I don’t get the love for Hulkenberg….seems to me he’s a mediocre mid-pack driver who stayed around way too long
Ross Brawn says Hulkenberg was their next choice as a driver if Hamilton hadn't signed for Merc.
Rumblings on social media of a possible return for Jerez and Istanbul for the tail end of this season to fill the gap prior to the middle east rounds. Istanbul esp would be a welcome return.
So 'Quali Modes' to be banned after Spanish GP. Not sure how they're going to police that? They'll just add a dial that goes up to 11!...
It's not just qualifying modes.
During the race, they often turn the engine down for reliability, or save fuel or do the opposite to overtake.
The only way of doing it is to remove the ability of the driver to change engine settings at all.
What about changing the mode to start the car?
All seems a very big can of worms and a big change at such short notice.
That seems to be the intention. I'm not sure how the different modes work.
The max fuel flow is regulated and oil burning has been minimized. Obviously, they can control the boost level, fuel richness, and ignition timing. The qualifying mode reduces durability massively, so it stresses the engine much more than standard mode, but the increase in power is only about 50 hp. My guess is that Merc figured out how to run higher boost with a leaner mixture, leading to higher temperatures in the combustion chamber, hence the reliability problem. Apparently they studied diesel engine combustion when they started developing their engine, which probably means they were researching how lean mixtures combust under high compression ratios.
Problem is, the regulations limit the fuel flow, not the combustion characteristics, so Merc must have found some way to change the combustion characteristics for short bursts. Maybe Merc used oil additives to alter the combustion characteristics in qualifying mode, as an octane booster rather than a fuel. Apart from something like that, I don't see how they can cheat if fuel flow is limited accurately.
wardee
MemberIt’s not just qualifying modes.
That's not he only way of doing it, but is the simplest. You could also for example mandate that the qualifying mode is also used for at least X laps in the race.
I just can't see that the rule change will stick if it's implemented as you've said, it's too far reaching.
It's not even proper Quali Mode! BHP so high you can't measure it and an engine that melts after 2 laps - that's Quali Mode! 🙂
the-muffin-man
SubscriberIt’s not even proper Quali Mode! BHP so high you can’t measure it and an engine that melts after 2 laps – that’s Quali Mode! 🙂
Yep, the good old days 🙂
https://twitter.com/ScarbsTech/status/1293912716411772929
Give them a manual gearbox as well while you're at it.
Give them a manual gearbox as well while you’re at it.
Nah, flappy paddles are common on road cars so they can stay, but to echo road car technology they should only be able to choose from 3 engine modes - 'Eco', 'Normal' and 'Sport',
thepurist
Nah, flappy paddles are common on road cars so they can stay, but to echo road car technology they should only be able to choose from 3 engine modes – ‘Eco’, ‘Normal’ and ‘Sport’,
"scenario 7 please Lando, that's Sport+ mode and air conditioning set to off"
my understanding is that they won't ban quali modes, but will mandate that teams must then use those modes for a certain percentage of the race...presumably enough that it would either destroy the engine or use all the fuel (is that even possible with fuel flow restrictions?). I assume the FIA have a way to check what modes were used for how long
I'm still struggling to see the point of the fuel regulations. Can't help but feel that "here's x litres for the race, off you pop" would be far simpler and more entertaining whilst still having eco credentials
I’m still struggling to see the point of the fuel regulations. Can’t help but feel that “here’s x litres for the race, off you pop” would be far simpler and more entertaining whilst still having eco credentials
agreed. but then I struggle with a lot of F1 regs at the moment. Now they've agreed a budget cap, they should throw away half the tech regs and just allow teams to innovate to their hearts' content within that budget cap (even if it's impossible to police)
Me too.
You've got 100 litres of fuel. If you can make a 7L V16 with 3,000hp get to the end of a race on that then hats off to you, that would push innovation. Next year you've got 90 litres...
Talking of engines and quali modes though, a serious question. Why don't Williams (and Haas/Alfa) engines go pop more often?
