Electronics enginee...
[Closed] Electronics engineers/DIY HiFi enthusiasts, help please! Why do my amps not work
6 Users
I have a couple of these amplifier boards:
https://www.ebay.co.uk/p/Xh-m253-Tda8954th-Core-BTL-Mode-HIFI-Class-420w-High-Power-Mono-Digital-Amp-Z4w4/21020333806
Based on this:
I am trying to test them for a project and am using a raspberry pi headphone out as the input. I am using a 19VDC laptop charger instead of the 24V AC printed on the board (I am pretty sure the ebay ad is wrong), as there is a bridge rectifier straight after the power terminals, so this should give around 18V to the chip (I think). There is a blue power LED which is lit fine.
The headphone out works fine with headphones, and I can get the speaker working running the headphone cable straight to it, so the problem is definitely the amp.
The resistance across the input terminals of the amp is measuring infinite, would this cause a problem as headphones would obviously have a finite resistance.
Not getting anything from the speakers, and not measuring an AC voltage across the input terminals (not sure if I should be able to with a standard multimeter?)
What have I missed? Any help appreciated!
Thanks
Posted : 04/01/2020 9:29 pm
Page 6 of the data sheet is about the mute and standby, do I need to close both of these for operation? If so that may be the problem, I did try shorting each but only one at a time
Posted : 04/01/2020 9:35 pm
Or is it that I have not provided a negative supply voltage?
Posted : 04/01/2020 9:47 pm
I guess that the board needs 24V AC so that positive and negative supplies can be generated on board (something like +/- 15V).
Chip protection circuits will shut it down if total supply voltage is <20-25V or if there is >30% imbalance between +ve and -ve supply voltages.
Buy a transfomer... 🙂
Posted : 04/01/2020 10:21 pm
A bridge rectifier is used for converting from AC to DC, so the board needs an AC input, and 24V sounds about right from looking at the supply voltage specs for the device.
As above, get a transformer... you should be able to find an plug in supply for 24V AC, but make sure it's rated enough for the amp... it's gonna need to supply about 20A at full load!
Also, amplifier inputs are almost always high impedance, so I wouldn't expect to see any meaningful resistance there.
Finally, a multimeter won't be able to measure audio, it's just not fast enough...
Posted : 04/01/2020 10:55 pm
 ajaj
The eBay listing shows a centre tap 12-0-12 transformer, which would give roughly +16v and -16v DC rails in line with the chip spec of +/-12-42v. Or you could use a transformer with independent secondaries wired in series to create a centre tap.
I presume there's some voltage regulation going on somewhere.
You'd probably want to ground it somewhere sensible too.
Posted : 05/01/2020 1:06 am
As above, it looks like there are 3 wires to supply power and not just 2.   So 0v and +-16v AC.
And, you need to check the current rating as well of course. That thing looks like it eats power. You might even need a fan
Posted : 05/01/2020 5:38 am
Or to protect against backwards polarity in the supply.
Posted : 05/01/2020 6:58 am
Thanks chaps. I can’t find a power supply for less than £40 so think The amps may be destined for the shelf for a bit longer, and I’ll get a ready made pi amp
Posted : 05/01/2020 10:24 am
 ajaj
Something like this would get you going for £15. Add in £5 for a box, slow-blow fuse and plug.
Wire the secondaries as shown here
Posted : 05/01/2020 10:46 am
At the recommended supply voltage for that board, the max output will be ~ 2 x 20W as single ended amps, or ~30-40W bridged (which is how I assume it's wired, but haven't dug into the Chenglish details).
Something like a 50 or 60VA transformer would be big enough.
Posted : 05/01/2020 11:13 am
