Fenderish amp - STW...
[Closed] Fenderish amp - STW Guitarist Hive mind
8 Users
I'm looking to invest in a new amp
must be
'Fender' Clean
less than 15 watts
all tube
FX loop
12" speaker
Considering
Evil Robot - a bit loud
Bugger, Bike forum again!!!
Bogner New York - very expensivo
Fender Blues Deluxe - but too much wattage
Fender super champ XD/X2 - no FX loop
An experience with the about or others to look at?
Thanks
Plum
Posted : 18/05/2012 9:37 am
Blues Junior? Love mine and use it farmore than my Hot Rod Deluxe....
Posted : 18/05/2012 1:27 pm
Tried a blues Jnr and Blues Jnr Pro on Saturday. Not great amps in my humble opinion
Posted : 18/05/2012 2:30 pm
Got a price limit? 🙂
A Two Rock?
Oh, and thread moved to Chat Forum. HTH
Posted : 18/05/2012 3:06 pm
How about a Boogie Lone Star Special - it's 30W, but you can run it at 5W open ended. Two channels, the best tube/spring reverb in the world ever, amazing clean tones and a second similar or more gritty channel if you fancy.
Posted : 18/05/2012 3:31 pm
Fender blues deluxe. Swap out the 6l6 power valves out for a pair of 6v6s and re bias. Gives you an 18w blues deluxe.
Posted : 18/05/2012 3:34 pm
you want a deluxe reverb really, or a princeton reverb. But they don't have fx loops (and the princeton is a 10" speaker)
but you don;t need FX, cos you will have fender reverb and vibrato
I think blues juniors are fine personally for the money (as good as a blues deluxe just quieter) - I've just got a 2nd hand one on ebay. I might look at modding it at some point though
Posted : 18/05/2012 3:51 pm
I borrowed a blues Junior a few years ago, I thought it sounded OK, but it burst into flames :-(. I watched the repair guy fix it, and the standard of construction on the outside is a lot better than the inside. It was really built down to a price.
I ended up with a Cornell Romany, no FX loop, but sounds good and has a useful power scaling function. The EQ bypass gives it a very different voice, which is useful when recording.
I've too have been after something with an FX loop....the Fender Supersonic 22 looks good, but i've not tried it, and I never hear it sound really good on youtube demo's. The most interesting amp I tried of that ilk was a Bogner Duende...it was really nice, quite expensive, but a bit different to the run of the mill. The example I played was a bit tatty (it looked like it had been in the shop for ages), otherwise I'd have gone for it.
If your anywhere near the East Midlands, you'd be welcome to check out the Cornell.
Posted : 18/05/2012 4:16 pm
PS, after Monday, you'd be able to try it with...
http://www2.gibson.com/Products/Electric-Guitars/SG/Gibson-USA/Jeff-Tweedy-Signature-SG.aspx
Posted : 18/05/2012 4:18 pm
I've got a random desire for one of these:
http://www.gak.co.uk/en/ibanez-tsa15-guitar-combo-amplifier/56914
However, I can see a new Fender Excelsior in my future first.
Posted : 18/05/2012 4:26 pm
The lonestar looks really nice, do you play a Special or a Classic Chipps?
Posted : 18/05/2012 4:33 pm
I tried a Marshall 1w JTM in GAK the other day, took all my will power to walk away. 10" speaker, but god it sounded good. The Casino Elitist they gave me to try probably helped.
Guitars are a bit like bikes aren't they. n+1 definitely applies & you nearly always regret what you've sold.
Posted : 18/05/2012 6:48 pm
I've got the Special. I think the Classic is 100w/50w/10w whereas the Special is 30W/15W/5W
Footswitchable channels and a solo boost too. Series (valve powered) FX loop plus lovely, lovely valve reverb. S/H they go for a little over a grand.
N+1 indeed 🙂
Posted : 20/05/2012 2:29 pm
 emsz
I normally say a frontman for an amp questions, but then i saw you wanted a loop. Supersonic then. 🙂
Posted : 20/05/2012 6:28 pm
I want this to go with my jtm1..... See above 🙂
Then I can use clean/dirty/wet/dry via a 2 amp set up
Not asking for much I know
Might have to try the vibro champ xd
Thanks for all your carefully considered replies though
Money no object on this project
Posted : 21/05/2012 11:42 am
If you're not using your amps for distortion, then why not run your effects straight into the front end and ignore needing an effects loop? Run two JTM1 amps then!
Posted : 21/05/2012 3:33 pm
Jtm1 don't do fender clean 😯
Ordered a vibrio champ so I'll see how that works
Ta like
One day we'll have to have a gear off!
Posted : 21/05/2012 4:13 pm
