Does speaker cable ...
[Closed] Does speaker cable actually make a difference?
103 Users
It has been fun though.
Posted : 06/07/2021 12:26 pm
Posted : 06/07/2021 12:27 pm
Because a microphone does not work in the same way as ears and ears can detect things a microphone cannot. You can tell if a sound is in front or behind you. Not because of the stereo sound and triangulation ( that only gives you either in front or behind) this ability is to do with harmonics / delays generated in the external ear at tiny relative volume levels
You don't need to determine the direction, you are literally only interested in what the speaker is producing. If it produces the exact same output across two cables then that's that. The cable isn't going to magically change the acoustics of the room.
Posted : 06/07/2021 12:30 pm
Cougar - - a microphone or even array still does not do the same as your ears. But point taken - with 3 microphones and a lot of processing you could replicate the infront or behind but not by the same methods yo can do it with two ears.
Posted : 06/07/2021 12:31 pm
Squirrelking the direction issue is just an example of how ears work differently to microphones
If it produces the exact same output across two cables then that’s that
But thats only the same within the limitations of your measuring devices - and as we know there is no such thing as a perfect measuring device
Again all you can say is they are the same within the limits of your measurement
You simply cannot state with surety that there are not differences undetectable by microphones but detectable by ears
You are usually good at the sciencey stuff 🙂
Posted : 06/07/2021 12:35 pm
cougar - you have a PM
Posted : 06/07/2021 12:38 pm
But you are also setting a bar so impossibly high that there is always some wiggle room for “but maybe you didn’t measure the thing that made the difference”
I'm not setting a bar, I'm just pointing out how experiments work. And even if I were setting the bar, complaining you can't meet it is a bit pointless. First we need to establish the required level of proof and then we need to find out how to obtain it. We can't just say 'well that's too hard so let's reduce the level of proof required'. Wel you can, but it significantly reduces the value of what you're doing.
We’ve only got mol + tj arguing that we can’t measure the things that make the difference
No, I'm saying that there MIGHT be things you cannot measure with your audio testing equipment, but you cannot be sure if you're not measuring it because a) you're not looking for it, b) your equipment can't detecting it or c) it's not there.
@stumpy01 I had a similar experience with my fancy headphones and HD music. I thought 'yeah this is nice' then I realised I could understand way more of the lyrics than I previously could.
An interesting side point here - my wife is more or less completely un-musical, where as I consider myself fairly musical. She can barely remember tunes and is incapable of things like picking out instruments or recognising melodies and the like. However she's much better at hearing lyrics than me and anecdotally I'm quite poor at this, because everyone seems to know the words much better than me.
So are our ears different? Or are our brains simply processing it differently? Does that mean different things go into our brains when the vibrations enter our ears?
I'm keen to know why Cougar is so adamant that we cannot hear a difference between different cables. I mean be sceptical by all means, but you can't be sure can you?
Posted : 06/07/2021 12:41 pm
And you cannot state with equal surety that there are.
It's very easy to make wild claims without any evidence, isn't it. But as we learned from the brexit threads, it's equally easy to dismiss them with the same substantiation.
Posted : 06/07/2021 12:42 pm
Observer effect
https://en.wikipedia.org/wiki/Observer_effect_(physics)
"This effect can be found in many domains of physics, but can usually be reduced to insignificance by using different instruments or observation techniques".
https://audiophilereview.com/news/why-double-blind-testing-cant-work-for-audio/
Hardly surprising they should argue against double blind testing. That way if someone says something couldn't be proven using double blind testing they can say it doesn't work in audio so proves nothing.
Posted : 06/07/2021 12:46 pm
Here's another thought.
When you do hearing tests, to see what frequencies you hear, you have headphones on usually right? It's not difficult to see how that could interfere with the function of your outer ear. And your outer ear is sensitive to sound in general - after all, if you touch it, you can hear the sound it makes. Try gently touching your tragus and then the skin just in front of it - sounds quite different.
Also if you sit with headphones on for any length of time the air in the ear cup becomes very humid. This could also affect the experiments.
I'm not asserting anything here by the way - just talking about things that could be affecting what we observe from experiements.
Posted : 06/07/2021 12:48 pm
apart from you can because its proven 🙂
How relevant that is is highly debatable.
