Flat Roof Repairs
[Closed] Flat Roof Repairs
9 Users
Anyone recommend a paint on type sealant for a felt flat roof that has a small leak?
Posted : 28/04/2020 10:49 am
Cheese sauce?
Posted : 28/04/2020 10:52 am
Acrapol
Its a fibre reinforced acrylic.
It's not bad stuff to eek a roof out.
https://www.acrypolproducts.co.uk
Theres a few producers with different names all very similar
Posted : 28/04/2020 11:07 am
I've used this on our flat garage roof after it started leaking:
https://www.screwfix.com/p/cementone-roof-repair-compound-grey-1kg/10990
Really good stuff but nasty to work with.. buy a cheapo brush and just bin at the end of it.. it's really thick soup like stuff but works a treat. The small pot (linked) doesn't go that far so if you've got a large area to cover get the big'un.
Thanks guys.
Can you remember roughly what kind of area the small pot covered please?
Anyone else have anything to recommend please?
Posted : 28/04/2020 12:50 pm
Not cheap but will buy you years more service. Worth coating the whole flat roof. - https://www.tufftechpro.co.uk/
Tech guys are very helpful if you give them a ring.
Posted : 28/04/2020 1:34 pm
Thanks guys.
Tech specs says that 1-2kg covers 1m²
Posted : 28/04/2020 2:24 pm
I used Cromapol which is similar to Acrypol and others. Nasty sticky stuff and you’ll chuck the brush away after but it held off a replacement roof for a couple of years.
The problem is that often where you see a leak inside is nowhere near where it’s coming through the felt, and whatever board is underneath can soak up quite a bit too.
Posted : 28/04/2020 6:37 pm
Isoflex
Did my houses flat roof last year, tenants haven’t mentioned the issue again, after this was recommended by a friend (You can get it from b&q)
Posted : 29/04/2020 2:06 pm
Used the stuff linked to above from Screwfix this morning.
I know where the leak is coming from. Same place it came from last time. A crack in a joint that's been repaired before.
Seems pretty good stuff lets see how long it lasts.
Posted : 29/04/2020 3:02 pm
I used both Acropol and Flexacryl in the past. Basically they have glass fibre strands in the paint, from memory they will ‘bridge’ a 10mm gap. Very good for a repair
Posted : 29/04/2020 3:49 pm
