My daughter just moved into a 1 bedroom flat. According to meter readings, she is using about 17kWh per day, which seems to me to be ridiculously high. My first thought was that she is taking baths at all hours and cooking pizza, but she swears blind that the heating is off and the water heating is restricted to 2 hours per day (she has an electric boiler). The high usage figures apply to both Night and Day usage, so it seems like some mystery appliance is permanently “on”.
At a distance it’s difficult to diagnose but my hypotheses are:
1. The meter is faulty, or incorrectly installed - seems most unlikely
2. She thinks she has turned off the heating but in fact she hasn’t. This sounds more probable but how can we check
This situation isn’t sustainable because the monthly bills are 150 quid or so. Does it make sense to call an electrician to check that the heating etc is not faulty (eg on when it says it’s off?). She is very stressed about it and is passing the stress on to us, so I’m hoping that the wise folk of STW have some suggestions for how to tackle the problem!!
Flick all the consumer unit switches off. Check the meter is stopped.
Switch each circuit on one at a time, checking the meter as she goes. If it suddenly starts racing there is the answer, or at least a bloody good clue.
Hopefully not a neighbour tapping off it…
Quite.
Can she get us some pictures of the consumer unit (fuse board in old terms) and the meter? Heating controls also.
Short of a faulty meter, you’re probably right to suspect the electric boiler is that’s a fair old amount of energy that has to be going somewhere.
Once we know what equipment she’s got there, I’m thinking we could walk you and her through how you can isolate circuits and understand the readings on the meter to isolate what and when is drawing power.
If it’s not already a smart meter she could get her supplier to fit a smart meter, that will be v helpful in diagnosis but not a quick fix.
I guess the obvious place to start is to turn everything off, take a reading, go out for a few hours and come back and read again. My focus would be on the electric boiler though.
Thanks all - I’ll ask her to send me some pics of the relevant items. Flicking the fuse switches should be do-able, hopefully they are labeled so she can turn the fridge right back on 🙂
For the smart meter, I’m wondering if that’s feasible? All the meters for the flats are in one room some distance from her flat. (Also makes monitoring slightly laborious).
<p style="text-align: left;">If the hot water is on for two hours a day presumably that heats a tank. Is the water temperature ridiculously hot?
</p>
Is there any electric underfloor heating that she's not aware of?
From a random energy supplier: (sse)
Can I get a smart meter if I’m renting a property?
Yes. As long as you’re the energy account holder and you pay the energy bills, not your landlord, then you can get a smart meter in your rented property.
Just guessing she’s renting. Regardless, the meter is effectively “owned” by the energy supplier, and the energy supplier is appointed by whoever pays the bills. So if she’s paying the bills (and it appears she is 😆) she can ask them to fit a smart meter.
Apparently it is not uncommon for electric meters to be accidentally connected up to the wrong house/flat/whatever.
i.e. your daughter is paying someone else's electricity bill and they are paying hers.
A co-worker had this - he only found out when his house burned down and he got divorced, it had been going on for years.
Electric shower? Gobble electric at an alarming rate.
Maybe, but she using 17kwh per DAY.
Even if she was in the shower for an hour on max heat that would probably only be about about half of that.
Theres a few checks to do
One is to search about for any isolator switches that might be powering something she's unaware of - I lived in a house with solid fuel heating / back boiler and was unaware it also had an immersion heater until I inadvertently switched what I thought was a redundant isolator when cleaning - it had been off for so long the thermostat had failed so I came home later that day to steam billowing out of the roof 🙂 So there may be more than one heating or hot water set up and something might be on that she's unaware of
So switch off everything you know about in the flat / at the switches in the flat and monitor the meter - if its still turning then keep looking for other switches
then the final one os to switch off everything at the fusebox and monitor the meter.