Take Williams in 2019 for example. Pretty much guarrenteed to be last, but can pretty much get through a season on the required number of engines. If they turned them right up for one race, what could they do, almost certainly score points, maybe good ones. OK, this would effect reliability and they would go bang at the next race or the one after, but then put a new one in, take the penalty and start at the back (as they would anyway) and repeat next time. Better to get half a dozen points finishes and a load of DNFs than a season of 20th places surely? Wouldn't work for the big teams, you need points almost every time to stand a chance in the championship. Might be expensive, but money is shared out according to success so maybe cost-neutral or even beneficial?
What's the lap time difference between pootling around preserving engines and giving it full beans? With fuel on board and tyre wear it will be slower than quali but should still get them well into the midfield (briefly)
They will be easily able to police the Qualy mode use thanks to the standard ECU. What I think they're going after is the way that the factory teams will have multiple maps to use all the time whereas the customer teams only get the basic maps and nothing more. I remember Williams and then-Force India both saying that they didn't get the same maps for their engines as Merc had a few years ago. It could also be a way of siplifying things for the general audience who will understand having 3 different modes (Eco, Sport, Sport+ as thepurist mentioned) as that's similar to their own cars rather than having 10 modes that can have a massive effect on the car's performance.
Personally I think it's a waste of time as the modes are no different to the previous generations where the drivers had turbo boost or just used more revs for a small amount of time. I enjoy the skill and strategy of using their equipment cleverly, balancing reliability against outright performance or simply running out of fuel. I feel it'll be like team orders, the teams will find ways of doing it anyway so it'll be made legal again soon.
They really wouldn't. They'd run out of fuel before the end of the race for starters.
they'll just run a relatively "high" output map and change the rev indicater/gear change indicator lights 1. quali normal 2 quali fast 3. race normal 4. race push 5. race economy. and a ultimate rev limit for each
The fact that there are only four engine manufacturers in the sport including three works teams must make for a certain amount of pay to win among the customer teams.
Both Williams and McLaren appear to be now neutral in the wake of Mercedes' defence of Racing Point. McLaren will have pissed off their engine supplier, let's see what happens next.
Regarding Williams and their engine maps, they may not be able to afford new engines when they go pop. They probably analysed the situation and think they will get better gains from spending that money in other areas.
No real surprises there. Albon needs up his game, 8 tenths off max!
Just had a meet up with the usual local F1 clique.
A guy with a son at Mercedes was told they didn’t use party mode in qualifying, they’ve saved the engine for more presses of the overtake button.
We shall see. Really looking forward to this afternoon.
https://the-race.com/formula-1/the-numbers-that-show-the-true-extent-of-mercedes-dominance/
blimey that ferrari is a dog
I thought initially when I saw a red car facing the wrong way, it was Vettel spinning it again...
absolute master class, cooked max for 15 laps then waltzed off into the distance. (makes the fishy tire choice for the aniversary gp smell a little more foul)
ferrari running 5th in the constructors!
Didnt see the race but just saw the Albon Interview, first thing that came to mind with the way he was talking is he's been told he's being replaced.
no doubt total rubbish but he looked like a rabbit in a cars headlights.
Surprisingly enjoyable race thanks to the midfield action. Masterclass from Hamilton, looked like they had bags of pace left.
Vettel/Ferrari relationship sounds FUBAR
Ended turning the race off, combination of mediocre race and C4 going to advert s every 5 mins
Wow, vettel ended up doing 37 laps on used softs...well deserved driver of the day imo!
Vettel: "you need to let me know now what you want me to do in terms of pace."Ferrari: "go faster"
Vettel: "for how long?"
Ferrari: "3 laps" .... "all you have" .... "no more saving"
(*a few laps later*)
Ferrari: "What do you think about going to the end with this tyres"
Vettel: "Oh for ****s sake! I asked you this before and now I've been pushing for 3 laps!"
I wouldn't be surprised to see Vettel leave Ferrari before the last race, he really is losing it with the team!
Good fun in the midfield, plenty going on with different strategies that relied on overtaking to work.
Ended turning the race off, combination of mediocre race and C4 going to adverts every 5 mins.
I've spotted that if it's a boring race C4 put more ad breaks in the actual race coverage than they do for a good one. Not really complaining about it though as you know that you're not missing anything. Plus it's 10x better than having to put up with Crofty's stupid shouting at anything more exciting than paint dry.
