Electrical Connecto...
[Closed] Electrical Connectors
6 Users
i need 45 connectors for a project. I need the type of connector that a multi meter spike would fit into nicely...
you no the black and red connectors...
any ideas where to get some??
Posted : 13/04/2011 4:23 pm
More info needed.
Maybe one of the Wago connectors would be good?
http://www.wagobox.com/shop/lever/
Posted : 13/04/2011 4:37 pm
Are you just on about bullet crimps or something better than that? http://www.maplin.co.uk/insulated-crimp-terminal-bullet-plugs-42722?c=so&u=strat15
Black & red, 4mm banana plugs spring to mind, but only really useful for going onto terminals:
http://www.rapidonline.com/productinfo.aspx?tier1=Cables+%26+Connectors&tier2=Connectors+-+Single+Pole&tier3=4mm+Connectors&tier4=4mm+Stackable+test+plug+screw+terminations&moduleno=125052&catRef=17-2885
Posted : 13/04/2011 4:38 pm
so the pins from these will fit comfy in the 'socket' or plug i can then mount to a plastic board.
Posted : 13/04/2011 4:44 pm
Maplin
Posted : 13/04/2011 4:45 pm
thanks for input guys...
also Parraell ATA cable and 2 Sockets without a motherboard??
would be great.
Posted : 13/04/2011 4:52 pm
maplin are stupidly expensive
http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/preinsterms.php
Posted : 13/04/2011 5:05 pm
Maplin are expensive, but at least you can figure out what prefer by handling them.
Posted : 13/04/2011 5:13 pm
RS have a good range, or try CPC
Posted : 13/04/2011 5:15 pm