In a flat set up - especially if it's a building that has been subdivided into flats - it's not unknown for unscrupulous landlords to siphon off power. My parents lived in a flat in their younger days that they discovered their shop-keeper landlord was running all the fridges in his shop below from their coin meter
A friend when I was at college discovered that the motor garage behind their house was running their business on power from their meter
In either of those situations just switching everything off at the fuse box reveals nothing becuase the meter will of course stop
My pal only figured it out becuase the mechanic's radio would switch on and off when she flicked off her mains switch
My dad only cottoned on becuase he was home ill one day and having to feed the meter to try and keep warm - until he ran out of coins and went down to the shop to ask to change a note and the shop was in darkness 🙂
Wouldn't worry about the fridge whilst diagnosing, it will be fine for an hour or two!
A smart meter is only going to tell you when the power is being used..... not what by.
You can see that by looking at the meter a few times a day.
Really appreciate all the replies - lots of good ideas. Some random bits of information …
I’m just reading the homebuyers survey report. It says the boiler heats water on demand, which doesn’t square with what she says about the HW being on 2 hours a day.
There is underfloor heating which she says is switched off.
There are some bad photos in the survey report so I’m asking her to send new ones!
She is the owner so she can ask the electricity supplier to install a smart meter, if it’s possible.
The flat is in a purpose built block.
A co-worker had this – he only found out when his house burned down and he got divorced
Hopefully OP's daughter doesn't have to go to such extreme lengths to find what's using all the power...
If there's no tank then it's hw on demand..... i.e. a big kettle!
Does she have baths or just showers?
Edit: actually heating 250L up from 28c to 40c is only going to use about 6kw.
So it can't be that alone.
Is she mining bitcoins!?
[url= https://i.postimg.cc/t7nyBftH/71654477062-12-C5-F351-EB2-B-4-C81-8-CC9-332-B8-E32316-B.jp g" target="_blank">https://i.postimg.cc/t7nyBftH/71654477062-12-C5-F351-EB2-B-4-C81-8-CC9-332-B8-E32316-B.jp g"/> [/img][/url]
[url= https://i.postimg.cc/tnNBrpB5/71654478712-92-EC6-D95-8-C1-D-4-E04-85-C9-60-D369-AE8782.jp g" target="_blank">https://i.postimg.cc/tnNBrpB5/71654478712-92-EC6-D95-8-C1-D-4-E04-85-C9-60-D369-AE8782.jp g"/> [/img][/url]
[url= https://i.postimg.cc/Snsgr0C6/71654480118-728-ECE27-257-E-4-B9-B-B565-7-E253-E8-C45-D6.jp g" target="_blank">https://i.postimg.cc/Snsgr0C6/71654480118-728-ECE27-257-E-4-B9-B-B565-7-E253-E8-C45-D6.jp g"/> [/img][/url]
Looking at these pics, I’d be tempted to just turn off the “underfloor heating” on the middle box. But … will she die ?
And the top pic seems to be of a timer, but how does that square with HW on demand ?
<p style="text-align: left;">My sister bought a brand new condo and after two years she discovered her property was connected to the wrong gas tank.</p>
First step is to turn the lot off and check the meter does not go up at all over a few hours. Fridge freezer will be fine just don't open the doors.
That will tell you if she is paying the wrong bill.
Then 2 circuits in turn for an hour each and write down the increase each time.
This will narrow it down quickly.
I think as others are probably alluding to, switch off at the main switch by the meter, go back to flat and check that everything is off, that would establish she actually is reading the correct meter. switch back on again.
switch absolutely everything off in the flat that she's aware of, go and look at the meter, if there's activity then there's something still on that she isn't aware of or some other draw. I suppose if there is a draw that she can't find then if all the flats are the same, speak to neighbours who might be able to offer advice from their experience or go to whoever manages the building for help/advice.
EDIT: ah looking at the consumer unit pic, I'd probably work my way thru that, I suppose you could start by turning the whole flat off and walking to the meter to be certain there's no 'other' draw
no, crack on, the only risk to turning things off is losing something you don’t mean to, like a cold fridge or a hot shower.
