I'm not mega good on coding parts of excel/macros but I have something working already and want to alter it slightly.
Sub copybrum()
Dim c As Range
Dim j As Integer
Dim Source As Worksheet
Dim Target As Worksheet' Change worksheet designations as needed
Set Source = ActiveWorkbook.Worksheets("In School Events")
Set Target = ActiveWorkbook.Worksheets("Stourbridge")j = 2 ' Start copying to row 1 in target sheet
For Each c In Source.Range("F1:F1000") ' Do 1000 rows
If c = "Stourbridge" Then
Source.Rows(c.Row).Copy Target.Rows(j)
j = j + 1
End If
Next c' Change worksheet designations as needed
Set Target = ActiveWorkbook.Worksheets("Birmingham")j = 2 ' Start copying to row 1 in target sheet
If c = "Birmingham" Then
j = j + 1
End If
Next c
End Sub
I actually want it to just copy from column A - I and not the whole row. I've tried altering the code but can't get it to work right and most results I've found online wanted single columns and not a range hence I cant get it working right.
Any hellllllp?
For Each c In Source.Range("F1:F1000' Do 1000 rows
I've not given any consideration to the logic of what the code's doing, but I think you're missing a closed parenthesis in both of these lines.
To copy a range you want to do a loop, start at cell (a, b) the work along the row before repeating on the next couple. So its a loop in a loop. I think that's what your after...
Can't you just use range(A1:I1000)?
Think if it were me I'd define a named range in the source, then you're not screwed if someone adds / removes lines.
You can just copy a whole block using Range(cells(topleftrow,topleftcol),cells(bottomrightrow,bottomrightcol))
Ah the copy paste hasn't quite done it right so the parenthesis is actually closed.
I think I know the range but obviously the command of source.rows or copy target.rows is wrong but im unsure how to tell it just the range of cells.
