im after some solid wood 1930s 4 panel doors, 1 above 3 below
and, a solid flat wood door that'll be okay to hold a pretty big mirror (180x80) so can't be some cheap hollow core job like I see in b&q. Â Are fire doors solid core and able to take additional weight?
Reclaimed or new styleee
I'm not fussed if new or reclaimed, more the correct style. Â I suppose reclaimed would fit better with the rest of the woodwork.
for the door that holds the mirror what ever is most solid and cheapest I suppose.
I've got to work out how to screw the mirror to the door securely so the edge of the frame, which will overhang, could be used as a handle to pull open the hidden door behind
