Electric motor-type...
[Closed] Electric motor-type noise after ABS working
3 Users
Driving down a muddy field this morning, I locked the wheels (no hill descent). After releasing the brakes there was a whirring like an electric motor which ended after a second or so. It was replicated every time.
I've never noticed it before but the only other time I've locked the wheels there was tyre-squeals and my heartbeat / swearing to drown it out.
Normal? Something to be investigated?
Thanks
Posted : 05/09/2017 2:00 pm
Diesel?
Posted : 05/09/2017 2:01 pm
Yep.
Posted : 05/09/2017 2:07 pm
I could be wrong, but since diesels don't generate a vacuum when running like petrols do they need an additional pump to create a vacuum reservoir. I thought I read somewhere that this could be electric - which might be on yours. What car is it?
Or it could be (perhaps more likely) a mechanically driven pump with a clutch that's cutting in?
Posted : 05/09/2017 2:35 pm
Isuzu D-Max pick up. 3.0L TDI. Auto.
I was driving with the button pressed which starts the truck in 3rd (not first).
From the general tone of your reply it's nothing to worry about. Correct? I know little to nothing about mechanical issues!
Posted : 05/09/2017 3:41 pm
Totally normal. The ABS system has a large electric motor to drive the pump that has to return the released fluid back into the high pressure side of the system. Without that, everytime it released a bit of fluid to "let off the brakes" the brake pedal would sink a bit towards the floor. After a few secs you would run out of brake travel and you'd not be able to re-apply the brakes. The characteristic "pulsing" you feel on the pedal as ABS operates is caused by the pressure fluctuations from the return pump pushing the pedal back up a bit.
You can see the big motor on the ABS modulator in this pic:
it's the black cylinder sticking out from the LHS of the valve block.
Posted : 05/09/2017 5:16 pm
Thanks Max.
Better safe than sorry 🙂
Posted : 05/09/2017 6:08 pm