Slowold man - insignificant does not equal zero 🙂
yes basically – because the microphone is an objective measure but what you hear is subjective – and thats due to the processing between your ears and your conciousness and because your ears function differntly to a micro[phone
If the mic can demonstrate that there is (objectively) no difference, how can ears (subjectively) detect a difference?
Posted : 06/07/2021 12:57 pm
Apart from you can't because it isn't.
We can do this all day, have you got a citation?
Posted : 06/07/2021 12:59 pm
Slowold man – insignificant does not equal zero 🙂
But it is insignificant.
Cost per metre.
Posted : 06/07/2021 1:00 pm
Given that an audiophile friend of mine made me listen to a whole side of a Phil Collins album once, because of the way it was recorded, it’s definitely the latter…
"The production on that album is amazing".
Posted : 06/07/2021 1:01 pm
Because microphones and ears work differently. Insisting that the output of the microphone is the absolute fundamental truth of the sound in its entirety is a bit daft.
Posted : 06/07/2021 1:03 pm
Hear ( sic) you go cougar
https://asa.scitation.org/doi/abs/10.1121/1.413219
https://direct.mit.edu/pvar/article-abstract/1/2/251/58771/On-the-Externalization-of-Auditory-Images
2 microphones cannot do this in the same way - they will always produce two possible locations that are a front / rear mirror image and cannot tell vertical angle
Its one of the weird things with ears - being able to tell the vertical and front / rear direction of noises with only two receptors in the same vertical frame
Posted : 06/07/2021 1:05 pm
Ok; I'll bite
What is a good enough level of measurement that any of you *would actually accept the results* ? There isn't one; the bar isn't set too high; the bar doesn't exist on this planet. Or if it does would you *please* tell me where the hell it is ?
'there is a difference I know it'
'Ok; lets set up a controlled experiement to see if we can actually prove or disprove it'
'Doesn't matter; you might not be able to measure it'
I mean.. come on. There's moving goalposts; and then there's fastening them onto a SpaceX rocket and lighting the tailpipe! 😀
Posted : 06/07/2021 1:08 pm
But I would insist that it's an accurate and representative of the pressure waves produced by a moving diaphragm attached to a moving coil being deflected by the presence of an electrical current passing through it. This handwaving around being able to measure stuff is getting ridiculous tbh !
Posted : 06/07/2021 1:10 pm
that is true steve - but it does not tell you how ears react to the sound
Posted : 06/07/2021 1:12 pm
Or can the human ear and associated processing do things a microphone cannot ( sound in front or behind is one example)
Can a microphone ( and any processing) tell you the direction of the sound source?
Calrec Soundfield mic or similar?
2 microphones cannot do this in the same way – they will always produce two possible locations that are a front / rear mirror image and cannot tell vertical angle
We're not using microphones to work out where the noise is coming from. Your argument is spurious to being able to measure if a sound wave produced by a known source in a known location is the same or different depending on which cable is attached.
‘there is a difference I know it’
‘Ok; lets set up a controlled experiement to see if we can actually prove or disprove it’
‘Doesn’t matter; you might not be able to measure it’
A proper blind control will be able to tell you if ears can detect a difference. It does not matter if you can measure that difference or not.
Posted : 06/07/2021 1:13 pm
We’re not using microphones to work out where the noise is coming from. Your argument is spurious to being able to measure if a sound wave produced by a known source in a known location is the same or different depending on which cable is attached.
I am simply using that as one example of how ears can do things microphone cannot
Posted : 06/07/2021 1:14 pm
It absolutely; unequivocally *does*.
Posted : 06/07/2021 1:17 pm
What about three? Or six? Or twelvety?
Which is exactly what I've been saying from the outset and been told by more than one person that the Scientific Method won't work because... I don't even know, the most robust reason I've seen thus far is "I can't be bothered."
Posted : 06/07/2021 2:01 pm
Why? If a difference is found in blind trials then the difference is there. If its something that cannot be measured then that does not mean it does not exist.
Posted : 06/07/2021 2:04 pm
If we could find a difference in blind trials; then we must be able to design some sort of apparatus to measure it. Then we can prove what the difference actually is.
