Our power/lights down to a shed in the garden has gone. Seemed to go off when I turned on the pond pump (at toip of garden). Nothing has tripped on the RCD in the house.
There is a simple fuse box (like a light switch that cuts off the power to shed) down in the shed. Is there a simple way I can find exactly where the fault is by using either a mulitmeter or voltage pen without killing myself?
You can check the fuse in the fuse box pretty easily. That'd be where I'd start.
[quote=nickjb ]You can check the fuse in the fuse box pretty easily. That'd be where I'd start.
i'd start by isolating the power to the shed first...
