I need to replace a short piece of cable [literally less than 2 x 20cm sections] that carry a maximum of 3kW (Immersion).
I have some spare 1mm twin and earth hanging around - the internets says that's fine but I thought I'd ask on here* too.
* Fully expect to be told that I should have the whole house rewired, shouldn't drive a big diesel, that my lawn needs cutting and it's all the government's fault.
Without going to look at my copy of the BS7671.......
Yes, you are correct - 'clipped direct' the current carrying capacity exceeds your requirement of 12.5A (3kW @240v)
Source https://intrelec.co.uk/2020/10/21/cable-sizing-charts/
Its very short so volt drop shouldnt be an issue.
BUT! The cable will have been calculated on fault current/ protective device rating etc
So would i use it?
No.
Id be looking at 2.5mm probably for an immersion (i think the regs say 1.5mm minimum)
The cable connecting to the immersion should be heat resisting- butyl flex would be ideal.
It's actually going near the CU in another room so heat is not an issue.
Ahh, fair enough. I do actually have a roll of 2.5mm but it's just a PITA to deal with as it's 'so' stiff! I was hoping to get away with something more flexible - not to worry, 2.5mm it is!