But arguing that there's a difference even if we can't measure it is just silly.
I mean; we've got CERN finding the subatomic particles that make up the matter of the universe; this is nothing like as fancy
Posted : 06/07/2021 2:09 pm
I can think of many things both in audio and in general physics where there is an effect but it cannot be measured
If a properly blind study shows a difference then that difference exists whether it can me measured or not
Posted : 06/07/2021 2:13 pm
Like what ?
Posted : 06/07/2021 2:14 pm
It's the core of experimental physics.
Posted : 06/07/2021 2:39 pm
It’s the core of experimental physics.
Designing experiments and sensors to measure and record observed or theoretical stuff, yes it is.
Going around saying "we cant measure a difference at all but you can hear it" - less so 😀
Posted : 06/07/2021 3:00 pm
Many things? Name, oh, I don't know, half a dozen. That's less than "many", yes?
Agreed. But it seems that everyone asserting this to be the case has a note from their mum when asked to try it.
Posted : 06/07/2021 3:50 pm
Many things? Name, oh, I don’t know, half a dozen. That’s less than “many”, yes?
OK I am not going to use google so feel free to pick holes in this 'cos I am sure there will be some. Have fun
Position AND speed of an electron. IIRC ( certainly 2 qualities of an electron) You only know one or the other
Weight of a photon. We know it acts as both a wave and a particle - as a particle it must have weight but can you weigh it?
"warmth" of sound. We all know some sound output sounds are "warm" some "cold". You can hear the difference. Can you measure it?
How an individual perceives sound. indside my head is the sound I hear the same as what you hear?
Pi. Yo can draw diagrammes that demonstrate pi. But you cannot measure it accurately even tho its clearly drawn ( ever increasing sided polygons inside and outside a circle). Its on paper, you can show it but you cannot measure it accurately only calculate it
colours - we can see them, we can measure the wavelength but we do not know if what I see as red you see as red.
changes in the weight of things as they approach the speed of light. We know ( or believe) this to happen but it cannot be measured because your measuring tool will also be effected by the same effects. You can infer it from observation even I believe, but it cannot be directly measured
The status of a cat in a box whose death is controlled by decaying radioactive elements. Without opening the box we do not know if its alive or dead.
have fun with that lot.
Posted : 06/07/2021 4:20 pm
Going around saying “we cant measure a difference at all but you can hear it” – less so 😀
That second thing is literally a follow on from the first one.
Even I'm bored with this now, and that's saying something. I'm trying to point out that the experiment with the microphone isn't necessarily as cast iron as you think it is, in a variety of ways, and you're just saying 'no' all the time, so I'll leave you to it Mr Cleese.
Posted : 06/07/2021 4:28 pm
I’m trying to point out that the experiment with the microphone isn’t necessarily as cast iron as you think it is, in a variety of ways, and you’re just saying ‘no’ all the time, so I’ll leave you to it Mr Cleese.
Interesting - given people saying "no matter how you measure it; there might be a difference you can't measure" - I've repeatedly asked *what* proof people would accept; and yet nobody has given me an answer. It doesn't have to be a microphone; I already mentioned other options. If there's a difference; it has to be measurable somehow; right ? It's only speaker cable after all !
Posted : 06/07/2021 4:39 pm
If a blind listening test shows a statistically significant effect that effect is there. If you cannot measure the effect then its still there.
Posted : 06/07/2021 4:41 pm
Thats a rather big if though.
Posted : 06/07/2021 4:47 pm
Weight of a photon.
No idea here. Chemistry is not my bag, baby.
“warmth” of sound. We all know some sound output sounds are “warm” some “cold”. You can hear the difference. Can you measure it?
Can you not?
This is almost philosophy. Does what I think of as 'red' look the same to you?
But we can calculate it far beyond any practical usage. Is this not true of other things? Can you measure the length of your desk to several trillion decimal places?
colours – we can see them, we can measure the wavelength but we do not know if what I see as red you see as red.
Hah, I just said this. (-:
Again, not something I know anything about so I can't comment.
The flaw in Schrodinger's thought experiment is that he's clearly never owned a cat. Put a cat in a box and seal it up, you'll know with cast iron certainty whether it's alive or not.
