Exciting radiator b...
[Closed] Exciting radiator bleeding question
8 Users
Upstairs radiators are a bit colder than they ought to be, I'm guessing they need bleeding... I'm completely ignorant of the subject, so stupid questions coming up:
a) Do you need to do each radiator separately? (I assume you do)
b) How do I bleed this radiator:
Just undo the screw a bit with the heating off, or is there some dark art to radiator manipulation I'm not aware of? There's a little bit under the screw that sticks out, what's that for?
Posted : 30/11/2012 11:26 am
[i]here's a little bit under the screw that sticks out, what's that for? [/i]
it's where the air/water will come out (I assume it's a tube)
Posted : 30/11/2012 11:27 am
I find bleeding a rad strangely satisfying … yes you do each separately and you may find one much worse than the others.
Sorry I can’t see your pics, so I'm not of much help.
But I do mine with the heating on… so that you can feel the warmth rise up the rad… Mmmmm… weirdo 😆
Posted : 30/11/2012 11:33 am
be careful bleedign open systems with the heating on - you can end up just sucking more air in to the system.
Posted : 30/11/2012 11:36 am
I was told by my plumber always to bleed when cold.....were on an old fashioned boiler not a combi
Posted : 30/11/2012 11:40 am
No... don't take that fun away from me.
My life just got even more sad.
Posted : 30/11/2012 11:41 am
Could be, although I'm sure I looked at it and it didn't have a hole running down the middle...
Will try later with the radiator in the bathroom, tiled floor you see 🙂
Posted : 30/11/2012 11:58 am
It won't be air it will be hydrogen, the by-product from your radiators rusting inside. If there's a lot you need to put some more antioxidant in the system, it's called Fernox.
If it's a combi boiler releasing pressure from the rads will cause a drop in pressure in the system, which you will need to replace with the filling loop under the boiler. If it's a traditional open vented system replacement water will flow down from the header tank, which is a good opportunity to tip in some Fernox.
Posted : 30/11/2012 12:12 pm
 ffej
mogrim
If you have a combi boiler then after you've bled them you may have to recharge / repressure the boiler. This usually isn't hard and is just a case of opening a valve or two on the boiler for a min and watching the pressure increase on a gauge, however find out how to do this BEFORE you bleed the rads as if it drops down too low the heating won't kick in.
Jeff
Posted : 30/11/2012 12:14 pm
I was told by the plumber earlier this week,
a) always do it with the heating switched off, and
b) start with the lowest and work up.
Posted : 30/11/2012 12:20 pm
 Taff
Agree with what Cougar said, I also go told to do it in sequence which is fine if you know it!
Posted : 30/11/2012 12:29 pm
Done that bit before, that's about the extent of my knowledge of the plumbing in my house 🙂
Cheers for the suggestions, will try and workout which is likely to be the lowest radiator first!
Posted : 30/11/2012 1:27 pm