I’m kinda leaning towards your plan here, just isolate the underfloor heating for say 24 hrs.
Other things to check are the towel rail. Hot water seems a mystery still.
In an all electric house 17kwh isn't really that much.
Tumble drying washing by chance ? The flats I've ended up have all had washer driers rather than communal washing lines. Seems to be the modern way.
Electric h/w
Electric shower
Electric cooking
Wfh?
17kwh could easy be burned. Bare in mind the average use is 10kwh -and that most folk have gas hot water and gas heating ....
As others have said, well under a kW (average) isn’t really a huge amount of power. Lights (especially if not LED) can quickly add up and electric water heating is definitely costly. Fridge also, though modern electronics (tv/computer etc) probably shouldn’t amount to much.
Regardless, switching off circuits should isolate the cause.
In an all electric house 17kwh isn’t really that much.
yeah this has crossed my mind.
I really think a smart meter could help here, in time.
It might help educate her, “oh, the dishwasher just cost me a £1 to run! I’ll not put it on till it’s full next time”
Etc
How far away is the consumer unit
A smart meter unit may not transmit ?
Is this your dishwasher?
There’s an immersion heater CB on that board which suggests a tank and also the HW side of that controller seems to be configured so my guess is it could be something to do with either the underfloor heating or the HW. If the immersion is left on that will certainly use a whole load. Does she know where the immersion heater switch is?
Just for reference, we use 14-15kwh on average in a 4 bed house with someone at home all day and 3 kids who have no concept of turning stuff off. With a pond pump running 24/7 and a 10.5kw leccy shower.
Funnily enough I've had a similar issue (nearly started a thread on it yesterday).
Going to be the smart meter would show 94w get up next day and with nothing on it was at 280w
I've noticed that overnight electric use has gone up as well.
Spent more time than I'd like to admit turning breakers off and seeing if the smart meter readings change.
Turns out it's the fridge! Even when the compressor is not running it can draw 150w but other times none.
I reckon a single person in a 1 bed flat would use c 4kw a day, plus the water heater is c 6kw so daily bath add that. Assuming no underfloor heating.
Old light bulbs are 60w, new leds 5w.
Good of you to catch and spot this early, as above, check circuits, old appliances. At current prices it's a good payback to upgrade.
I think some smart meters will tell you instantaneous use if you press a button to cycle through the menus. Then just get a friend with a phone next to the meter to tell you what is happening as you flip switches. Might help you narrow it down a bit faster. A bot like the spinny disk on old school meters
Well not really as they have thermostats.
To heat 150L from 18c to 58c (which is very hot is going to use 7kWh.... and that's not going to happen every day, so probably half that.
I'd get a few Tapo P110 smart plugs with energy monitoring. enables you to see what anything plugged in uses. working from home, laptop and two screens is about 45w. Water heaters, then you'd be ooking at 2-3kw - shower 10kw.
Our main issue is two gaming pc's with multiple large screens. A large TV can consume 100w
But it’s not a house, it’s a one bed flat.
We have a 5 bed house with 3 teenagers living in it and I work from home every day. average 16.8kw per day over 12 months.
Heating and hot water is gas but our oven seems to be permanently on and tumble dryer does a marathon effort every other day. So 17kw for your daughter does seem way too high.
And it's switched off at the breaker in that photo.
One thought, one of the breakers there is labelled "smoke alarm." Cutting the power to my burglar alarm - even if it's not armed - will set it off. It's probably nothing to worry about (I can't think offhand why a smoke alarm would need tamper protection) but I think I'd want to know how it was configured before accidentally evacuating the entire building.
The cannabis factory in the loft? 😉
As written earlier, if flat doesn't have gas for room heating, cooking and water heating something like ~15kWh per day in late summer sounds about right. If flat has Economy 7, make sure immersion is heating water in the last hour of cheaper night rate.
And it’s switched off at the breaker in that photo.
