Excel experts conve...
[Closed] Excel experts convene
5 Users
How do I add a button at the end of a data entry form in Excel which users would press once finishing data entry which would then send an automatic email message to 2 of my colleagues to let them know someone had submitted data?
I've designed the form in VBA. I've been adding buttons using the toolbox which is currently the limit of my VBA knowledge.
Thanks in advance.
Posted : 28/11/2018 12:47 pm
https://powerspreadsheets.com/send-email-excel-vba/
You using outlook?
Posted : 28/11/2018 12:51 pm
Create a button, assign the code to the button.
Posted : 28/11/2018 12:53 pm
No offence bikebuoy, but that advice is a bit:
Posted : 28/11/2018 1:05 pm
Thanks all.
Posted : 28/11/2018 1:23 pm
Is it possible to change a form list box colour depending on what list item is selected? I'd like to highlight that box in red if one of the options is selected ie 'cancel so other users are made aware. Ideally I'd like to highlight the whole row in which that box is like you can in excel conditional formatting.
Thanks in advance.
Posted : 30/11/2018 11:13 am
Try...
ListboxName.BackColor=
Posted : 30/11/2018 11:27 am
Thank you. Do I type that into the code lines for that list box? I can change the colour of the box using the properties box but can't seem to have it change depending on whether I select yes or no in the list box. I've currently somehow got it where no is blue and yes is red so I'm happy with that.
Thanks again all.
Posted : 30/11/2018 12:19 pm
first you need to detect that something has changed, so in the VBA code editor, for that form you need to create an event procudure eg
private sub ListBox_Change
end sub
This will get called each time the value in the Listbox called "ListBox" changes.
You then need to decide what to do eg
if ListBox.value = "Fred" then
ListboxName.BackColor=Colour_for_fred
else
ListboxName.BackColor=Colour_default
endif
end sub
etc...
Posted : 30/11/2018 12:31 pm
