fitting hinges to i...
[Closed] fitting hinges to integrated washing machine door
3 Users
I've got a door that will cover the washing machine but need to drill it for the hinges. Where could I get this done?
Anyone know what tool is needed to do this? Is there a standard jig?
Many thanks
Posted : 17/01/2015 5:26 pm
Ha, The bain of the Kitchen fitters life!
You need a 35mm TCT Hinge hole cutter and a steady hand, or a drill press/router ideally.
There's no jigs available I don't think, I always mark up carefully, and drill by hand if having to do it on site with my plunge router. I usually set the hinges on the machine then measure down from the worktop, remember to allow for door offsets. Drill a bit at a time as on thin doors (15mm) the hinge hole will be nearly all the way through the door.
Posted : 17/01/2015 5:33 pm
[url= http://www.axminster.co.uk/cabinet-hinge-installation-jig-bit ]http://www.axminster.co.uk/cabinet-hinge-installation-jig-bit[/url]
Bit plus marking out jig.
You still need to measure where on the door to put it though.
Posted : 17/01/2015 5:42 pm
The jigs are for normal cabinet hinges, which can be different offsets to washing machines. hand marking is a better way for me.
Posted : 17/01/2015 5:45 pm
Thanks guys
Posted : 17/01/2015 7:10 pm