Posted : 06/07/2021 4:48 pm
Why would it *not* be measurable ? Honestly; why this insistence ? You'd look again at your system of measurement; refine and adjust until you worked it out.
Posted : 06/07/2021 4:49 pm
stevehine - the point is simple. If in a blind listening test a difference is detected that difference is there whether you can measure it or not. I am not saying it is not measurable - I am saying being able to measure it is not the critical point,. the critical point is detecting the difference. Maybe you can maybe you cannot measure it - thats irrelevant. the difference is there.
You do not have to be able to measure something to know its there.
Posted : 06/07/2021 4:54 pm
Technically, TJ is correct. If you can reliably detect a difference in fair conditions then that difference is clearly there even if it's immeasurable.
However, the chances of this scenario actually occurring are hypothetical at best.
OK I am not going to use google so feel free to pick holes in this ‘cos I am sure there will be some. Have fun
Weight of a photon. We know it acts as both a wave and a particle – as a particle it must have weight but can you weigh it?
That's about the most impressive example of whataboutery I've ever seen.
I'd call it a dead cat except, well you know....
Posted : 06/07/2021 4:56 pm
Careful now. You're on the cusp of proving god.
The other thing with the cat in the box cougar is all cat owners know if yo uput a box on the floor the cat will get in it
Posted : 06/07/2021 4:57 pm
@tjagain you are obsessing over something that has never been questioned. The question is whether a particular cable makes a difference to the output of a speaker. End of.
That output may be measured electrically, acoustically, magnetically, dynamically or any combination thereof. Your observer effect is irrelevant since the measuring devices are constants and in a controlled environment the only variable is the cable. Change the music, run it again. Change the speakers or source, run it again. Compare the results. Congratulations, you either have repeatability and thus science wins or it's all over the place and proves a writer from What HiFi knows better than hundreds of years of empiricle observation.
Leave philosophical questions out of this and you are left with the science. How you choose to translate the output between your ears is not what is being discussed here.
Posted : 06/07/2021 4:58 pm
Change the music, run it again. Change the speakers or source, run it again. Compare the results. Congratulations, you either have repeatability............
100% agree with this. the only thing that matters is can you hear a difference. It matters no one jot if you can measure it - accurately or not
I was just nitpicking daft statements from folk claiming absolutes when you cannot and claiming other stuff that is not correct. Just being nitpicky and amusing myself sorry.
Posted : 06/07/2021 5:05 pm
It's probably worth noting that behind the scenes TJ and I have been slapping each other about the face with gloves. It's all done in the best possible taste, or something.
Posted : 06/07/2021 5:16 pm
That’s about the most impressive example of whataboutery I’ve ever seen.
I’d call it a dead cat except, well you know….
I was challenged to come up with a bunch of unmeasurable things having claimed that this was so. I did my best and am somewhat disappointed no one pulled it to pieces
Posted : 06/07/2021 5:28 pm
If you've paid for the full half hour I'm sure someone will be along in a minute
Posted : 06/07/2021 5:38 pm
Can you not?
Of course you can. Spectrum analysis.
OK criticise this experiment.
Place one speaker in an anechoic chamber.
Play some source material.
Record it with a single high quality mic.
Change the speaker cable.
Repeat experiment.
Align the start points of both recordings, normalise levels, invert the phase of one recording.
Combine.
Any difference will show up as a deviation from a flat line (i.e zero signal).
Now then as for double blind testing, it simply isn't adequate to do the experiment once. Anyone can say "yes I heard a difference". What needs to be done is for the experiment to be done several times and for the subject to record whether condition A or condition B exists.
Posted : 06/07/2021 5:50 pm
Well more than once for blind testing - I would have thought in the range of hundreds of times to get statistically significant results but I am no statistician. I never said do it once - thats obvious nonsense
good point on the measuring of an ill defined thing - so you would be able to tell a difference but could you state which was the "warm" sound and use the difference you have found to be able to predict whether another sound was "warm" or are you finding a difference but an unquantifiable one?
