Excel Help Please
[Closed] Excel Help Please
6 Users
I am just working on a product feed and need a bit of advice.
The feed has both single products and also Parent&Child products.
Is there a way that i can highlight all of the products that dont have multiples
All Parent Codes are in Column A Child Codes Column B
So i need something to pick all the Column a Codes that are singular like below it would show 54786
As there are 90,000 lines to go through i dont want to do this 1 by 1
54706 117738
54706 117739
54706 117741
54706 117742
54706 117743
54706 117744
54706 225097
54786 118589
54967 119090
Thanks
54967 119091
54967 119092
55167 119714
55167 119715
55167 119716
Posted : 17/01/2020 9:14 am
Countif() then filter for the 1s
Posted : 17/01/2020 9:21 am
 Mat
So if I read right you have 2 columns of data, you want to show entries in column A where there's nothing in column B?
- Highlight the whole table
- click the drop down menu 'sort and filter' (on the home tab on the ribbon)
- click filter, you'll then see little drop downs appear at the top of each column
- click the drop down on column be (child column)
- untick select all
- tick blanks
Posted : 17/01/2020 9:30 am
If you just want to get a list of the unique values in Column A, copy it to a new column (C) to preserve the orginal then highlight Column C and use Data/Remove Duplicate (make sure only Column C is ticjked in the dialogue box) and you'll be left with a list of the unique values.
Edit - Just reread your post so scratch that, go with RobHilton's COUNTIF
so set C1 = COUNTIF(A:A,A1)
copy that down the whole data set
do the autofiltering setup then select on Column C = 1
Or you could use a Pivot Table....
Posted : 17/01/2020 9:34 am
I just want to hightlight the rows that in column A dont have only have 1 occerance
Posted : 17/01/2020 9:40 am
The purist
Thanks that worked
Posted : 17/01/2020 9:44 am
if you just want to 'highlight' the number i.e. change the colour or something, then use Conditional formatting
- select all the data in column A, say A1:A100000
- Home > Conditional Formatting > New Rule
- select "Use formula to determine which cells to format"
- type in =countif($A$1:$A$100000,A1)=1
- click the a Format button and select a font colour etc.
- click OK, OK
Posted : 17/01/2020 3:52 pm
If it's only a single column, select the column then:
Home > Conditional formatting > Highlight Cells Rules > Duplicate Values
You can then select either Unique or Duplicate, plus the highlight colour.
You can then sort by that column using cell colour to bring all the unique or duplicate values to the top or bottom.
Posted : 18/01/2020 12:19 am
