Does the floor get ...
[Closed] Does the floor get hot under a gas oven?
7 Users
I've had to run a phone cable temporarily around the kitchen. Is this a problem if it runs underneath a freestanding gas oven? I expect the floor may get warm but not 200 degrees hot, so a thin cable should be ok?
Posted : 04/02/2020 4:30 pm
Its only a phone cable - what's the worst that could happen?
Posted : 04/02/2020 4:33 pm
If its anything like my oven the bottom of the actual oven barely gets warm when the thing is on gas 9 so underneath I can't imagine getting even a few degrees above ambient.
Posted : 04/02/2020 4:38 pm
No or it would be a fire risk.
Posted : 04/02/2020 4:39 pm
Hot air rises so unless your oven is upside down you'll be fine*
*Don't listen to my advice
Posted : 04/02/2020 4:43 pm
Thanks all, appreciate clearly not ideal, but would be helpful to get some feedback to help assess this. For example, is a modern oven *expected* to be insulated, so this should be OK, but don't leave unattended, or is it a case that this can only lead to disaster...
Posted : 04/02/2020 5:01 pm
It’ll be fine they don’t get hot.
Posted : 04/02/2020 5:04 pm
Ovens are routinely built in to wooden cabinets. Inside the wooden cabinets will be mains cable to power the oven.
Draw your own conclusions.
Posted : 05/02/2020 9:41 am
Or sitting on foam-backed vinyl floors
Posted : 05/02/2020 9:44 am
Our Ooni Pizza oven has zero insulation and the stone base gets to over 500c - The piece of wood it sits on barely gets warm.
Posted : 05/02/2020 9:48 am
