Evoc terminal bag o...
[Closed] Evoc terminal bag on ryan air????
3 Users
Hi all.
Traveling to Poland on a stag do in a few weeks. Unfortunately we are flying with ryan air.
I need to purchase a decent hand luggage case and quite like the look of the evoc terminal bag
http://www.chainreactioncycles.com/mobile/evoc-terminal-bag-40l-20l-2013/rp-prod64941
I know its a bit expensive, but it will get plenty of use.
Has anybody used this case while flying with ryan air? They state that the dimensions should be 55 x 40 x 20. The case is 56 x 38 x 20.
Are they really that strict that they will say its do big by 1cm!!!?
Steve
Posted : 24/06/2014 3:06 pm
They have a test box you drop it in so they can be strict even by 1cm, ie it'll go in or it won't. That said that case should squash enough if isn't rammed full. Also they very rarely test so if looks OK you'll almost certainly be fine, but its not 100%.
Posted : 24/06/2014 3:11 pm
It's a soft bag so it will be fine.
You would need to fill it to capacity with concrete and wait for it to set for it to be an issue, and even then it would probably fit in the cage, you just wouldn't be able to lift it 🙂
Posted : 24/06/2014 3:34 pm