I always thought leaving the immersion on was a bad idea as it used loads of leccy. I stand corrected. And yes it’s obviously off in the photo but it could have been on before the photo was taken Shirley.
A 1 bed flat has the published average use of 2800kwh/year explicitly excluding heating and hot water.
Thanks once more to everyone for your help - really great. All has been passed on and I am waiting to see what she actually decides to do, and what the outcome is.
There seem to be breakers for two lots of under floor heating, one on each board. The programmer can only be connected to one of them, so it's possible that the other (bathroom?) is on 24/7. There's also a breaker for a towel rail - if that is on, it could easily use 5 - 10 kWH / day.
There also seem to be two breakers marked boiler- What does each of them feed?
What's the rating on the towel rail and is it on all day?
Looking at the photos, i think the setup is an electric boiler and unvented cylinder.
Knowing how bad these things are set up and how most electricians are less than competent at heating wiring I would be looking at those. Check the thermostat on the hot water cylinder as if it is too high then the water will never reach temp and the boiler will be on continuous, could be a 6kw electric boiler, on for 2 hours as you say, there’s 12kw right there if it is never satisfied, could even be a 9kw version……
Thanks again. What temp should the boiler be at? She swears that the towel rail and heating are switched off, but the meter doesn’t lie and SOMETHING is on! As MrsJ told her - there isn’t a ghost using your electricity.
60c
The thermostat is on the hot water cylinder and should be 55 deg. C, the boiler will need to be higher than that minimum 65 otherwise again it won't satisfy the hot water and will be running continuously.
The thermostat on the cylinder may be behind a cover and have a scale of numbers like 1-5 instead of temperature which is a pain!
My last place was a 2 bed new build flat, electric only. We used approx 3500 kWh per year, no boiler - electric panel radiators that we rarely turned on, and an unvented water cylinder.
The unvented cylinder was set to heat overnight for a few hours. If needed, that is you'd used up all the hot water, the 'immersion' switch on the wall by the cylinder could be flicked on, but we were warned by the builder not to leave it on as you'll eat through electricity.
Might not be relevant, but assuming some form of electric heating isn't on, I'd be double checking the immersion switch for the cylinder is off.
Sometimes, unhelpfully, the 2 switches on the wall are not labelled, but both shouldn't be on. At least that was the case in my flat.
So, to update this saga. Daughter had an electrician in and he basically confirmed what you suggested- as soon as the hot water heater is turned on the usage shoots through the roof. His diagnosis was that it’s because the boiler is old and obsolete and the only solution is to replace it. Not a surprise but not what we wanted to hear.
Next question- what should she replace it with? What types of boiler exist and what should she go for if the priorities are low electricity usage and reliability?
Electric boilers are like kettles - a heating element surrounded by the water. Unless the element is covered in limescale they're all about the same. The only thing that makes a big difference is the insulation of the tank. Also worth making sure that none of the hot taps drip.
Reduce the timer on the hot water - maybe heat once a day - certainly reduced our gas use since winter by reducing the timer for water, when we don't have heating on.
Were' a heavy electricity user, but average 15-17 KWh a day (watched monthly and recorded on a spreadsheet) - 4 adults and at least one person at home every day.
I'd be getting a second opinion on that, you only need to replace an obsolete boiler if there's broken parts you really can't replace and being old isn't a valid reason either. Can these things be flushed/cleaned if the reason for inefficiency is loads of limescale?
A massive heater coming on will always make the instantaneous consumption shoot up, you're probably increasing the demand by 10x in seconds. The amount of usage is due to how long that load stays on for, inefficiency is the problem, not age.
Rubbish - Murray has it.
I’d be getting a second opinion on that, you only need to replace an obsolete boiler if there’s broken parts you really can’t replace and being old isn’t a valid reason either.
Very much this!
Can you clarify what the boiler heats the water for.... is it to heat water for radiators as well as water for baths, showers, etc.or is it just for the latter?
