Dullest of the dull...
[Closed] Dullest of the dull - what hose pipe fittings?
10 Users
I'm really sorry, but the list of lockdown jobs has got down to sorting the outside tap.
I've got a hoselock hosepipe and fittings, a Worx Hydroshot and a Nilfix Pressure washer. The plastic ones seems to age quickly.Which brands should I be looking, is brass the answer?
Ta.
Posted : 01/05/2020 8:48 pm
We've had a standard plastic Hozelock thread to male connector on our outside tap for years. The hose stays connected mostly, so the connector doesn't do much work. It's also on a north facing wall, don't know whether that makes any difference.
If you're going through loads of them, pick a few up from Lidl/Aldi when they've got their own brand ones on sale.
Posted : 01/05/2020 9:28 pm
Gardena fittings seem to have better reviews compared to hozelock. Guess who else has been buying hose this week!
Posted : 01/05/2020 9:34 pm
We've got high water pressure so the standard plastic hozelock stuff just leaks, but the premium metal hozelock parts appear to be indestructible so far.
Posted : 01/05/2020 9:42 pm
I can't believe that I even opened this thread.
Shoot me in the head.
Posted : 01/05/2020 9:51 pm
I'm reading this with interest. We too have high water pressure. However, the biggest problem is that the hose eventually slips out of the fitting. It is a hose in a reel, so it is quite thin walled to help its flexibility I suppose. I've tried wrapping the end of the hose in electrical tape before I fit the union;it helps a bit but it isn't that good.
Posted : 01/05/2020 10:27 pm
Hozelock metal are decent. The plastic are good, but smash fairly easily.
I used to make them, don't you know...
Jubilee clip, rather than tape to keep the hose attached.
Posted : 02/05/2020 12:10 am
Brass all the way.
Posted : 02/05/2020 4:21 am
Not dull at all.
Hozelock plastic are junk. Never had a problem with these:
https://www.toolstation.com/brass-fittings-set/p30897
Posted : 02/05/2020 8:17 am
Gardena lasts well, brass ones eat o rings, you can't really mix n match with plastic as the brass eats that too, and the brass hose is a bit shite.
Posted : 02/05/2020 8:38 am
