball and hard clubface, maybe a foot and football is like 5x that? 1/40 of a second? Not a lot but if a player is running at 8-10m/s (Mbappe can do 10.6) that equates to 800/40 = 20cm. A player could be just onside when the ball is kicked but 20cm offside when it leaves the foot again.
If lino is confident of offside, they should flag it. Yes, that will lead to situations where a promising attack is halted, but in my mind it's better for fans to momentarily grumble about that than have the emotion of celebrating an historic goal cut short by a decision so marginal that you really can't be confident about it.
Every little thing - the frame rate, the resolution, the angle (does the line get narrower as it gets further away?) and even the question of whether the pitch is perfectly flat makes a decision involving a few mm more questionable. Probably impossible for the VAR to draw a pixel-width line that sits exactly at the end of a player's boot, or to find a video frame which marks exactly when the ball was played.
Even this, from the PL itself.
Firstly, for marginal offside decisions, after the one-pixel lines are applied, the VAR puts on the thicker broadcast lines and where they overlap, those situations will now be deemed as onside.
Can we see any evidence of a gap between the two lines?
If lino is confident of offside, they should flag it. Yes, that will lead to situations where a promising attack is halted, but in my mind it’s better for fans to momentarily grumble about that than have the emotion of celebrating an historic goal cut short by a decision so marginal that you really can’t be confident about it.
I disagree, officials would be vilified for stopping an attack that is later shown to be onside.
The issue isn't the process, it's that the technology isn't good enough to go to one pixel lines. As I said before, we need a clear water type ruling, so anywhere up to say 100mm offside by the technology is still considered onside. Then any arguments about whether it was 98mm or 102mm is irrelevant because they already had benefit of the doubt and some.
Can I just say that 5 years ago today, I was at VP watching Villa play Millwall in the Championship.
On Saturday I'll be at VP watching Villa play Chelsea in a game that could all but secure us 4th place and UCL next season.
5 days later we'll be in a Euro Semi-final.
It's why we all love the game. It doesn't matter how crap things are, there's always the chance that glory is around the corner.
Long time Villa fan, started going when I was six, I'm 52 now. I've had some great times over the years but the last twenty years in the wilderness have been miserable, I've watched some dross. It's the hope that gets you isn't it? Weirdly, for the first time for as long as I can remember I will miss the next two games due to prior commitments, no Chelski or Olympiakos for me. I guess I'm not used to this degree of success and normally expect us to be out of any cup competitions and definitely not challenging at the top of the league. I need to find a bar in Palma, Majorca. Any suggestions?
Just listen to the commentary via Villa TV on the club website. I had to do it in The Canaries last month. It’s old school, like listening on WM or BRMB 😀
That's not a bad shout I guess, although if it's Mark Regan it can be a bit of a hard listen.
How ****y is this? (Rights management)
“While Topps holds the overall rights, Panini retains aspects of rights relating to some teams, the Times reported, meaning five of the teams, including England, can be shown in their kit only by Panini.
In addition, Panini holds the rights to individual players meaning Topps has been forced to fill out squads with other players. For England, Luke Thomas features, who has never been selected.”
Given Ten Hags comments today on the ‘great performance to be proud of’ on Sunday, he seems to be giving Liz Truss a run for her money in the ‘utterly delusional and quite possibly completely mad’ stakes
I've never seen Truss & Ten Hag in the same room together. Makes you think eh?
Id be interested in knowing what the wider footballing world thinks of Forests latest drama, amatuer hour from a fed up petulant owner or the flag bearer for disgruntled fans Prem wide?
Think folk are fed up, especially the Forests and Everton's who are also being penalised by the whole FFP debacle as well.
VAR should benefit the game, but the whole issue about 'interpretation' of handballs, contact, etc is ruining it, especially when you have the VAR assistant provide a freeze frame of the worst angle, so providing a pretty one sided argument.
Don't think i see a match go by now without some weird VAR intervention, or a lack of an intervention when the referee has made a decision that's a bit suspect, they're all defending each others decisions by backing them 99% of the time, and i always say, having referees being in charge of VAR is a recipe for disaster, they are trained to ref a game, not provide data to a referee to assist decisions that are easier with that data, rather than overruling them.
I'm Forest and it's been relentless to the point of me wanting to give up and go ride the bike instead.
It's not even the slight differences in judgement, it's Toney moving the ball (and foam a yard) and scoring off a free kick, it's the Boly getting sent off when the Bournemouth player stamped on him, and the 10 mins added at home to Man U when they're chasing the game, I used to think the conspiracies where all nonescence but I'm about done with it.
I get it'll even itself out over a season usually, and rival fans won't mark our lot as saints but just seems to be never ending at the moment.
On balance, VAR hasn't really stopped the vilification of match officials, or endless re-runs of controversial decisions. It's just transferred those officials to a windowless room in West London.
If anything, clubs and fans are behaving worse towards VAR officials - case in point being the Notts Forest tweet pretty much libelling the VAR from their game at the weekend.
It’s always been thus.
Is there any difference between the Forest tweet and Maureen blaming officials for his latest loss, or Fergie pointing at his watch?
There's a significant difference between saying a ref is shit at their job, and implying that they are biased because of their own club allegiance.
https://twitter.com/NFFC/status/1782056187652960764
Also a big difference between a manager moaning at a press conference, and the club sticking it out in black and white as an official communication.