(I know there's UFH in at least one room but that's electric)
What does she use the hot water for?
You could avoid the need for a boiler full of hot water if she has an electric shower and an instantaneous water heater for washing her hands.
A dishwasher is a very efficient option as it only heats the water you need for the wash. You can get small counter top ones for £200 - £300.
There are much more efficient electric heaters available but they are not cheap. We put one in a shared family holiday home, I was surprised at how much heat it puts out from a rating of 1500w. Way more than the 3000w it replaced. No idea how it does though?
Just checked mine and we use an average of 12.73 kWh per day and I work from home and drink lots of tea. The power shower I know uses a lot.
My neighbours just bought a new car so I'm hoping his electricity bill is not zero.
Two thoughts:
1) An electrician is not (usually) a Gas Safe engineer. I'd perhaps file this under "false authority."
2) When was it last serviced?
1) An electrician is not (usually) a Gas Safe engineer. I’d perhaps file this under “false authority.”
It's an electric boiler, not a gas one.
Leaving an immersion heater on all day is as good as burning her £10 notes instead. Yes they have thermostats - but even a well insulated tank still loses some heat (which results in the thermostat turning the element back on to get back to full temperature). It's why an airing cupboard finishes off drying clothes- the lost heat from the tank heats the air.
And if the tank insulation isn't great, or even worse an old style with a strapped-on jacket rather than molded onto the cylinder... £££ down the pan.
In terms of £££, most UK houses use gas for the true high-consumption uses (heating, hot water for bathing and in the tap, and many the cooker + hobs too). Being electrical instead trebles their operating costs as E is about 3x the price per kwh than gas.
Our overall bills went up markedly a few years back when we changed the gas cooker and hob to electric (lots of reasons to like the induction hob though).
Or not reading the thread correctly 🙂
Yup, and having had a teenage son who could easily stand day dreaming in the shower for an hour plus it's not beyond the realms of possibility.
Reduce the timer on the hot water – maybe heat once a day – certainly reduced our gas use since winter by reducing the timer for water, when we don’t have heating on.
Yes, unless you're ploughing through the hot water use, the unvented hot water cylinder should only need heating for a period to bring back up to temp. Different circumstances probably but I'll mention it anyway in case it's of some use - I accessed the dial on the cylinder to turn the temp down (as hot water out of the taps was far too hot), and set it to turn on between midnight and 4am where it could use the Economy7 cheaper rate to heat up. We never ran out of hot water (2 adults, 150l cylinder).
Assume there isn't something like an 'eco' mode available on the boiler? I use this on our combi boiler so that the boiler doesn't keep firing up several times all day just to keep a bit of water hot and ready.
What controls are on the water heater? is the temp set too high, or timer set wrong for usage?
Might be worth knocking it down to 60c if it's set higher...i.e theres no point having scalding hot water comming out of the hot taps/shower if your'e just going to mix it back down with cold water at the tap/shower head to make it comfortable!
So there's a boiler, as well as an unvented hot water cylinder?
I don't know enough about it, but is the control of the unvented cylinder done from the boiler? (My system had a Dimplex control panel where you'd set the on/off state for the cylinder, and electric panel heaters if you wanted).
On second opinions, unvented cylinders need particular qualifications and these are stated on people's Gas safe register profiles.
I get the point that water getting hot requires a fixed amount of energy and there’s no way round the laws of physics :-). What I’m wondering is if a new “kettle style” boiler might have less energy loss for some reason (which I can’t imagine is actually very big) and secondly if a “heat on demand” boiler might be less wasteful as she’d only be heating the water she needs?
currently she only uses it for washing herself (at home that involves soaking in the bath for hours but now I imagine it’s showering) and some minimal amount of washing up (she had a dishwasher).
EDIT - for new readers - we’re talking about a fully electric system
Taking a step back here.
An all electric property is always going to have higher energy bills than a similar property with gas heating - electricity is about three times more expensive per KWh than gas. Hence this is something to factor in when weighing up places to rent/buy along with the other ownership/rental costs.