Didnt see the race but just saw the Albon Interview, first thing that came to mind with the way he was talking is he’s been told he’s being replaced.
I get that feeling too - at the minute they've not even got a decent No.2 driver. 8th in a car capable of podiums isn't good enough.
I'm not sure Gasly is a good option either. But honestly don't know who else they could go for. Hulk or Vettel aren't long-term options, and they've no-one ready in their driver development programme.
Would love to see Vettel vs Max in that car. Mind you, sounds like it's a right handful to drive, and Vettel hasn't exactly shown himself to be able to drive around instability in the car...
Horner has been pretty clear in saying they're not interested in Vettel. RedBull is now more of a one man team than Ferrari was under Shumi - the #2 driver just needs to be there to stop other teams taking poihts, but Albon is not doing a great job there. I have zero sympathy for RedBull though - they had a promising young driver line up but have squandered them by first preferring Seb and now Max, leaving the #2 drivers riddled with doubt about their own ability. They've got a couple of options in their junior programme in F2/F3 - none are setting the world alight with their pace at the moment but my feeling is that they will reshuffle the pack for 2021 switching Kvyat or Gasly back to be Max's punchbag and Albon back to AT, and look for new talent in 2022 when they have more of a chance of beating Merc.
It's hard to judge from the outside. The car appears to be difficult to drive. Verstappen, despite being an annoying, arrogant ****, seems to be extremely talented, on the level of Senna, Schumacher, Hamilton, etc. Verstappen has the confidence and reflexes to drive it right on the limit despite it being very unpredictable. Merc have a similar situation, with cars over the last few years that have often been very difficult to get the best out of. Hamilton has generally done better at that than Bottas, but Bottas seems to be a fairly decent driver. He's just unfortunate enough to have a teammate who has credible claim to the Greatest of All Time. Same problem for Red Bull and Albon - he seems to do better in races than in qualifying, but he's driving a difficult car and being compared to a truly exceptional teammate. Red Bull will have a better picture of what's going on, but they need to produce a car that's a bit more predictable before writing off young drivers.
I must say I'm kind of on the same page as Retro here. While he has had quite a fall from grace I thought Vettel did a pretty good job of making those tyres last and keeping the train of clearly faster cars behind him. Yes, it helps that Barcelona is not the easiest track to overtake on but there is also an element of skilful and tactical driving and I thought Vettel did a very good job yesterday.
I think Albon has potential to improve. He has shown that he can be a brave and optimistic driver with some great drives, in places. I think he deserves a bit more time. I have also been impressed with George Russell this season. Despite being in a pretty uncompetitive car he has achieved some impressive results. In some ways I am surprised that Mercedes have given Bottas another year and not gambled with Russell.
At first I also thought that the comments from Seb sounded like major meltdown in the relationship but, again, thanks to retro's post I have the context that we didn't see in the highlights, and they make an awful lot more sense. Also, Vettel did have a more rational conversation on the radio a bit later in the race and seeing both of these together makes me think the relationship is not quite as toxic as might be suspected if you only heard the "Vettel: “Oh for **** sake! I asked you this before and now I’ve been pushing for 3 laps!” line
The Red Bull has been twitchy so far, remember that Verstappen ended up thumping the wall on a formation lap a couple of weeks back.
We know from Albon's promotion in 2019 that he's quick and capable of delivering the goods. It's evident that Albon does not have a confidence inspiring car underneath him.
It’s hard to judge from the outside. The car appears to be difficult to drive. Verstappen, despite being an annoying, arrogant ****, seems to be extremely talented, on the level of Senna, Schumacher, Hamilton, etc. Verstappen has the confidence and reflexes to drive it right on the limit despite it being very unpredictable.
Yup, there's a good chance that Albon is the one showing how good the car actually is
Bet you didn't know that Kovalinen was faster over a lap than Prost? 😂
The stat I liked from the weekend was Kimi’s overall distance in F1 races has now beaten Alonso’s 83,846km.
Nearly 84k Km in F1 races - blimey.
Yep a nice shift!
Seems odd it will be beaten again so soon though when Alonso returns for at least 2 seasons.
This season in the Alfa poor old Kimi must have felt like he was doing that extra distance every race.
He's also losing a few km's by being lapped each race 🙂
Yin and yang.