Maybe they’d just watched the Inside Number 9 episode “ the Referee’s a…”
Looks like Liverpool are also after a bald Dutch bloke as their manager.
Need to go back to the 70's when refs used go for a pint or 6 with the players. I expect VAR doesn't drink though.
This Arsenal Chelsea game's not too bad
When I read the headline 'Slot a candidate for Liverpool manager role' I thought I'm not a fan but murdering them before they've even started seems vindictive.
Two tricky top of the table clashes in PL and Championship tonight !
Arsenal haven’t done their goal difference much harm tonight. A clean sheet and 5 to make it +56
Fair play to them. They’ve handed out some absolute shoeings this season
5 nil in both games, who'd have backed that
At least that answers the question as to what Chelsea would be like without Cole Palmer.
Two nineteen year old players from the same club arrested and bailed on suspicion of assault and rape
https://talksport.com/football/1840698/two-premier-league-footballers-arrested-suspicion-of-rape/
Well, seeing as my predictions on Sunday were so depressingly accurate, I reckon we’re going to plunge to new lows and lose at home to Sheffield tonight, 2-1 or 3-1 after scoring first
Think I might stick a few quid on it this time, to make it a bit more bearable
Odd how things have changed under VAR: Everton were just awarded a penalty, Allison booked but as it was deemed offside both were withdrawn.
In the stone age I doubt a penalty would've been awarded in the first place.
Brilliant! Not a bad evenings football.
Thankfully I lost my United bet (I may start betting against us all the time) but I had a Mrs B-esque feeling Everton would be well up for properly derailing Liverpools title challenge tonight, so I stuck a few quid on them at 9/1 😂
Great result for Everton - they should be safe now.
Dear god, Sturridge is an absolute clown! How the hell did he get a job as a pundit? He’s arguing with Rooney, thinking he knows better. Remind us Daniel.. what did you ever win?
Sturridge and Rooney - a real meeting of minds!
used to be 40 points had you safe, when did that change to 30?
united were behind twice, and only got in front with a penalty to a team with 16 points after 34 games
It’s the ETH way. Hopefully they win every game from now until the end of the season, bar the FA cup final, but put up a good fight, to show Chelsea Jim he’s worth keeping on.
Klopp really is out of steam isn’t he? Looks gone. Good on him for making the right call for himself.
Everything’s relative. Have you not watched us this season? This is just standard fare nowadays. We’re absolutely dire, but 3 points is 3 points, as TH will be clear to point out as he praises another ‘fantastic performance’ under his stewardship
When the even playing field became a very uneven playing field.
As above, the teams coming up now can only dream of getting into the 30s in terms of points, the EPL is getting more uneven every year, FFP is making it even bigger now.
Agreed. As a supporter of a non 'big 6' club, ETH's unfathomable ability to get results, despite playing dire football and draining the confidence out of players, is a blessing. It should ensure that Stat Man Dave (Brailsford) keeps him on for next season. Although I wouldnt worry if they move for Southgate. In fact as an England fan....:)
As an Evertonian today is a good day! Enjoying my day of winding up the Liverpool fans in the office….only happens once a decade so they’re obliging me!
I got a phone call at 5pm last night asking if I wanted a ticket for the game….i hate Derby’s so turned it down….what a mistake that was!! I do have a ticket for Saturdays game so you can guarantee normal service will resume and Everton will get beat!
Looked like a tricky away fixture for City. Making light work of it though.
Citeh kicking into gear again and just doing what they do at this point in the season
They're a machine
I’d say they’ve had a bit of help from the ref. Dubious free kick for Foden’s goal and Brighton denied a clear pen. But I’m clutching at straws - they’re cruising and can go up a gear if needed.
Do they look better without Haaland?
The old Liverpool (80's) team used to do what city do each season - look just above mediocre for 90% season and then just click into a 5th gear come March.
Judging by last nights substitutions, Pep isn't going to aiming make up the goal difference on the gooners, I think city could have scored a few more last night, but he brought important players off instead to keep them fresher for the run in.
Cant believe that after tomorrow's game, there will be 3 games difference between Villa and Spurs. Ridiculous at this stage of the season.
I've got tickets for the Villa v Chelsea game. Buzzing for it, can't beat a big game under the lights at VP.
A special place.
Villa will be fine. Spurs have Arsenal, Chelsea, Liverpool, City (and Burnley and Sheff Utd) to play yet!
I'd just extend the trophy lease for another year at this point to Citeh.
I reckon Spurs will do us over at the weekend. Still think we are finishing 3rd.
Haaland has been missing chances he took for fun last season. Don't know if he's just a bit knackered, or teams have worked him out a bit.
I think most of the problem has been slightly fewer goalscorer options all round this season. If you don't have Gundogan or Mahrez hovering around, it's slightly easier to set up to defend against a single spearhead player. De Bruyne missing a large chunk of the season again made them both less creative and more reliant on Haaland. It has allowed Foden to develop, though.
Arsenal should be kicking themselves. They are, in my eyes, the team of the season, this is one they should have converted. Still time for City to drop a couple of points though.
You’re a glass half empty kinda guy eh? Arsenal have been great - so solid defensively, which always gives you a chance.