The boiler is a large high power device, you can think of it a bit like a supersized kettle, the power draw will be high while it is on. The relevant question here is how long is it on for per day, and why?
Generally it is wise to treat self-serving advice with some skepticism - the electrician would benefit from being paid for installing a new boiler.
A new gas boiler might be 10-15% more efficient than an older one due to the introduction of energy-saving features (condensing, etc) that reduce how much heat is lost in the exhaust gases. However, this is not the case for an electric boiler, as these just dump heat directly into the water, so you're unlikely to get significant energy efficiencies from a new electric boiler.
Tweaking habits is more likely to sace money than a new boiler e.g.:
- For central heating (e.g. in winter) use the clock to turn on the heating only when the place is occupied rather than heating when nobody is home.
- Heat water on-demand rather than storing hot water which will leak out heat over time (an exception to this would be if there is an variable tariff).
- Change showering habits - less time, lower water flow, shorter, etc.
- Limit use of hot water for washing up e.g. use a bowl rather than free flowing water. Nowadays I mostly use cold water and only use hot for stubborn stuff.
I very much doubt an old immersion heater can be significantly worse than a new one. They are just turning power into heat, there's nowhere for it to be lost.
Inadequate insulation on the tank is another matter (though if in the interior of the house, that heat is offsetting other electric heating anyway, assuming heat is wanted, which it probably isn't in the summer).
If she's using a lot of hot water (long showers!) then maybe the usage isn't so unreasonable.
Is washing done by electric shower or from immersion heater?
Electric shower and instant hot water would cut back on unnecessary heating of water.
What tariff is she on, switching could also save £
Don't know if they can be set up for electrical heating rather than gas (but I assume so) - one of the bast things we got when we needed a new boiler, was getting a 'Hive' device / app for controlling the heating. It allows much finer control of timings etc than an older style on/-off or rotating segment timer, and thermostatic temp settings too. It also means we can turn the heating on or off as necessary remotely, eg if we are later home than planned, use the app to delay the heating, or turn off completely if away (yes thst can be done without a Hive device/app, but not when you've already left home !).
To rewind a bit - one of the photos she sent has 3 isolators labelled Immersion, Boiler and Underfloor Heating. I’ve now confused myself to where I’m not sure what is the difference between “boiler” and “immersion heater”?
Boiler could be CH and HW with the immersion as a backup for HW.
It’s an electric boiler, not a gas one.
Ah, mia culpa. As you were.
Who’s Mia?
On top of all this, I'd start researching time of day electric tariffs like Octopus Agile. 1st thing is to find out if it's possible to fit a smart meter, 2nd thing is to research whether there's any controls for water heating that work smartly with Agile or just set the timer to heat in the expected cheapest period which I assume will mostly be 12am to 4am (tonight's Agile prices for me probably averages something like 2ppkwh between 12-4am)
ASHP instead of the electricity boiler?
More efficient. More expensive though.
Yes. For various reasons.
We run our system boiler at 60C. 55C in summer.
Can she take pictures of radiators, boiler, HW tank to help us out a bit here?
Next question is, how long are her showers?
Not possible..... it's an apartment in a purpose built block
And this is why we need to know just what the setup is. Is the room heating wet (i.e. radiators or wet UFH) or just electric panel heaters?
Assuming it's radiators heated by the electric boiler - does the boiler also heat the water in the unvented tank?
(heating water in a boiler with electricity to then heat water in the tank would seem slightly inefficient when you could cut out the middle man)
A decent unvented tank doesn't lose a huge amount of heat - my 210L Megaflo loses 8c over 24hrs if left alone - to reheat that would use 2kWh...... not very much really.
Incorrect you could fit a heat recovery ASHP, and I know of an internal version that you run ductwork to outside for the air intake etc. Still not cheap.
you need to check the temperatures of the stored water.