Williams has been bought by Dorilton Capital
Excellent news.
Wonder if Claire is studying her other options yet?
Excellent news.
Maybe not so excellent for Claire, as mashr says. There's no way an investor is going to buy a failing team and not try to turn it around and the first thing they'll look for is someone to lead the team through that. Sadly I don't think that's Claire - I'd expect some sort of reshuffle where she goes back to the marketing side and someone else takes on a full team principal role. Frank will probably become 'Team Principal Emeritus' a la Bernie.
I cant see how an investment company can make any money from an F1 team without breaking it up and selling the bits off. They will want quick results, Williams is already (almost) at the back of the grid, and it'll take a mahoosive amount of investment to make them even remotely top of the mid-field.
The rest of the grid isnt going to sit still, unless Williams get lucky with the rule changes or can attract some real top end engineering skills (I'm not saying the current ones aren't talented, more that others are more talented than them 🙂 ) then I do wonder how a company that exists to make money for its shareholders can actually make any money from racing.
I'd put £10 on it being sold again within 5 years, and thats a shame as I love the team and have great memories of them in their pomp.
I thought the engineering co within/behind Williams was pretty profitable though?
The press release specifically mentions the sale of Williams Racing, not any other part of the Williams Group so I expect the engineering side is still family owned.
Yup, Williams Engineering isn’t in the deal
Toto is as Team Manager? He's been dropping hints he's not staying with Merc and he already owns Williams shares. Something big brewing in the background?
Williams is already (almost) at the back of the grid, and it’ll take a mahoosive amount of investment to make them even remotely top of the mid-field.
The whole point of the huge changes coming in the next couple of years is to make it possible for mid-field teams to be profitable. The sport needs 10 teams that are financially stable, so the cost cap and new concorde agreement were aimed at that. The richer teams will still have an advantage because the salaries of drivers and chief designer aren't part of the cost cap, which means that Merc, Ferrari, and Red Bull, can pay massive salaries for superstar drivers and designers that the poorer teams can't afford, but the big teams won't be able to hire 1000 engineers versus 200 for the small teams. A smaller team with a well-managed technical department should be able to get much closer to the front than they can now, hopefully that will help them attract sponsors so they aren't all perpetually on the verge of bankruptcy. Williams' new owners seem to think it's worth a gamble.
Wasn't Williams Advanced Engineering already sold last year?
Reading more about the buyer, it sounds like they'll try and turn the team around rather than break it up and asset strip it.
Genii Capital did a pretty good job with Lotus so hopefully these guys can do the same.
From Dorilton's website:
Patience
We prefer to create value over the longer term by reinvesting cash flow while avoiding excessive leverage.
PartnershipWe work actively with existing management teams recognizing that long-term business success is the result of a team effort. Dorilton views its role as providing additional capital for acquisitions and growth projects and support and expertise to take its companies to the next level.
ContinuityWe partner with companies that are led by strong management teams and have a successful history and culture. We firmly believe in our companies continuing with the elements that have made them successful.
Reading more about the buyer, it sounds like they’ll try and turn the team around rather than break it up and asset strip it.
They'll not say on the website "We'll saddle the company with debt and asset strip it for a profit" tough will they?
I'm not really sure that an F1 team would be a suitable target for asset stripping. Obviously, they have engineering facilities, future prize money payouts, and IP, but the sale price will reflect the value of the facilities, the prize money will only be paid if they continue to operate, and the IP generally won't have much market value IMO. This is because i) Their car is horribly slow so no other team will want their data; ii) Teams have to design their own cars so they can't just buy designs from other teams. However, that IP will have value as part of an existing team because it means the buyers own an existing car design instead of having to design a car from scratch like new entrants have to do. The Williams name has some value, IMO, it still has a lot of loyal fans from its glory days, but that value is only associated with F1, so they won't get much for it if they close down the team and sell the name to a clothing label.
So my opinion is that the buyers probably think it is worth more as an operational team than selling off the bits.
Don't forget the value of the F1 grid slot too, much easier for a new manufacturer to enter by buying an existing team than financing a new entry from scratch.
I hope Williams end up better due to the deal as it really hurts to see them at the back. I'd be happy with consistent midfielder with the odd good result!