Posted : 06/07/2021 5:56 pm
Well more than once for blind testing – I would have thought in the range of hundreds of times to get statistically significant results but I am no statistician. I never said do it once – thats obvious nonsense
So do you think given many repeats a listener could reliably pick the same cable as their favourite?
good point on the measuring of an ill defined thing – so you would be able to tell a difference but could you state which was the “warm” sound and use the difference you have found to be able to predict whether another sound was “warm” or are you finding a difference but an unquantifiable one?
My understanding is that "warm" refers to more bass leads treble. Easily demonstrated by spectrum analysis.
Posted : 06/07/2021 6:24 pm
Is this the longest ever thread resurrection?
This arguing about testing criteria bollocks has been going on now for almost more pages than the original thread 🤣
It's certainly the worst thread resurrection.
You know that theory about monkeys, typewriters and Shakespeare?? I feel like you lot are edging real close.
Although....it'll be more like the script for Eldorado than Shakespeare.
Posted : 06/07/2021 6:26 pm
I am really not sure. After many repeats you would get a valid answer tho - either there is a statistical correlation or there is not
My understanding is that “warm” refers to more bass leads treble. Easily demonstrated by spectrum analysis.
Fine - every day is a school day 🙂
Posted : 06/07/2021 6:36 pm
Well it's more interesting than speaker cable.
I am really not sure. After many repeats you would get a valid answer tho – either there is a statistical correlation or there is not
So on that basis "does speaker cable make a difference?" has not been answered either way.
Posted : 06/07/2021 6:46 pm
You don’t need an anechoic chamber, use a klippel near field scanner, this method of measuring can be more accurate than using anechoic chamber especially for 50hz and less
Posted : 06/07/2021 6:50 pm
NOt until someone runs a proper trial no
IMO ( and its only an opinion) the difference between shitty bell wire and some proper cable at a couple of quid a metre can be heard easily. Beyond that you so quickly get into diminishing return that I doubt you can and I am perfectly happy to accept the hypothesis that above a certain level it makes no difference
But a proper blind study done with multiple people and many multiples of tests would give a definitive answer
I think the reason that hi fi companies will not do this is that they don't want to hear the answer. If they were sure of their products then they would test them properly in this way
Posted : 06/07/2021 6:52 pm
is this thread why the site keeps asking me to 'agree and move on'
Posted : 06/07/2021 6:58 pm
Well it’s more interesting than speaker cable.
It's actually not, depressingly.
So on that basis “does speaker cable make a difference?” has not been answered either way.
If its a simple yes or no answer, the answer has to be yes.
Although I'd caveat that with as long as it's reasonable quality, decent sleeving and decent terminals. Which might mean spending £10/20 quid rather than £2.99.
I'm really not convinced spending more on super fancy audiophile grade stuff will make any difference.
Posted : 06/07/2021 7:26 pm
This is my opinion also. But I sure as shit wouldn't hang my hat on it, I'd have zero confidence in my own ability to actually be able to reliably tell the difference.
Posted : 06/07/2021 8:37 pm
Not necessarily because I'm fairly sure that 50% of the population don't give a toss and probably 40% aren't really that good at listening. It'd be like asking the general public to rate fine wine. Most people would go 'mm that's nice wine' and a good many would say 'I don't like wine'.
Posted : 06/07/2021 9:07 pm
How's that if the test hasn't been done? Surely the simple answer is "we don't know"?
Posted : 06/07/2021 9:14 pm
Given that quantum effects and Schrodingers thought experiment based challenge to the Copenhagen interpretation have been raised as evidence against being able to prove/disprove anything via measurement I postulate that whether anyone of us here is personally wearing underwear at any given moment will made a difference to how TJ’s morning coffee tastes.
Measure that!
Posted : 06/07/2021 10:24 pm
Bindun.
https://www.tylervigen.com/spurious-correlations
Posted : 07/07/2021 1:56 am
I did one for myself.
It wasn't blind
I couldn't hear a difference.
Why don't you get two cables, a mate to a/b them over the same hifi, same music, same seat, same room.
You won't find out if it's true for everyone, but you will find out if it's true for you.
It would take less time than reading this whole thread!
Posted : 07/07/2021 9:48 am
My morning coffee tastes great. who has the pink knickers on?
