I have two cells, each of which could contain 1 of 5 options.
I have a table with cell 1 options down the side, cell 2 options across the bottom and filled with every permutation.
What formula do I need to produce a result from the table for instance if cell 1 = H and cell 2 = L the table shows 200 in the corresponding row/column.
Tried VLookup but that seems to apply to lists rather than tables.
Ta!
Can you upload a screenshot? I'm confused.
Nor sure I fully understand the question but you can use HLOOKUP to get the column nested with VLOOKUP to get the cell.
Do the letters hold a numeric value then? Screenshot would help.
If I'm understanding it correctly
Cell A will contain a row reference for a table
Cell B contains a column reference for a table
He want's a formula that looks at the combination of Cell A & B and finds the corresponding result in the table?
Basically I want a formula which reads from a table of results if I tell it a value on the x axis and y axis
Edit Boardinbob has it
Would an IF scenario not work in that instance (as outlined by BoardinBob)?
think enmac has the solution
Too many variables for IF
You need a match in your lookup
=VLOOKUP(A9, $A$1:$F$6, MATCH(B9, $A$1:$F$1, 0), FALSE)
for example
In my example above
the table is A1:F6 including headings to be looked up
A9 the value to be looked up from column A
B9 the value to be matched to row 1
=VLOOKUP(B8,A1:F6,C8+1,FALSE)
Where:
cell b8 is your "cell 1"
cell c8 is your "cell 2"
A1:F6 is your table with 5x5 options and the headings for each column and row which relate to the cell 1 and cell 2 choices.
Much easier just to write a custom function and use that
Cheers RB that's smashed it! I was nearly there with INDEX-MATCH too but yours is easier
VLOOKUP is for tables but the third value defines the column in the table. You need the MATCH in the example I gave to define which column you want using your second value
Mixing VLOOKUP & INDEX/MATCH makes me uncomfortable 🙂
Assuming the labels are in column A & row 6, and data in range B1:F5:
=INDEX(B1:F5,MATCH(cell1,A1:A5,0),MATCH(cell2,B6:F6,0))
