Excel Wizards
[Closed] Excel Wizards
11 Users
I have a simple formula that I'd like to make work a bit better. It's just a column that says either Yes or No depending if a submission has met the deadline. The formula simply looks at the two dates and says either yes or no. The problem is, until the date is entered, it defaults to Yes. I would like either to show No, or nothing at all. Can anyone help?
=IF(K20<F20, "YES", "NO")
K20 is submission date
F20 is deadline
Posted : 04/02/2022 11:08 am
Try
=if (k20>0,if(k20<F20,"Yes","No"),"")
Posted : 04/02/2022 11:15 am
 StuF
swap the formula round, should default to NO, add another IF around it to cope with blank entries
=IF(K20>F20, “NO”, “YES”)
Posted : 04/02/2022 11:17 am
Try
=if (k20>0,if(k20<F20,”Yes”,”No”),””)
Thanks, but unfortunately I get a name error.
Posted : 04/02/2022 11:19 am
=IF(OR(K20="", F20=""), "", IF(K20<F20, “YES”, “NO”))
Posted : 04/02/2022 11:29 am
You can still use this with the errors, then set a conditional formatting rule to set all errors to have white text, therefore appearing blank.
Posted : 04/02/2022 11:31 am
If copying and pasting, retype the quotes. ” is not the same character as "
=IF(ISERROR(K20<F20),"",IF(K20<F20, "YES", "NO"))
Posted : 04/02/2022 11:34 am
Please don't do this. If you want to handle errors then Excel has got plenty of functions to support that.
Posted : 04/02/2022 11:55 am
As per your request! 😄
=IF(ISBLANK(K20),"No, or nothing at all",IF(K20<L20,"YES","NO"))
RM.
Posted : 04/02/2022 12:00 pm
There is a special place in hell for people like you.
Posted : 04/02/2022 12:04 pm
=IF(ISBLANK(K20),”No, or nothing at all”,IF(K20<L20,”YES”,”NO”))
RM.
Nice try! Too many arguments, but if I remove "No," then it goes back to name error.
Posted : 04/02/2022 12:44 pm
is the date stored as text rather than date format?
Posted : 04/02/2022 12:51 pm
There doesn't look to be anything wrong with
I'm guessing you've missed a " when you've retyped it and the first , is not part of a text string but a delineator.
I would however strongly encourage the use of true false in place of yes no as they're useful.
Posted : 04/02/2022 12:52 pm
Ahhh, I forgot about ISBLANK 🤦‍♂️ Yeah, that.
Posted : 04/02/2022 12:55 pm
The first reply from the Purist works in my test, as Cougar says did you type it manually?
Are the dates in columns k & f typed in or are they referencing other cells?
Posted : 04/02/2022 12:56 pm
