Hello, So im finally going to be starting soon...got the go-ahead from the commune so all is ok. Wood has been ordered and i managed to find a door & frame as a kit that wasnt too expensive.
Question now is how do i finish this off? Im doing it like this:
1. Timber frame structure
2. OSB walls with black, UV stable housewrap and vertical furring strips (covered in the housewraps suggested black tape, UV stable)
3. Horizontal larch cladding with spaces in between (because i like this and i cannot find shiplap in stock in switzerland..)
The door i chose is external opening (with security pins that prevent it from easily being broken into when closed..). If i insert the door frame to be flush with the ply (so that i can screw it into the actual framing of the shed) how do i go about finishing this off so that its neat and still waterproof...?
Anyone?