It’s a bit of a no loose situation for the investors as it doesn’t cost them any money as they will transfer the cost of buying the team to the team as debt.
sort off. The buy-out will be financed in a large part by bank debt, but there will also be PE money from both a company level and individuals within that PE firm - there may also be money from HNWI's. The money back will come in the form of 3-4 mechanisms'
Managament fee back to the PE's -monthly - this can be fairly substantial
then you'll have the loan notes of different types (C1-3 and likely some D notes with different values)
Debt payemtns to bank - i would have thought 6 monthly
Debt payments back to PE - (this will be at end of term normally, so say 5 years) - this will accrue monthly and compound over the course of the term at an interest rate say min 12% (Some HNWI's will be in this)
Sweet equity - thos are loans at the lower end of the payback scale after debt and are realised post sale. These can be worth exponential amounts depending on the sale of the company, or worth nothing if it goes below the asking price. (Some HNWI's will be in this)
Profit after all other debts, loans, equity is shared out.
For companies to asset strip, there has to be something worth asset stripping, generally in F1 there is sod all as it's all owned by other people/rented, so they have to work on the assumption they are buying the brand, the people and the success of the company, so that they can sell it for either
a. multiple of what they bought it for
b. multiple of it's EBITDA
c. multiple of it's EBITDA potential
d. some chomp with more money than sense just gives over a random amount - (not unheard of).
this is unfrotunately why people like he that should not be named, never go away as they never put money, but are good a courting people into high profile deals that have a potential to go right!
So you're say that Flavio Briatore is behind the buyout?
Wonder if they'll still keep a bed at the office for Frank.
So you’re say that Flavio Briatore is behind the buyout?
no idea, but possible - i was actually refering to the "he that should not be named" as the other knobber that steals bike logo's, though wont be behind this.
Four more races announced:
https://www.planetf1.com/news/turkish-gp-return-2020-calendar/
It'll be interesting to see the difference in lap times at Istanbul Park, compared to the last time they raced there.
I'm wondering who will bin it first at Turn 8 - Vettel or Grosjean? And will Albon try to pass someone round the outside there?
Im really looking forward to all the interesting circuits coming up.
Grosjean in FP1, Vettel in the race!
Of course he will, and it'll be the other guy's fault when they crash.
i was actually refering to the “he that should not be named” as the other knobber that steals bike logo’s, though wont be behind this.
Weirdy Beardy is currently making a lot of noise about buying Sunderland FC.
WTF....
https://www.bbc.co.uk/sport/formula1/53947251
What a boring race the second Bahrain race will be - it looks flat out for almost the entire lap. They may as well go to America and race an IndyCar circuit.
What a boring race the second Bahrain race will be – it looks flat out for almost the entire lap. They may as well go to America and race an IndyCar circuit.
Q1 us going to be chaos with everyone trying to get a quick lap with no traffic, and then pit stop strategy in the race could be tricky as there won't be many clear gaps to drop back into, so even with blue flags for traffic there will be a few more variables to get right. In some ways it'll be a bit like a high speed version of Monaco, but hopefully more interesting as a race.
Haas could be saying bye bye to Grosjean and hello to Hulkenberg for 2021
https://www.planetf1.com/news/nico-hulkenberg-haas-2021/
BTW the outer Bahrain loop is nothing like an oval. Its got a right handed hairpin after the start finish straight, and there are another 2 fairly heavy braking zones, alongwith the flat out twisty bit along the back straight. Hopefully it'll be a Monza downforce style circuit. It'll be a quick lap but DRS might make it fairly interesting if they end up with passing and repassing on the same straight.
Ferrari forgot their...
With this sort of performance, if spectators were allowed at Monza...
Like , err, yes I know it isn’t an oval but there are precious few corners. It’s just flat out > corner > flat out > corner. It just looks spectacularly boring. I’d rather they do the same (original) circuit on both weekends .
Erm, isn’t that how most of them work?
Vettel is going to go crazy in Quali! Last in FP3.
I am laughing so hard.
My God, wtf is with Ferrari?
Been caught stealing cheating.
Anyone else think vettel might not show up at all next week at Monza, if he continues in this rich vein of form? Definitely can’t see him seeing out the season