Posted : 07/07/2021 10:25 am
Not necessarily because I’m fairly sure that 50% of the population don’t give a toss and probably 40% aren’t really that good at listening.
repeat it enough times and you still get a statistically significant answer even if half the folk doing it are deaf
Posted : 07/07/2021 10:26 am
Perhaps. But if only say 1% of people are capable of differentiating the sound, given how time consuming it is to do it the study wouldn't be large enough to give results that weren't 'statistically insignificant', I suspect.
When I was about 8 or so they offered violin lessons, but they gave us a test to see how much of a musical ear we had which screened out about 80% of kids. Seems a bit elitist these days to be honest, but for violin teaching I can sort of understand it.
Posted : 07/07/2021 10:43 am
How’s that if the test hasn’t been done? Surely the simple answer is “we don’t know”?
The simple answer is "yes" because everyone agrees there are some basic electrical parameters that need to be met by the cable to achieve adequate performance.
The non simple answer is the one being debated here. As some people claim once the electrical parameters have been met full performance is achieved and increasing the specification of the cable has no effect on performance or colouration of the sound.
Where as some people claim that the basic electrical parameters only offer good performance but not full performance and "better" cables do offer more performance. Also different parameters (above the minimum requirement) can colour the sound and you can tune and adjust to your liking.
Posted : 07/07/2021 11:02 am
But as far as we know the claims have never been tested properly.
Posted : 07/07/2021 11:03 am
Ooooh design of experiments! - part of my day job. First decide the likely magnitude of effect you would like to detect. A difference of proportion (50-50) is a noisy endpoint at the best of times. Then guess the likely variability in the response for an individual (test-retest). Then calculate sample size needed to detect the difference you think is important (say 10% of people prefer nice cables to cheap ones). The randomise those subjects to AB or BA and run the experiment. In fact, for test-retest sensitivity, one will re-run AB and BA randomised multiple times in the same subject. This has the effect of reducing the overall sample size needed.
Studies are powered on false positive and negative rates. The power is typically to detect an effect if it exists in 8/10 to 9/10 experiments, and declare an effect when it doesn't exist in about 1/20. At a rough estimate, for a 10% difference, you will need a 100 subjects.
The fact that one can measure spectral differences in responses within the aural range isn't really in doubt (as that linked article states). They are not large, but they are present and measureable. This is based on the length, impedance and skin depth of the cables tested. Whether they make any impact on perceived audilble quality is another matter entirely. Speaker responses can be read off these curves because the effects are much more pronounced.
Posted : 07/07/2021 11:12 am
Did anyone watch Ethan Winers experiments? Would love to know your thoughts on his experiment strategy and his conclusions...!
Posted : 07/07/2021 4:55 pm
Did anyone watch Ethan Winers experiments? Would love to know your thoughts on his experiment strategy and his conclusions…!
Skip back a few pages and you'll get your wish.
Posted : 07/07/2021 5:09 pm
16 pages and the answer is a simple no. Snake oil for the audiophiles. I’ve got some magic beans to sell if anyone wants them?
(Runs and hides)
Posted : 07/07/2021 5:32 pm
* Wake up
* Have a wee
* Make some coffee
* Check STW whilst driving coffee
Yep, they're still wanging on about speaker cables.
All is well with the world.
Posted : 08/07/2021 7:17 am
Around the mid 90s I was working with a couple of companies selling high end gear to recording studios and on the side I fitted out a couple of home studios for extremely rich people with more money than sense (hence my getting the job) and the general attitude of the engineering advisers I used was that anything more expensive than electric cooker cable was OTT as long as you had decent connections fot it. I doubt that electricity has changed much since.
It was good enough for George Martin back then and he was supposed to have decent ears.
Posted : 08/07/2021 9:15 am
I take it you're in the 'yes it makes a difference' camp as cooker cable is quite a bit meatier than bell wire? (or at least it is in my house)
Posted : 08/07/2021 2:46 pm
Skip back a few pages and you’ll get your wish.
Blimey I had a look but couldnt find it - assumed it died - didn't realise it was back on page 8!
To those asking whether that video is now gospel... ironically Ethan Winer is seen as a bit of a god within audio engineering circles 😀 (He's done a lot of work on audio myths and bringing science into audio)
Posted : 08/07/2021 3:55 pm
Page 8 / 8
