Excel (or Google Sh...
[Closed] Excel (or Google Sheets) knowledge required
5 Users
So I used a Google form to gather data and now need to provide interpretation. Some data was peoples views based on what event they attended. I want to create lists based on each event - ie comment 1, 3 and 5 for event A and then comments 2, 4 and 6 for event B etc.
Does anyone know the excel (or more usefully) the sheets function to gather this information cleanly...
Original data looked like:
Event
Event A - Comment 1
Event B - Comment 2
Event A - Comment 3
Event B - Comment 4
Event A - Comment 5
Event B - Comment 6
How I want it to look like
Event A
Comment 1
Comment 2
Comment 5
Event B
Comment 3
Comment 4
Comment 6
Posted : 29/05/2019 4:48 pm
Is the Event/Comment thing really a single string per cell i.e. "Event A – Comment 5" rather than 'Event A" and "Comment 5"?
If it is I would just sort it alphabetically and then insert some extra lines if it is a one off and there aren't many events.  If you are doing it more often then something a bit more complicated might be needed
Posted : 29/05/2019 6:54 pm
If the whole string is in one cell, you can use the “left” function to generate another string with which to sort your data.
Eg in b2: (IIRC)
=left(a2,7)
This puts the first 7 characters of a2 into b2.
Posted : 29/05/2019 8:53 pm
Text to columns function using the dash as a delimiter.
Then a simple pivot table.
Posted : 30/05/2019 5:31 am
Assuming the events vary in length
And that you want it to keep going as you add more data.
=LEFT(A1,(FIND("-",A1,1)-1))
Plus the equivalent right in two separate columns will split the data
Then as above the mystical pivot table.
Alternatively you can set it up manually with an ace formula i found but i eill need to fond it again.
Posted : 30/05/2019 8:17 am
