Electrical question...
Electrical question ... I don't understand!!!
3 Users
2 Reactions
 Aus
Hi, hoping someone can help me understand this!
My motorbike digital speedo sometimes fails and simply reads zero … probably 1 in 3 rides.  If I switch the bike off, and restart, it usually works fine.
The speedo works by a rotating magnet near the hub sending a signal to the ECU.  There are 3 wires – a live, a ground and then the 3<sup>rd</sup> which sends the signal.  I’ve bought a Tuneecu diagnostic tool and it reads the error as ‘P1502 Speedometer driver – short circuit to positive’.
As far as I can see, the wiring all looks very clean and in good shape, it plugs into the ECU loom very nicely and cleanly.
I don’t understand the short circuit to positive?
Anyone help?
Thanks
(It’s a 2002 Triumph Speed Triple 955i)
Posted : 18/01/2025 3:36 pm
It means the positive is shorting to ground before it gets to the sensor - check wiring for damage or replace sensor.
Posted : 18/01/2025 3:51 pm
 Aus
Thanks, and keen to understand ... so when I switch the ignition on, 12V is sent from the battery along the positive, but e.g. there's corrosion/mositure on the wire or the positive wire is frayed and touches the frame, so 'shorts' ... is that kinda the idea?
Posted : 18/01/2025 4:24 pm
Yep, the 12v isn't reaching the sensor, my guess is a new sensor might come with a cable attached & sealed to make it waterproof at the wheel end so should fix the problem of cable or sensor.
It would be ideal if you could try one off a similar bike to confirm before buying a new one.
Posted : 18/01/2025 4:33 pm
u02sgb and u02sgb reacted
 Aus
Great, got it.  And I think I could cannibalise a friend's bike to trial a different sensor and wire.  Thanks
Posted : 18/01/2025 4:56 pm
'P1502 Speedometer driver – short circuit to positive’.
I read that as the *input* to the tacho is short circuited (i.e. connected to) positive - possibly by moisture inside the tacho, sensor, cable or connectors.
Posted : 18/01/2025 7:25 pm
 Aus
Well, switched the wheel sensor + cable to a know good one, and still getting intermittent zero.
So thinking of tracing the power feed to digital Speedo I it itself, but surely if this was shorting, it'd be blank rather than displaying zero?
Posted : 23/01/2025 2:45 pm
