Drain Cleaner recom...
[Closed] Drain Cleaner recommendations?
17 Users
And preferably one I can buy today.
Drain from bathroom sink appears to have finally gunked completely. Before I have to rip off a load of boxing which was put in without any thought to future removal, I might as well try a pour-down-the-pipe type thing. Neighbour plumber mate recommended Mr Muscle which I can get today no probs. I'm no distance from plenty of hardware stores too though, so anything else out there like, say, HG, which folk have tried successfully?
Cheers.
Posted : 26/04/2015 9:34 am
Never found the liquid down the sink stuff to work. The humble plunger has always delivered the goods.
Posted : 26/04/2015 9:37 am
Again, I use Mr Muscle kitchen and bathroom drain gel here, seems to clear the build up of hair and dirt I moult into the shower.
I'd agree plunger are a good solution but haven't got one and Mr Muscle does the job, so can't see any point in changing.
Posted : 26/04/2015 9:38 am
Don't be coming here telling me about stuff what doesn't work. 🙂
I've had the trap (bottle type) off and cleaned completely, checked down to where pipe enters boxing, but can feel funk (EDIT: gunk goddamit) build-up with my fingers. 😡 So whatever I use, I'll be pouring it in after the bottle trap.
Posted : 26/04/2015 9:47 am
 Del
bicarb crystals. solution first with boiling water. be careful.
Posted : 26/04/2015 9:58 am
Caustic soda poured down the plugole. Open the widows and make sure that kids don't go in there.
That is all most drain cleaners are anyway.
Posted : 26/04/2015 10:12 am
if you've got the trap off a poke and a twisting action with some brake or gear outer might sort
Posted : 26/04/2015 10:13 am
antigee - Member
Aye, I may be able to borrow one of those twisty type things, but just looking for a potentially easy solution to try today until I can get hold of something that would do it physically.
Posted : 26/04/2015 10:22 am
If the caustic soda (or a whole bottle of domestos) doesn't work you can get a bottle of Shift-It from a plumbers merchant. 94% sulphuric acid.
Posted : 26/04/2015 10:27 am
94% sulphuric acid.
*Like* 😀
Posted : 26/04/2015 10:32 am
Boiling water and washing soda, which is nasty to skin and aluminium, use about a cupful of one and a kettle of the other. If that doesn't work, caustic soda which is even nastier, used according to instructions.
You need to know that CS and boiling water will react, bubbling violently and spitting alkalai, as the CS dissolves.
Doesn't acid eat the mortar holding your drains together?
Posted : 26/04/2015 10:34 am
Best to pour it into the sink, not some half-hidden pipe.
Posted : 26/04/2015 10:35 am
Mr Muscle works fine on hair / snot / detergent build up. Chuck it in, leave it overnight.
As a student I used medium concentration H2O2 with success but it'll probably get you a visit from MI5 nowadays.
Posted : 26/04/2015 10:46 am
Mr Muscle for us
Posted : 26/04/2015 10:56 am
Do not flush sulphuric unless its with plenty water, the reaction is damn hot (we burnt out a mixing vessel at work getting the order wrong years ago). Dont bugger about trying to get things to react off your own back, not worth risking your eyesight or worse.
I found crystals to work as did the two part stuff from B&M that is sodium hypochlorite and sodium hydroxide, the reaction should shift most plug badgers.
Posted : 26/04/2015 11:56 am
One Shot is great. Open the windows and wear eye protection as acid. Will clear the drain of hair and soap etc. Be aware of the pipe getting hot and will show the location of the blockage. Be ready to run the taps to flush it out too.
Posted : 26/04/2015 12:03 pm
Caustic soda good for hair blockages and less likely to cause damage. If that fails then sulphuric acid
One Shot is great
Sure is - heed the precautions.
Posted : 26/04/2015 12:05 pm
Never liked the idea of putting nasty stuff down the drain. Even if it does get neutralised eventually.
A good old fashioned plunging for me but put more empahsis on the upwards pull (hard and fast) to draw stuff up out of the plug hole if it's not far down.
Something to seal over the overflow helps too.
Posted : 26/04/2015 12:10 pm
Caustic Soda cheap and does the job.
Posted : 26/04/2015 12:11 pm
One Shot = £10 from B&Q. Use it all in one sitting and don't splash it :O)
Posted : 26/04/2015 12:58 pm
*UPDATE*UPDATE*UPDATE*UPDATE*UPDATE*UPDATE*UPDATE*UPDATE*UPDATE*
Mr Muscle has cleared it (mrs deadly didn't bother waiting for STW recommendations 😐 ). Which is a slightly expensive way of buying caustic soda of course.
Posted : 26/04/2015 3:24 pm
Were you a hairdressing student?
Posted : 26/04/2015 4:47 pm
