Excel vlookup and s...
[Closed] Excel vlookup and summing results
7 Users
I have a spreadsheet with a list of about projects in column A, Resource name in column B, Days Allocated for Oct, Nov and Dec in columns C, D & E. Where there are multiple resources for a single project the project name is repeated for each one. Each resource can work on multiple projects.
I need to add a project Summary sheet that shows one row per project with the sum of the days allocated for each month.
I also need a resource summary spreadsheet that shows one row per resource with the sum of the days allocated for each month.
So far I have tried vlookup but only get the first occurrence brought back as a match rather than the sum of all occurances
Posted : 14/09/2020 12:29 pm
 Nick
Pivot Table would be the easiest way, you could use DSUM as well
Posted : 14/09/2020 12:31 pm
SUMIF sounds like the function you want? You can filter/select on one column and add the number in another column.
SUMIFS can use multiple conditions if you need that (I think)
Posted : 14/09/2020 12:32 pm
Sounds like a pivot table job if I understand it correctly
If not I'd add another Column and sum it in there - it's a pretty simple sumif statemen
Sumifs is exactly what you want. Or a pivot table.
Posted : 14/09/2020 12:38 pm
Sounds like SUMIFS to me, cos pivot tables are evil.
Posted : 14/09/2020 12:51 pm
Pivot Table works. Thanks
Posted : 14/09/2020 12:55 pm
Like most things in excel, they're great for what they're supposed to do, they're shocking for what they're used for 90% of the time.
Posted : 14/09/2020 1:22 pm
 db
SUMPRODUCT if you want something other than a pivot table?
Posted : 14/09/2020 3:09 pm
